DK50SE stuck in low range
/ DK50SE stuck in low range #1
Oscarveg08
2013 Kioti DK50SEHC
Good evening everyone,
First timer here, I appreciate everyones response in advance!
I just purchased a 2013 DK50SEHC that was working fine for a couple of days until yesterday. For some reason I cant get out of low range. I can physically move the lever, and feel it click (which Im assuming is just the detents), but doesnt go into another range, nor neutral. Sometimes itll pop out of low while Im using it, then I throw it back in low and itll work in low again. It never goes into any of the other ranges no matter what I do.
When it did work, I could feel it grind just a little before the synchronizers caught. I would just hit the forward pedal a little to help synch to gears and decrease the grinding, and it would go in just fine. Now I dont feel any of that grind at all, feels real soft.
The shaft going into the transmission from the range lever is turning (roll pin isnt sheared).
Hydraulic fluid is full.
My assumption is that a fork broke, what do yall think? If so, whats the best way to get to it?
/ DK50SE stuck in low range #2
That's going to be a good one. Time to break out the shop manual! I know a few folks on here that should have one.
I do have the shop manual for the CK50, which I read is the same. Going to dive in this weekend, was hoping for some reassurance.
/ DK50SE stuck in low range #4
The technical term for the problem you have is "broken". You know and I know and yes, even yellow dog knows you are going to have to tear it apart to fix it. Your idea of a broken fork sounds about right to me, but you are not going to know until it is opened up and you can look and see what is broken.
Dang it. I know this is not exactly what you wanted to hear, but you know it is truth.
I made a typo in my last post, I meant EX50, this is what I have the shop manual for.
James,
Looks like I have a project this weekend. Any tips or advice?
/ DK50SE stuck in low range #6
James,
I wish I did. The only thing i can think of is when I disassemble something complex, I take a series of photo's. It actually helps to put things back together during those "oh crap" moments where you say "I wonder where that thing goes?"
/ DK50SE stuck in low range #7
i have done the same thing for years.... only real use i can find for a smart phone.
I’ll make sure to post some pictures here when I tear into it!
9DCD721C-1354-4EED-9C47-F50CF7D96F0A.jpegF76D91BE-3054-4F69-A600-3B41AF548BC8.jpeg0673EC18-B12B-48FB-B665-AFFECBED8E5A.jpegF7FF4AB0-CAE1-40B3-B292-88122A88BBEE.jpeg50F7914D-11F0-45AB-AA16-DC3B3AC24D98.jpeg357A4FD7-FE53-4669-A5F3-5B6E89EEFAB4.jpeg9832E768-9D9B-4231-B52D-8041A9D2CB9E.jpeg
Been meaning to post some progress pics, turned out to be the fork but it wasn’t snapped like I thought it was going to be, it was worn out??
/ DK50SE stuck in low range #11
So is that like some sort of galling on the surface of the fork?
/ DK50SE stuck in low range #12
I have a DK45SC that I bought new in 2010, that had (almost) the same problem! My symptoms were not with the "range", but with the "speeds", (mine is not the hydrostatic model).
My tractor was always difficult to put into 1st gear, it was just 'stiff'. I thought (hoped) it would free up with age, but just got worse, until eventually it would not go into 1st gear at all.
When I pulled the 'fork' cover off, I discovered the 1-2 fork completely worn out, exactly like yours. In order to replace the forks - (I decided to replace both) - you have to 'push' the fork rods out of their bores. I noticed it was much harder to remove the 1-2 fork rod, than the 3-4 rod. I figured the 1-2 rod must be bent, but in fact it ended up that one end of the rod was nearly .005 inch over sized. I chucked it up in my lathe and turned it down. After reassembling the tractor, shifting into 1st gear is now exactly the same as shifting into any of the other gears.
You have certainly taken your tractor much further apart than I had to! I was able to just pull the fork cover off with no other disassembly. Although the forks are cast iron, the syncronizers are apparently much harder, as I could not measure any wear in the syncronizer 'groove'. I dodged a bullet!!
It turned out to be an easy fix to what I had dreaded would be a very time consuming and difficult repair. I forget how much the forks cost, but it was not anywhere near as expensive as I feared (Kioti really has you over a barrel here; no competition) And, although they had to come all the way from Korea, it "only" took a couple of weeks.
Anyway, my main point here is to take heed of how hard it is to move the "fork rod" in its bore. The detent is a spring loaded ball which rides in a groove in the rod. It is designed to relieve the pressure between the fork, and the groove of the syncronizer (sliding gear). If the rod is so stiff in the bore that the detent cannot overcome the friction, then the fork and 'groove' will be wearing against each other the whole time you are in that particular gear.
I don't know your situation is the same as mine, but it does seem very similar.
Good Luck!
Yes, the only thing I can figure is the original owner would keep some pressure on the handle for some reason?? That or something binding up keeping pressure on it.
Kioti Paul,
Good find there! That’s some good advice, I hadn’t put much thought into the rod itself.
Thanks for taking the time to share your experience!
Unfortunately mine doesn’t have any covers to remove at all. I had to split the transmission in order to slide the fork out. With the amount of work involved to replace the fork, I’ll definitely look further into the culprit. I can tell the original owner had issues with it because he told me he had to replace the roll pin on the lever about 4 times. He kept snapping them which seemed odd to me, so obviously something wasn’t right.
I ordered my parts from michiganironandequip. Hopefully it doesn’t take too long with the pandemic!
/ DK50SE stuck in low range #15
Kioti Paul,
Please keep us apprised of your repair and what you find. I have not had any problems getting the transmission in gear on mine. Mine has 500 hours.
/ DK50SE stuck in low range #16
Kioti Paul,
Yes, I would have been in the same boat as you, had my problem been with the range shifter,,, no way to get to the forks without splitting the tractor and disassembly!! I definitely did 'dodge a bullet'! I feel for you!
/ DK50SE stuck in low range #17
Kioti Paul,
/ DK50SE stuck in low range #18
I see a lot of gears so I'm assuming this is a standard gear transmission.........
If I do find anything out of the ordinary I値l post it here for sure.
It痴 actually HST, the gears shown are low mid and high range. The single gear with a fork is for the mid pto (mine doesn稚 have a mid pto installed).
On a side note, the left brake case had a crack in it as well (upper left corner in the picture), seems like the brake rod got hung up and broke the case and cam plate. Have the parts on order too.
Just a few more pictures for fun.[/ATTACH]45AB9DFD-FB2E-4B43-8DF7-EA2F776BDD31.jpeg64B131CD-DB60-4C80-9A0D-AE354BE1C474.jpeg38E7C732-2145-4B45-A467-4AB0C95A91DB.jpeg
/ DK50SE stuck in low range #20
WOW I would bet a million that was a gear tractor, I thought I asked another stupid question. I like repair jobs so good luck I'll stay tuned and thanks for posting pictures.....
1997 Take 3 Auto Transport Trailer Trailer, VIN # 1C9TT5036VB409167 (A61165)
1997 Take 3 Auto...
2022 John Deere 317G Track Loader (A63109)
2022 John Deere...
2715SSFL (A61567)
2715SSFL (A61567)
2012 FREIGHTLINER 114SD ROLLOFF TRUCK (A59909)
2012 FREIGHTLINER...
Sundowner Rancher Express 20FT Livestock Trailer (A63118)
Sundowner Rancher...
DRILL CABINET SKID (A60736)
DRILL CABINET SKID...
