PTO shaft size
/ PTO shaft size #1
bones66
BlueGrass State
MF-230
If the tractor pto has 6 splines and it is a 1 3/8 can I assume the other end of the shaft which fastens to the Bushhog gearbox and has 6 splines is also 1 3/8?
/ PTO shaft size #2
Depends, IF the rotary cutter was made for a 1000 RPM tractor, then NO, also some really old import rotary cutters even turned the opposite direction. (by todays standards)
SR
/ PTO shaft size #5
Easy way to find out: try connecting the tractor end to the implement. If it's proper 6 spline 1 3/8 the detent ball should lock on too.
/ PTO shaft size
SR
I’m possibly wrong but I think 1000 RPM pto shafts have 20 splines (1 3/8) or 21 splines (1 3/4). Thus tractor equipped with both 540 & 1000 outputs cannot be mixed.
A lot of them have something like an 1 1/8" keyed shaft.
..... but I have 6 spline on both ends. Both ends look identical in size but of course the tractor side has the push detent and the implement side although splined has a bolt pinning (Not a shear bolt) it to the Bush Hog. I want to put a slip clutch in-line and was double checking before I ordered. I couldn’t find dimensions on Bush Hogs website.
/ PTO shaft size #7
Pull the PTO shaft and see if the tractor end will fit on the gearbox end. You are trying to run it connected this way, just doing a dirty size check! If it does not fit as tightly as it does on the tractor PTO stub, go buy an inexpensive caliber and measure the gear box shaft diameter. Calibers can be bought most anywhere from harbor freight, Lowes, home depot and on and on.
/ PTO shaft size
Guys I have a caliper but believe it or not I couldn’t find the correct way to measure a PTO shaft.
New/Unused Wolverine 72in Quick Attach Brush Cutter (A65583)
New/Unused...
2017 Peterbilt 579 (A64127)
2017 Peterbilt 579...
2022 CATERPILLAR 262D3 SKID STEER (A62129)
2022 CATERPILLAR...
ROAD GEAR ALUMINUM HEADACHE RACK (A64277)
ROAD GEAR ALUMINUM...
Case 1083 20ft Corn Head (A63118)
Case 1083 20ft...
2020 INTERNATIONAL LT625 T/A SLEEPER TRUCK TRACTOR (A59914)
2020 INTERNATIONAL...
