CoyPatton
- Joined
- Aug 10, 2015
- Messages
- 1,645
- Location
- Poplar Bluff, MO
- Tractor
- Yanmar YM2002D with Koyker 110 FEL
Noted. I never take my tractor out of 4x4.
I do not know your property so that may be appropriate, but would not be for 95+% of tractor owners. You should NEVER use 4x4 on solid surfaces (this will be in all owners manuals) included very hard packed soils. There is some lag between the front axle and rear axle due largely to different size tires and partially to how the 4x4 is designed.what that means is on surfaces that do not allow for slippage you run a huge risk of damage to the mechanical components of the 4x4.
Again your owner’s manual will tell you to use 4x4 when need! For a very few operators is that going to be 100% of the time.
