Anvils???
/ Anvils??? #22
I use my anvil quite a bit. I'll post a pic tomorrow. I'm sittin under a shade tree drinkin a Beer and too lazy to walk to the shop for the pic. :)
/ Anvils??? #23
Ah. Life is good
/ Anvils??? #25
I was 12 when I started my Model A restoration.
The Blue Chip stamp vise I was using had a anvil back and I broke it... Dad was not too happy but I said it's the only anvil we had.
Dad asked around and one of his friends loaned me his... this was in the 70's.
About 30 years later I was at a 4th of July party and making conversation and was asked if Jack is my dad?
Then it came out we had his deceased Father's anvil...
Last I heard all parties concerned have passed and I still have it nearly 50 years later.
/ Anvils???
Pics or it didn't happen. :D
/ Anvils??? #27
Here is a pic of my ASO (anvil shaped object). My daily driver you may say...
Used for pounding on sh*t. The real anvils are kept for smithing.
/ Anvils??? #28
So is that piece on the end a vice, or just an extension to give you a flat place to hold things?
Aaron Z
/ Anvils???
Aaron Z
I have seen this beast... it is impressive as is most everything in Terry's IMC (Industrial Man Cave)!
/ Anvils??? #30
Aaron Z
Just a sliding extension Aaron.
/ Anvils??? #31
An oxy-fuel torch and grinder can fashion a passable horn on railroad track. If confidence or equipment is lacking, take it to a metal fab shop.
/ Anvils??? #32
Here's my two. Given to me and I clamp on a 18 inch I beam section to use. Look at the nice job he did on the horn.
Many of you have heard this common saying about railroad iron anvils.
Well.as they say, it's as good as a real anvil, if you haven't used a real anvil. But, truthfully, I have, and I can say that it is nearly as good.
/ Anvils??? #33
I met an aerospace engineer just yesterday. He made an anvil out of RR track and was surprised the top surface had been work hardened to a depth of one inch!
He was able to cut most of the way through with an abrasive cut off wheel and then smacked it with a large sledge hammer. He says it broke clean.
/ Anvils??? #34
Here are my anvils
A 295 pound Peter Wright
and a 200 pound John Brooks
A little made in England Record
And modern 65 pounder of unknown origin that was gifted to me from a couple of brothers who own a local scrap yard. Surprisingly good quality with 95 percent rebound.
/ Anvils??? #35
Here's a 1,000 pound one on Ohio Craig's list.
/ Anvils??? #36
Rails made into anvils. There must be more than 50 steel mills that have made rails over the past 150 years. With that variety of mills and age, we can't expect them to be the same in fact, steel making technology has really improved over those years. I'd suggest using the most modern rails you can find and the heaviest. Like 100lb rail as a minim but 140 would be my choice. Of course what you find in junk yards would be on the lighter and older side.
/ Anvils??? #37
15 or more years ago I picked up a Hay budden 250 lbs anvil from a hardware /machine shop over the state line in PA that was going out of business. The shop had been in operation way back in time and was full of old tools and hardware. The anvil is in perfect shape with only a nick on the horn from a chisel. Based on the stamping it dates back to late 1800's. Also picked up a ring anvil and a large block with shapes in for forming.
/ Anvils??? #38
A swage (or swedge) block! Cool.
I have a couple 200 pounders.
/ Anvils??? #39
I the 1950's I worked for a blacksmith shop in a rural area of Denmark partly in the blacksmith shop and partly repairing tractors and trucks. There were 3 of us kids learning the trade. Started at 15 and finished after 4 years. There was the old master blacksmith and a journeyman blacksmith working this full time. There were no forging machines back then but he lined up the kids around the heavy forgings with sledge hammers and he would set the tempo with his regular hammer and we had to keep up with the sledges in turn
/ Anvils??? #40
What a great story!
WACKER NEUSON LIGHT TOWER (A60736)
WACKER NEUSON...
40ft High Cube Shipping Container (A61166)
40ft High Cube...
Zero Turn Mower (A59231)
Zero Turn Mower...
2016 Toyota Camry Sedan (A61569)
2016 Toyota Camry...
2015 Kia Sorento AWD SUV (A56859)
2015 Kia Sorento...
17101 (A55851)
17101 (A55851)
