LED shop lights
/ LED shop lights #102
The build quality of SMD's (LED arrays) varies greatly depending on who builds them across the pond. Don't much care what the brand is because the brand don't denote who actually produced the SMD's.
The reason I brought up brand is because Costco is extremely careful about bringing in sub quality merchandise. And the fact that they have been carrying it for a long time tells me something.
/ LED shop lights #103
I have 44 of the Costco/Feit lamps so far, in 3 different areas + a couple in each of 5 containers - some have been in service for about 5 years, others less than 2. To date, I've lost both tubes in one fixture and one in another - both are in a tarped area, both show signs of having gotten dripped on. From this I would surmise that they are IP-zip; my response is NOT to use 'em where they'll get wet.
Costco puts 'em on sale every so often for around $15, when they do I grab a few. ATM, my "stash" is down to less than a half dozen, so next time I see 'em on sale I'll grab a few more.
In containers, lighting without making any holes is easy - I buy these
1 Pack of Super Strong Neodymium Fishing Magnets, Pulling Force Rare Earth Magnet with Countersunk Hole Eyebolt Diameter 1.26 INCH(32mm) for Retrieving in River and Magnetic Fishing: Amazon.com: Industrial & Scientific
Plenty strong pull to support lamps, switches, power strips, etc - a short ladder or stool, some tie wraps, 2 magnets - tie wrap the magnets to the hanger slots on the lamp, up on the stool, hold one end up by the roof til it grabs, do the other end, few more magnets/tie wraps if you care about cord droop - same mount for a power strip by the door. Keep an extension cord just outside the container - open the door, plug in the power strip. Works pretty good til I find more "tuits"... Steve
/ LED shop lights #104
As a rule, I prefer not to patronize Amazon for anything because of who owns it and... If the seller don't say what SMD's are used, you can bet they aren't CREE. Interestingly, even Harbor Freight's 'Roadshock' series of lights and bar lights are all CREE SMD's and HF states that in their ad blurbs. I think the trade name 'Roadshock' sounds kind of stupid but I didn't dream it up.
Electricity use, LED versus fluorescent in my shop is inconsequential. My machine tools and welders pull a heck of a lot more power and are usually running every day.
The last 2 things i purchased from harbor freight were a batteryless flashlight that you shook for light. When it stopped working i opened it up and there were 3 button batteries. The copper coil was fake and a plane metal bolt moved back and forth simulating a charger. The last thing i purchased were some GFCI outlets for a temp power box. When they would not trip with my testing unit, i opened one up. There were no electronics inside. Both of these happened maybe 7-8 years ago, and i never went back. I wonder if their CREE leds are really KREE.
/ LED shop lights #105
I went with LEDs in my shop, not so much for the minimal energy savings with respect to flourescents, but because they work in cold temperatures. My shop isn't continuously heated.
I have no beef with Bezos, I can think of CEOs I like way less.
/ LED shop lights #106
it's CREE btw and yes they are. Buddy bought a light bar and we dissected it prior to use and the SMD's are marked CREE. Kind of surprised me.
I get almost all my SMD's from SuperBrightLED.com fast shipping and everything thy offer has the tech drawings on the website and plainly spells out who made the LED devices.
HF stuff in general has improved greatly over the last 5 years or so and the prices have increased as well. I like and buy the Icon tools, Snap-On quality but not at Snap-On prices.
/ LED shop lights #107
I don't respect his politics but that isn't germane to this discussion do I'll leave it at that. Been getting some stuff from Bangood. It's 100% Chinese and they make no bones about it,
/ LED shop lights #108
Oh yeah good point cold weather lighting, that where LEDs shine, I definitely need cold weather lights. I remember fluorescent's not so good when cold......
/ LED shop lights #110
Don't matter to me, my shop is climate controlled.
My shop has an excellent heat system. But no AC. My HVAC guy is working up a quote to change that. :)
/ LED shop lights #111
i have heat in my shop also, but if i tried to add AC i think the wife would send me packing.
/ LED shop lights #112
Yeah, it's real hard to "sell" that plan in a hobby shop. :D
/ LED shop lights #113
I still need to blow in attic insulation now that I have new 45KW propane powered sealed combustion heater and a dedicated 125gal tank added to my shop this spring.
Still working up the guts to ask my wife to assist me with the DIY insulation job. "Honey would you please cut and load these bags into the machine while I operate the hose?"
/ LED shop lights #114
Good opportunity for bonding through a common goal ;-)
/ LED shop lights #115
Climate shop must get costly...
What kind of budget to keep comfortable?
My shop heat is bringing in the car after the drive home.
/ LED shop lights #116
I had my shop insulated with urethane spray foam. I keep it heated and cooled with a heat pump with propane backup. Fortunately the propane only runs on rare occasions, like having overhead doors open in the dead of winter, or when it stays below 20 degrees out.
I can’t say enough good about the Urethane, it truly is worth the cost.
I replaced all of my fluorescent lamps (96 HO) with 96” LED’s from Amazon. I got the ones that let me remove the ballasts.
/ LED shop lights #117
Makes sense being well insulated...
/ LED shop lights #118
My shop and house suck propane out of the same tank so I can't give you an exact dollar amount.
In the last 12 months I used 1,050 gallons of propane at $1.25 per gallon totalling $1,312.50.
I would estimate 40% went to the shop. If so, it cost me $525 to heat my 1,900 square foot shop.
/ LED shop lights #119
For comments like these your location would be greatly appreciated.
/ LED shop lights #120
I would love to have an insulated, heated shop (other than a small-ish woodstove), but can't really justify the expense on something I don't use that much in the winter (A/C not needed here). Still, what I have now is waay better than what I had at my last house.
Clearly, your experience with "we" projects is different than mine. :laughing:
2019 Dodge Charger Sedan (A64557)
2019 Dodge Charger...
1991 Polar MC 312 General T/A Chemical Tanker Trailer (A64194)
1991 Polar MC 312...
2022 East Manufacturing 48ft. T/A Walking Floor Trailer (A64556)
2022 East...
Kivel 42in Forks and Frame Mini Skid Steer Attachment (A64553)
Kivel 42in Forks...
2013 WINSTON AP22024AL-DC T/A 24FT TRAILER (A66091)
2013 WINSTON...
2015 FORD F350 XL SUPER DUTY BUCKET TRUCK (A63276)
2015 FORD F350 XL...
