Buying Advice Bought 100 Acres. Upgrade my tractor or hire some work done?
   / Bought 100 Acres. Upgrade my tractor or hire some work done? #31
Instant on, instant off, saves a lot of time. Oaks are what I cut.
Changing a battery is faster than fueling with gas. No Bar Oil. Changing a reciprocating saw blade takes 40 seconds, much less time than replacing a chain. Reciprocating saw blades are minimally affected by dirt on the wood.
When new, a battery would last me six hours in the woods. Now, after years, half that time. The Milwaukee Sawzall I purchased came with two batteries in the package. Batteries fully charge in 30 minutes.
The only reason I'm not calling total B.S. on this statement is because of your clever wording. :)
Last six hours in the woods. Yep. My cordless equipment will last six day in the woods. If I limit my use. I would never expect anyone to believe that I can do six hours of work with it sawing trees on one battery. Unless I'm a piddler and spend more time looking at the trees than sawing. Once I mark a trail my chainsaw is cutting trees 90% of the time it's running. :)
   / Bought 100 Acres. Upgrade my tractor or hire some work done? #32
I didn't read all the replies but I have put in miles of ATV trails which I make wide enough for a truck to get threw, all I have ever used is two chainsaws, a machete and a ATV, I personally wouldn't pay someone $10 an hour to cut ATV trails, I might hire some HS kids if the work is too much for you. I grab my 660 magnum which I bought used when I was 18 and my MS 201 Stihl arborist saw which I also picked up used for a few hundred bucks. Yes it's a slow process but that's the part of being a land owner, invite some buddies to come over, pack a cooler full of beer, a work radio, chainsaws ext and get to work and have fun, I bet I could clear faster trails with the set up I just suggested than that guy charging $100 an hour. Cut everything at ground level, throw/roll it all off to the side and keep going, once you get going, it goes fast. I'm 25 now and if you comfortable running a chainsaw safely and felling trees then I would say your set.
Another thing to add is I don't make my trails strait, I kinda zig zag them, that way your saving a lot of time clearing brush vs trees and if someone wanders on the property they don't pop out in the back yard.
Now if you want nice flat roads your better off paying a guy with a bull Dozer to cut one. ATV Trails are easy. Only thing I would use a tractor for is FEL cutting into banks to drop down in creeks.
Well stated John. Direct and to the point. :)
   / Bought 100 Acres. Upgrade my tractor or hire some work done? #33
As to the rechargeable sawzall,,,,, really??? Can it be done?? Yes.. Is it efficient and timely?? No.. :confused3:
I didn't want to comment on that one cause it's not really worth arguing over lol. Whatever gets the job done safely I guess.
   / Bought 100 Acres. Upgrade my tractor or hire some work done? #34
I have a makita cordless sawzall 18v with the larger 3 amp hour batteries, under heavy use the battery is dead in about 15-20 mins and too hot to charge. Same goes for the dewalt I have seen other guys use on jobsites.
   / Bought 100 Acres. Upgrade my tractor or hire some work done? #35
Yep, I have four Dewalt cordless tools. Tool batteries will last a couple weeks laying on the bench. Put them to use and reality sits in. Especially on a high amp draw tool such as a sawzall or circular saw. Again I stress, it's all about work tempo.
   / Bought 100 Acres. Upgrade my tractor or hire some work done? #36
I'd love to see a picture of the OP's woods. My woods and most around here are 50+ years since they were last farmed or cut so not a lot of saplings and typically more than 4-6 feet between trees. So a tractor can drive right through the under brush. Just put the bucket down and push the bushes out of the way. But doesn't sound like that's what the OP is dealing with. Picture please!!!
   / Bought 100 Acres. Upgrade my tractor or hire some work done? #37
I have not heard this mentioned yet, " how about a heavy duty rotary cutter that handles 4 inch brush? Seems it would clear a path in the majority of it with a lot less chain saw work.
   / Bought 100 Acres. Upgrade my tractor or hire some work done? #38
I gotta say, I'm in the do it myself crowd. That would also mean my bride of 30+ years would be right beside me helping. I don't think it needs to be a race to get it done. Just get a saw and start cutting. :)
One other thing. I sure wish I had 100 acres to deal with.:laughing:
   / Bought 100 Acres. Upgrade my tractor or hire some work done? #39
Have you considered hiring a guy with a masticator? Don't quote me on the machine name, but it clears trail and chops up the material at the same time, leaving behind only splinters and chips...
   / Bought 100 Acres. Upgrade my tractor or hire some work done? #40
I was over 50 when I got my 40 acres. I did a LOT of clearing of brush using a machete: I was able to slash for hours at a time, switching between hands; got to be pretty good. Now, the reason for this approach is that I had no idea what was underneath that brush, or, for that matter, where I was going (only in a crude sense): lots of areas machinery couldn't go anyway- see my comment below about getting an excavator stuck!). Oh yeah, my wife would also be out swinging a machete (and she's just a tad bit older than I, not to mention diminutive in stature).
Had I went about hiring out for clearing it would have meant that I'd have had to have a plan! I was aware long before acquiring this property that one very good bit of advice is to live with/on the land for a full set of seasons before doing anything major. My slow clearing has allowed me to make better decisions about how to make my property work. I've gotten 5 ton excavators stuck, and I knew full well where I was (oddly enough my smaller, wheeled tractor had just been in that area and I didn't get stuck); someone not familiar might do a LOT worse. One other thing which matters in my case, in my area of the world, is that I have to be mindful of not making huge, rapid changes such that they'd draw any unwanted attention: I'm good with my neighbors, so no worries there. Anyway...
After doing some research on a bush hog for my newest tractor I got to understand a little bit more about them. There are bush hogs for CUTs as well as UTs that are able to cut up to 4" diameter trees. Well, we know that they can cut thicker, it's just that that's what they're rated to do and keep doing it for a long time. I cannot fathom chewing up stuff like that, but there it is. Bigger stuff can be cut with, yes, a chainsaw (I didn't fall it [it was too close to the house so I hired it out], but I did recently buck and cut up a cottonwood that was 44" at the butt; I've taken down and cut up 3' diameter stuff): even my wife can run a chainsaw- knock on wood, we've been at this for some six years now w/o incident. Up until just getting my new tractor and a used 6' Bush Hog 286 (good for 3" stuff- it's been fortified) I'd managed to deal with things using my B7800 and a 5' "light duty" rotary cutter: biggest gain was when I got a tooth bar! If you cut up the tree trunk a ways you can push over a lot of stuff. I've got various clumps of stumps and other large wood debris to get out of my way, so I've purchased a grapple (only possible with my newest tractor).
On the infrequent occasion I need to remove BIG stumps (I will bury them, most of them- have one that was so massive that I'd have had to dig to China!) I'll rent an excavator.
I/we live here, so having [most of the] equipment and time makes it a bit more convenient.
I don't ever tell people what they should or shouldn't do (unless they're trespassing :laughing:). I'm just providing info on what I've done as a way of musing. Every situation is different.
2010 Chevrolet Silverado 1500 (A55973)
2010 Chevrolet...
2017 Freightliner Bucket Truck (A55973)
2017 Freightliner...
2019 DRAGON ESP 150BBL ALUMINUM (A58214)
2019 DRAGON ESP...
Kubota KXO40-4 (A53317)
Kubota KXO40-4...
IRTPL 10,000 LBS TWO POST LIFT (A58214)
IRTPL 10,000 LBS...
2018 LARK UNITED MANUFACTURING S/A GUARD SHACK (A55745)
2018 LARK UNITED...
