Gear Box Temperature
/ Gear Box Temperature #1
dieselscout80
South Carolina
New Holland TC45DA
What is a good temperature for a gearbox with straight cut gears to run?
My new (used) Alamo was about 180 degrees today when I was mowing.
However, it was at least 90 degrees outside today.
/ Gear Box Temperature #2
They get pretty hot, but 180 degrees is just about perfect. You want to be over 140 degrees so the heat drives off any moisture.
/ Gear Box Temperature #3
Never thought about checking the temp until I saw this, anyway temp in the mid 80's and the gearbox on the Alamo was at 133 by the IR temp gun.
/ Gear Box Temperature #4
I've never heard of that?
/ Gear Box Temperature #5
Yesterday I was following a 3/4 truck with a flatbed. It was 55F degrees and raining. His rear third member and about 6" of tube on each side of it was dry. Wonder what temp it was running?
/ Gear Box Temperature #6
I never have either until my reverser gave me trouble on my bulldozer. It would work fine when it was cold, but as it warmed up, it would start to slip. I dug into that problem and fixed it, but while I was there I put in a temperature and oil pressure gauge, as well as a hydraulic cooler.
It knocked my temperature down, but too far, and was creating condensation in the oil.
UNUSED KUBOTA M1886-96" QUICK ATTACH BUCKET (A62130)
UNUSED KUBOTA...
New/Unused Wolverine 82in Quick Attach Bucket (A61166)
New/Unused...
2017 FORD F-450 XL BUCKET TRUCK (A58375)
2017 FORD F-450 XL...
Mini Metal Donkey Statue (A61569)
Mini Metal Donkey...
6053 (A61165)
6053 (A61165)
2020 CATERPILLAR 259D3 SKID STEER (A62129)
2020 CATERPILLAR...
