3pt watering solution
/ 3pt watering solution #1
czechsonofagun
Elite Member
Old Dominion
Kubota B1750
I built this to water rhododendrons my wife planted on the other end of our property, out of reach of the hose. We used to haul water there by wagon and bucket, now I can water from the tractor seat. It is just a barrel and roller pump for the PTO.
I finished it by the end of July and naturally the whole August it rained pretty much every second day :D
/ 3pt watering solution #4
Looks useful. How is it plumbed? A roller pump, being positive displacement, needs some kind of pressure relief unless you squeeze your nozzle prior to pump engagement.
/ 3pt watering solution #5
My neighbor figured that out when he built a "fire wagon". 1,000 gallon tank with gas powered positive displacement pump. Had 3 separate hoses with fire hose style shutoff nozzles. As soon as he revved up the engine he exploded the plastic pump case. :(
/ 3pt watering solution #6
Looks great but take off those rubber tarp straps and add some web straps.
Thats what I do - hold the nozzle open while I engage the PTO, I might replace it with just a jet to make it foolproof. With just a hose it pulses :)
The barrel is pretty much balanced, rubber straps is all it needs.
And yes, it will assist by the burn pile too. Few years back it took a lot of effort to extinguish all the leaves around it when it went ablaze.
/ 3pt watering solution #9
Not a fan of any PTO powered stuff unless there is no other way. Maybe a 12v transfer pump?
Why? That's what the PTO is for. I prefer the pto pump over a 12v pump, it'll do more volume or more pressure, just all around more useful. I'll do a 12v pump on a pickup because that's all the power source I have.
Adams Tender / Magnolia Trailer (A61307)
Adams Tender /...
CAT 930M (A58214)
CAT 930M (A58214)
2000 ITASCA SUNCRUISER 37G CLASS A RV (A60736)
2000 ITASCA...
CATERPILLAR 926M WHEEL LOADER (A60429)
CATERPILLAR 926M...
2004 John Deere 310G 4x4 Loader Backhoe (A59228)
2004 John Deere...
2014 18ft. Parker Performance T/A Trash Trailer (A60352)
2014 18ft. Parker...
