Bush Hog Chain Length
   / Bush Hog Chain Length #1
bones66
BlueGrass State
MF-230
When I am operating my bush hog and using a chain instead of a top link should the chain be tight, have slack. If you say slack about how much.
Please do not try to save my life by telling me how dangerous using a chain is.... I already know it is not OSHA approved! Thanks!
   / Bush Hog Chain Length #2
This is soooo dangerous! :laughing:
The only time the chain needs to be tight is to raise the mower for transport or to back into tall stuff. Take the top link off and raise your lift arms to the highest point you plan to mow at and then measure for the proper length of chain. No problem.
Thanks! That is exactly how I have mine set. I contemplated letting it out a couple links to allow it to conform to the ground contour rather than lifting the tail wheel and in many instances allowing the tail wheel to bounce down against the ground rather hard.
   / Bush Hog Chain Length #4
Why isn't it OSHA approved?
   / Bush Hog Chain Length #5
Because it is so dangerous. Be safe out there! :thumbsup:
   / Bush Hog Chain Length #6
You can always throw a quick link in there so it is adjustable to a point.
   / Bush Hog Chain Length #7
Use a bit of rope and bungee cord in the middle of the chain, up to the top of the roll over bar to hold up the chain when it has slack..
   / Bush Hog Chain Length #8
   / Bush Hog Chain Length #9
I was joking with the OP. I do not think it is dangerous at all. I found humor in his first post.
   / Bush Hog Chain Length #10
I think it's because there's a chance that the mower deck could flip forward if there is not a rigid connection to the top link.
I had the same question years ago. Imagine that the front edge of the mower hit something like a stump. It would probably take a perfect storm of beer and bad decisions in order for this to happen though. Three Stooges meet the Keystone Kops.
2016 Club Car Carryall 1500 4x4 Utility Cart (A55758)
2016 Club Car...
2007 INTERNATIONAL DURASTAR 4300 BOX TRUCK (A58214)
2007 INTERNATIONAL...
2022 Delta Gooseneck Equipment Trailer VIN # 4MWGF4022PN059238 (A57453)
2022 Delta...
2021 Ver-Mac PCMS-3812 Solar S/A Towable Trailer Message Board (A55973)
2021 Ver-Mac...
ST225/75R15 Trailer Tires (A55787)
ST225/75R15...
2022 Ram 2500 4x4 Crew Cab Service Truck (A55852)
2022 Ram 2500 4x4...
