Front window for mini-x Polycarbonate or Acrylic?
   / Front window for mini-x Polycarbonate or Acrylic? #1
Rebeldad1
Hughett Bend Washington
Kioti Tractor, John Deere Mower,New Holland Mini Excavator
Need advice on what thickness would be needed for a front safety window on a mini-x
polycarbonate or acrylic roughly 24" wide by 30" tall.
[h=2]Thanks!![/h]
   / Front window for mini-x Polycarbonate or Acrylic? #2
Rebeldad,
I would recommend polycarbonate in this instance. Acrylic sheet is very brittle compared to polycarbonate and the window is all about safety. Now, the corona virus has used up the large majority of plexi (acrylic) and polycarbonate sheets all over the country so good luck finding yours. I'm thinking 3/16" or 1/4" thickness will suffice.
   / Front window for mini-x Polycarbonate or Acrylic? #3
polycarbonate nor acrylic, as stated acrylic is brittle and no good for impact, myself 1/2 inch would be my choice, made a windshield on my UTV and went with 1/2 inch, very solid and rigid, you could use a thinner but price wise if something hit it what are you comfortable with
   / Front window for mini-x Polycarbonate or Acrylic? #4
Are you adding something to a machine that doesn't have one, or replacing a damaged one?
You might want to look into tempered, laminated glass.
   / Front window for mini-x Polycarbonate or Acrylic? #5
The windshield on my BMW is polycarbonate. So far its only had to deflect bugs - does that very well.
have to make a add on to fit the mini-x
   / Front window for mini-x Polycarbonate or Acrylic? #7
I would do this^^^^
   / Front window for mini-x Polycarbonate or Acrylic? #8
I agree with you and Big Barn go with the glass,probably cheaper too.
   / Front window for mini-x Polycarbonate or Acrylic? #9
Also (arguably) better clarity and not prone to scratches.
   / Front window for mini-x Polycarbonate or Acrylic? #10
As long as it was designed to have glass installed in the beginning. It needs a method to hold the tempered glass and rubber seal and not touch anything that can damage glass edge.
2012 Big Tex 14ET-20BK 20ft T/A Flatbed Trailer (A55851)
2012 Big Tex...
2010 Club Car Precedent Electric Golf Cart (A55758)
2010 Club Car...
David Brown 380 Tractor W/Loader (RUNS)(Hydraulics Do Not Work) (A50775)
David Brown 380...
2018 DRAGON 150 BBL ALUMINUM VACUUM TRAILER (A53843)
2018 DRAGON 150...
Club Car Electric Cart (A55758)
Club Car Electric...
JOHN DEERE 560M LOT NUMBER 15 (A53084)
JOHN DEERE 560M...
