Pressed-In grease fittings???
   / Pressed-In grease fittings??? #1
Fuddy1952
Elite Member
South Central Virginia
1973 Economy and 2018 John Deere 3038E
Wonder who the idiot was who developed press in Zerk fittings? I had to bush hog a field today so thought I'd grease my new bush hog (I think it has 30 hours) and the wheel swivel one just pulled out. I'll dis-assemble it, drill & tap new Zerk after washing everything...but how dumb design can anything be?
   / Pressed-In grease fittings??? #2
CheeeeeP !!!!
   / Pressed-In grease fittings??? #3
Most times press-in zerks are fine if installed correctly. Care has to be used when drilling the hole by double drilling or reaming.
   / Pressed-In grease fittings??? #4
One day I realized that all my old implements are clearly better built than the new ones. And about at the same time it occurred to me that we aren't ever going to get back to quality machinery unless we change something. So when I can see something of better quality, I buy that one.
Maybe more importantly, for awhile now I've been making an effort to return things that are poor quality. Hit them where it hurts.
All that takes is making sure that both the retailer and I agree about their return policy. It's usually right there on the receipt, so it turns out to be easier than I thought. To my surprise, I haven't had any problems doing that even with fairly high dollar things like appliances. After all, the retailer just wanted to make a sale; he didn't manufacture it.
I don't buy something intending to return it; I expect it to work right so I don't have to. But I surely will bring it back if it doesn't.
It's not perfect, but I don't know of any better way to get the manufacturing world to change.
rScotty
   / Pressed-In grease fittings??? #5
Press In or Drive In have been around over 100 years... My 1928 Ford is full of them and no issues other than lining up the grease gun...
I have the drive tool which sets the fitting home.
   / Pressed-In grease fittings??? #6
I use press in fittings on everything I make for the tractor. No issues. Hole has to be correctly sized.
   / Pressed-In grease fittings??? #7
As rScotty indicated, quality is a serious issue—but on this one it is my opinion that quality fails in 2 areas
1) inferior steel! It just does not have the integrity for the long term to hold up. This is a factor in both parts the zerk and the modern implements, with a few exceptions.
2) workmanship or rather lack thereof, is how I chose to express the bigger issue of quality. Very few individuals anywhere take any ‘pride’ in a jib well done. This has always been and issue but not as widespread as it seems it is currently.
As someone else mentioned, the drilled or stamped hole during the construction stage must be the correct size for the press in zerk. This is actually quite involved for long term success, the hole must be clean, free of burrs and when pressed in the zerk needs to properly aligned, these conditions can be achieved easily and quickly with experience and attention, but mass production tends to place less importance on these than speed too often it seems.
Then quality control seems next to nonexistent.
I guess it goes back to the old joke when this 60 yr old was a kid, you don’t want a car build on a Friday or a Monday! On the former the workers are too distracted thinking about their weekend plans and the latter, they are suffering from their weekend activities!
   / Pressed-In grease fittings??? #8
Press fits have been around for centuries. Nothing wrong with press fits. Sloppy work has been around for a long time too.
Sloppy zerks are a pain, sloppy axle bushings are more so. Sloppy crankshaft bushings are a disaster. All similar Third World stuff. None of it is impossible to fix, just time-consuming.
In recent decades, sloppy work and poor fits are increasingly combined to make cheap goods. That leads to a manufacturing future that looks good to some but not for me. I simply return things when they are shoddy or defective.
not shy,
rScotty
   / Pressed-In grease fittings??? #9
rScotty
Be VERY careful with the Best Buy (appliances) return policy.
After fifteen days, Best Buy will NOT accept returns, even if the item is unused! (ask me how I know)
When I bought my John Deere tractor from a local dealer I got most implements with it, FEL, BH, bush hog, etc. I can't take it back after over a year just for a Zerk. Otherwise it does a good job.
I've never had a threaded Zerk fail. I've added Zerks to things not having one (drill & tap). I'm not a mechanical engineer but common sense when you grease something the hydraulic pressure is a lot and "wants" to push a press-in out. I push gun tip straight on and pull straight out. I grease until I just start seeing grease come out. I don't think I'm doing it wrong?
Just seems like mentioned here "cheeeep!"
2014 MACK CXU DAY CAB (A54607)
2014 MACK CXU DAY...
JOHN DEERE XUV835M (A53084)
JOHN DEERE XUV835M...
HYUNDAI HL760-9A LOADER (A52705)
HYUNDAI HL760-9A...
Case-IH 370 Steiger (A53314)
Case-IH 370...
2012 Ram 1500 Crew Cab Pickup Truck (A53422)
2012 Ram 1500 Crew...
2007 CATERPILLAR D6K LGP CRAWLER DOZER (A52705)
2007 CATERPILLAR...
