LED shop lights
/ LED shop lights #144
Pole Barn is never heated and clad in tin with insulation under the very high roof panels...
It's the only time experienced mold and thinking was leather is more prone being a natural product.
My chainsaw and similar are stored on plastic garbage cans or tubs... no issues yet but sometimes they don't see the light for a year or more.
/ LED shop lights #145
Most dehumidifiers of any capacity will have a garden hose tap on the condensate container. You hook up a garden hose... never have to empty it ever again.
It has that function, but I don't use it coz I have nowhere convenient to drain it to. It let's you know when it's full, I just empty it out then.
/ LED shop lights #146
Has anyone tried the lights with 4 adjustable panels that screw into a light bulb socket?
/ LED shop lights #148
Yes, we have one in the female Craft room. It seems to work very well, puts out a lot of light (10,000 lumens) and seems to be RF quiet.
/ LED shop lights #149
I have 4 of the 70 pint frigidaire dehumidifiers, three of them hooked to hoses and it is essential to keep the humidity out. For the basement areas without drains, I use seperate pumps with floats that push all the water out a basement window well when the reservoir fills. The difference between occasionally emptying a bucket and 24/7 water removal is huge, the differnce between moldy and unmoldy stuff in the room.
/ LED shop lights #150
I've seen them with condensate pumps to move water...
/ LED shop lights #151
Our high efficiency forced air electric furnace is located in the basement and it has an small external pump to vacate the condensate water. Should be easy to install and route depending on location.
/ LED shop lights #152
Wow, I never knew electric furnaces produced condensate, always thought it was a by product of NG or propane combustion. Just learned something.
/ LED shop lights #153
I'm guessing it's there for the air conditioning.
/ LED shop lights #154
I would bet a dollar he is talking about the "A" coil of the heat pump when run the direction that the A coil gets cold. Not when the reversing valve runs it the other way so the A coil gets hot.
But I think you knew that already.. :)
/ LED shop lights #155
I really didn't. I know nothing about electric furnaces other than the cost of operation around here is not economical. Back on the 60's there were a number of 'all electric' homes built here that have since converted to other fuels.
/ LED shop lights #156
Electric Heat pumps are common here for house heating and cooling. The unit does both heating and cooling functions. For a simplistic view, think of a window air conditioner that cools your room in the summer, and puts heat in the room outside. If you turned the unit around, it would take heat from the outside and deliver it to the inside. Obviously as the "heat" outside becomes less and less, then the available heat to extract from the outside air becomes less and less, and then the units efficiency drops. Then resistor banks are switched on inside the "A" coil housing and that is when the expensive heating starts. :) I am guessing up in Michigan, there might be a deficit of "heat" in your outside air in January so these units might not be very common up there.
Long story short, during the cooling time of the year, as the A coil cools down condensation forms on it and runs down and must drain to somewhere. Or be pumped uphill to be gotten rid of. During the heating cycle of course, no condensate is formed on the coil as it is hot.
/ LED shop lights #157
Well, we do have an electric (220-1) hot water heater that is very economical to operate because our utility provider has a separate meter for it and can shut it off during peak demand hours if they want to. Far as I can tell, they never have but I will say the cost per KWH is on par with propane.
I don't believe they will do that with an electric furnace however.
Good friend just built a new home and put in a 'Water Furnace' and did a direction boring for the HX pipes (5 feet below grade in 2 100 foot closed loops). Seems to work just fine for both cooling in the summer and heating in the winter but I believe the backup heat source is resistance elements so it could be an expensive deal if the ambient temps are extremely low and the water furnace cannot keep up with demand. Again, don't know how they work but I assume it's a heat pump of sorts.
/ LED shop lights #158
The ground loop heat pump will probably never use the resistance backup unless there is a failure in the heat pump itself. The old air exchange heat pumps would use the resistance heating when the air temperature went below 20 deg F or so, but the water system will never go that low so you won't need the resistance backup.
/ LED shop lights #159
dont bet on it. i work on several houses that have ground loop heat systems, and in winter the backup heat kicks in. mind you this is north idaho.
/ LED shop lights #160
I've had my geothermal for about 15 years. My backup resistance heat has never kicked on in northern Indiana. I believe -22 is the coldest it's been.
MAC STRIPPERS POWER MAC JR LINE PAINTING TRUCK (A63276)
MAC STRIPPERS...
2016 Ford Explorer AWD SUV (A64557)
2016 Ford Explorer...
2023 JCB S3246E ELECTIC SCISSOR LIFT (A63276)
2023 JCB S3246E...
2024 JOHN DEERE TURF GATOR TX 4X2 UTV (A63276)
2024 JOHN DEERE...
2020 CATERPILLAR CS54B SMOOTH DRUM ROLLER (A65053)
2020 CATERPILLAR...
2006 Western Star 4900 Concrete Mixer U98358 (A62613)
2006 Western Star...
