HOW TO: Adjust the Pressure Relief Valve (PRV) on the MF GC 1705/10/15/20
/ HOW TO: Adjust the Pressure Relief Valve (PRV) on the MF GC 1705/10/15/20 #81
I'm sorry for trying to help....the chart is not "mine", I was just proving it as a reference to the info-notice that it's from DHH. Most won't even read the charts or the FAQ's, you think they'll read or understand a disclaimer about a ball vs. a poppet?
I also can't help that OEM's change things or pick oddball couplers to use on their machines...Good day all, I'm out.
Well you're linking it on your website and referring customers to it, so...that chart is "yours" enough methinks.
/ HOW TO: Adjust the Pressure Relief Valve (PRV) on the MF GC 1705/10/15/20 #82
Think there is a lot more to this ....
All so close but yet so far....
On my DL 95 loader on 2017 GC 1715...
Probably is ISO 5675, which is "0.56 in" ( 1/4 inch) by direct measurement...
ON female body it states its a Safeway S45-2 which is 1/4 inch....
https://www.safewayhyd.com/wp-content/uploads/2019/04/Safeway-Catalog-2018-2627-S40-Series.pdf
WHICH makes the "Bolt on Hooks" chart correct for my application...
Dale
/ HOW TO: Adjust the Pressure Relief Valve (PRV) on the MF GC 1705/10/15/20 #83
My 2015 GC1710 has 1/4" on it. I believe newer models ultimately converters go 3/8" but don't quote me
/ HOW TO: Adjust the Pressure Relief Valve (PRV) on the MF GC 1705/10/15/20 #84
Dale
Your chart and link should help folks out, and those that have 1/4" couplers should have couplers the same as I have...
On my GC2410, which has the FEL- Model DL100, here are the couplers that I had researched years ago and purchased:
All are Safeway; S40 Series, 1/4" Body, 3000# @ 3 GPM
S40-2 is a "complete coupler" (female & male)
S45-2 is a "female half"
S41-2 is a "male half"
And I purchased Loctite Sealant 545 for the installation.
KC
/ HOW TO: Adjust the Pressure Relief Valve (PRV) on the MF GC 1705/10/15/20 #85
Ok, I'm seeing a pattern with the Safeway couplers, I guess they're following numbering which is fairly common with fluid power fittings. In Sxx-2, the number 2 seems to indicate that it's a 1/4" npt fitting. Mine is a S45-3, 3 meaning it's a 3/8" npt. If it was a 4 it would be 1/2" npt.
/ HOW TO: Adjust the Pressure Relief Valve (PRV) on the MF GC 1705/10/15/20 #86
You are beginning to understand specifications and part numbers....
Dale
/ HOW TO: Adjust the Pressure Relief Valve (PRV) on the MF GC 1705/10/15/20 #87
Dale
:cool2:
I work with pneumatics for a living with the fittings and all that, different game but same ballpark as hydraulics.
/ HOW TO: Adjust the Pressure Relief Valve (PRV) on the MF GC 1705/10/15/20 #88
:cool2:
Safeway does it kind of different than other companies like Gates or Eaton. 1/4" in Gates is a #4, 3/8 #6, 1/2 #8 and so on.
Any local industrial/hydraulic supply place should be able to hook anyone up with the fittings needed. They are usually so well versed in their field, you can take a picture of what you need with you phone and they can get you on your way.
/ HOW TO: Adjust the Pressure Relief Valve (PRV) on the MF GC 1705/10/15/20 #89
jist got got a 2010 GC2400 with DL100 (255 hours on it) that seems a bit low on lift power. granted I am more used to a 2017 GC1710 DL95 but this DL100 struggles more than what the spec differences themselves cause. I am having breakout issues with 250lbs (3/4 bucket) of loam.
system operates smoothly no odd noises/etc just little less force than should be.
am unable to find out pressure specs for the GC2400 / DL100 combo and on kenny site am unable to tell for sure what the fitting would be.
any advice appreciated
/ HOW TO: Adjust the Pressure Relief Valve (PRV) on the MF GC 1705/10/15/20 #90
This image might be useful for fitting type....
https://www.tractorbynet.com/forums...ust-pressure-relief-valve-page-2-page-001-jpg
You might find details on pressure in ARGO parts books.... Sign as guest....
Welcome to AGCO Parts Books
Dale
2022 FORD F-250 STV CREW CAB TRUCK (A59823)
2022 FORD F-250...
1985 CADILLAC SEVILLE (A60736)
1985 CADILLAC...
KJ K3325 33'x25' Barn Shed (A60463)
KJ K3325 33'x25'...
2019 ATLAS COPCO QAS 25 T4F NB-3 PHASE GENERATOR (A60429)
2019 ATLAS COPCO...
Kubota L2501 (A60462)
2018 Toyota C-HR Hatchback (A59231)
2018 Toyota C-HR...
