Front-End Loader Loader bucket cylinder replacements
/ Loader bucket cylinder replacements #1
Believer45
Cincinnati, Ohio
Kubota L305DT with Bush Hog 2240QT loader
Both the bucket tilt cylinders on my loader started leaking badly. Bush Hog uses the wire style attachment for the cylinder heads. I was able to get the heads to turn but the wires have evidently broken off inside the groove in the head/cylinder bore as they stopped moving with the heads when you turn them. OEM replacements range from $670 to just shy of $1,000 each. OEM bore is 1.75 inches. I have found aftermarket replacements that will fit for $133 each (shipping included). They have similar stroke but the bore is 1.5 inches. Since this is on the bucket tilt and not the lift cylinders my question is will the smaller bore (about 25% smaller, if my logic is working that means more speed and less power) be an issue?
Any insight is greatly appreciated.
Thank you ------ Dave / Believer45
/ Loader bucket cylinder replacements #2
Pressure and flow is what determines the power of a cylinder...the size of the rod would be a strength issue...
BTW...1/4" is 1/7 of 1-3/4" which would be about 14.3% I think...
Good Luck...
/ Loader bucket cylinder replacements #3
At 2500 psi you’ve got about 4400 pounds push vs 6000. Also the loader curl does it’s main work with the retraction stroke so the rod size is also important. I don’t think you’d be happy with that kind of loss. The previous posters calculations for percentage loss are incorrect. When you’re dealing with the area of a circle double the diameter is 4x area.
/ Loader bucket cylinder replacements #4
Drill a blind hole directly into the gland through the slot in the barrel where the wire exits. Insert a piece of wire, cut off screw or something that fits into your blind hole and sticks up just high enough to clear the top of the groove in the barrel. Turn the gland, if you have a strong enough slug of metal cut the right length the wire will come out. Do not drill more than 2/3 of the way down to the cylinder rod.
If you do this correctly and it works (it usually does) the gland can be re used.
/ Loader bucket cylinder replacements #5
Good Luck...
I apologize...I was only thinking of rod dia. and not the bore...!
Giyi HWG72 (A60463)
Giyi HWG72 (A60463)
Poly Fuel Tank with Electric Pump (A55851)
Poly Fuel Tank...
2019 FORD F-250 XL EXT CAB TRUCK (A59823)
2019 FORD F-250 XL...
NEW HOLLAND 706 30 INCH 3PT DIRT SCOOP (A57024)
NEW HOLLAND 706 30...
UNUSED FUTURE 12" HYD AUGER (A52706)
UNUSED FUTURE 12"...
iDrive TDS-2010H...
