3-Point Hitch hyraulic top link? B21
/ hyraulic top link? B21 #1
joea99
Marbletown NY
Kubota B21, JD 240GT
Thinking about a box blade, instead of a Land Leveler. Both EA items. While the LL seems easier, I really have more to do that just "maintain" the road/driveway. The drainage is poor and needs side drainage and crowning. Also have some ground, dirt, rocks, I need to clear up and level.
Most say a hydraulic top link makes it almost fun to use a box blade and some say the standard B21/B26 top link might bend if pushing backwards. Just starting to look at what might be needed.
Cat 1 hydraulic top links seem to be under $150. I read that a "remote" setup is needed and find them quite expensive. But, since the backhoe will be removed, is it reasonable to look into just rigging up something on my own, plugging into the backhoe oil supply? Or is that what the remote kits all do anyway?
Have a WR Long 4 in 1 bucket now, which has a "remote" (?) for that already. I leave that alone, I'm thinking.
/ hyraulic top link? B21 #2
Some say the standard B21/B26 top link might bend if pushing backwards. Just starting to look at what might be needed.
I do not think the B21 Top Link will be a problem. The potential problem(s) are your two Lower Link stabilizers.
You should not PUSH dirt with chain/turnbuckle stabilizers for your Three Point Hitch. Chain/turnbuckle stabilizers only support the Lower Links when the tractor is operating forward, when the "chains" are in tension.
If you wish to prudently PUSH dirt you need install rigid, pin-adjustable stabilizers to your Lower Links. Tractors are designed to PULL. You have to be very careful when you PUSH or something will break.
B21 T-L-B had 21-horsepower gross when new. Not too sure how heavy a Box Blade your T-L-B can pull after this much time and tire tread wear. Box Blades depend on weight to peel slices of moist soil into the "box".
I'll look around for that type stabilizers. Any suggestions for sources?
The size of the B21 concerns me a bit regarding being able to effectively use the box blade as I hope (got some big rocks hidden in the dirt) but EA makes a range of sizes. For this class from 55-72" and 350-400 lbs as I recall.
When I brought up Box Blade to a neighbor some time ago he looked a bit skeptical. Did not get into why, beyond "touchy to use".
/ hyraulic top link? B21 #4
1. The key parameter for Box Blades is implement weight per unit of width. Eighty pounds per foot of width is good.
2. Box Blade should be rear tire outside width or up to 12" wider (6" each side). With your limited power I would shop for outside tire width to 4" wider.
3. Only a Moldboard Plow requires more time than a Box Blade to learn to use proficiently. Most here consider all tractor seat time fun time.
/ hyraulic top link? B21 #5
It is possible the TPH kit for your B21 has rigid stabilizers. Check.
The B21/B26 is a low volume model. Rigid stabilizers for a standard Kubota 'B' model tractor may fit. I would start with your Kubota dealer.
Mark Hodge at Stabilworks custom made mine which have been perfect. He made rigid stabilizers part time. He may or may not still be in business: markhdg@gmail.com
eBay: Stabilizer Assembly for Ford New Holland Tractor - D9NNB856AA | eBay
VIDEO: Kubota Standard L Series L843 Telescopic Stabilizer kit (overview and install) - YouTube
/ hyraulic top link? B21 #6
Rigid stabilizers are unnecessary and a "gimmick" sold by some dealers. If you have chain stabilizers adjusted correctly and an implement attached, the lower arms are not going to move side to side. That's all I got to say except the guy in the video didn't even know what kind of wench he was holding. :rolleyes:
By "low volume" I take it to mean production numbers?
In any case, looking at this semi rationally, if I really need to "push" I can always "back blade" or frustrate myself with the 4 in 1 "bull dozer" fantasy . . . Pushing with the Box Blade would be a nice thing, but I could probably get by.
/ hyraulic top link? B21 #8
Any tractor with at least one set of free hydraulic remotes I find a hydraulic top link to be handy. Never had one until we found the used 3PH fork lift attachment. We just left it on the tractor after getting it.
The links are like the ones shown in your earlier picture. Same as B26.
Mark Hodge still has a web page, dropped him a line.
In any case, looking over the hitch, seem to me the stabilizers, in the case of the Box Blade I'm looking at anyway, may not take a whole lot of "compressive" force or shock, with the heavier links directly mounted to the Box and Tractor are taking most of the beating, hopefully "square" to the direction of travel.
I have zero experience using a Box Blade and can only engage in wool gathering at this point so could easily be missing some crucial point.
/ hyraulic top link? B21 #10
The Kubota factory turnbuckle stabilizers in this picture weigh about 4-1/2 pounds.
The rigid Mark Hodge 'Stabilworks' stabilizers in this picture weigh about 12 pounds.
I personally deformed/bent the properly adjusted Kubota factory turnbuckle stabilizers in this picture pushing dirt with a Rollover Box Blade.
Kubota B3300SU tractor-loader.
TUGGER TRAILER (A58214)
TUGGER TRAILER...
1995 John Deere 7400 (A60462)
1995 John Deere...
2020 DRAGON ESP...
HYSTER S50FT STRAIGHT MAST FORKLIFT (A59823)
HYSTER S50FT...
2016 John Deere 4044R 42HP 4WD Utility Tractor (A59228)
2016 John Deere...
2010 International 7400 Service Truck with Crane, VIN # 1HTWGAAR4AJ276527 (A61165)
2010 International...
