Price Check Kubota B2650
/ Kubota B2650 #1
ALSA0554
Kubota B2650
Hello,
Recently inherited a B2650 Kubota with full enclosure. The only accessory is the 63 inch snow blower. Bought in 2015. The tractor has 55 hours on it and resides in northern Michigan USA. Can anyone help with a value
Thank you
/ Kubota B2650 #2
You have a great reliable Kubota tractor with factory cab, and only 55 hours on it. Current value is highly variable depending on indoor or outdoor storage, and if it has hydraulic remotes and front loader. Also is the snow blower rear or front mounted? Just my opinion, but the potential value may range between $19,500 to $23,000 depending on configuration.
You can do research at following locations:
Used Kubota B265 Tractors for Sale | Machinery Pete
KUBOTA B265 For Sale - 76 Listings | TractorHouse.com - Page 1 of 4
Kubota B265,B265HSD,B265HSDC Tractors For Sale New & Used | Fastline
/ Kubota B2650
Thanks for your reply. The issue I have with getting a value is that all I research have a front loader. My father bought his only for snow removal.
/ Kubota B2650 #4
Yes, I was wondering about the FEL, because you failed to mention it. Most come with FEL, but some do not.
Your probably on the low end of that value range. Other members on this forum can provide a better price value than me, but you really need to advise on the following questions. I also assumed the snowblower was an extra item, not included with the tractor. Good used tractors hold their value surprisingly well.
1. Is it a front or rear mounted snowblower, the model, and is snowblower included with tractor.
2. Is the transmission HST or Gear
3. Indoor or outdoor storage for last 5 years.
4. Are rear hydraulic remotes on the tractor.
How you answer the above questions, adjusts the value of your tractor. Any pictures available?
And a big welcome to the forum.
/ Kubota B2650 #5
OP, is the 'full enclosure' actually a Kubota factory installed cab, or an aftermarket? Pics help. good luck...
/ Kubota B2650 #6
How much can a Kubota b2650 lift?
GMC 2500HD 4wd Service Truck (A63689)
GMC 2500HD 4wd...
Ford F-450 (A63689)
Ford F-450 (A63689)
New/Unused Landhonor Hydraulic Quick Attach Pallet Forks (A65583)
New/Unused...
New Holland T5070 (A64126)
New Holland T5070...
KBH Tank Trailer (A63688)
KBH Tank Trailer...
2019 CAT 259D (A60462)
