B2710 3pt. lift
/ B2710 3pt. lift #1
James Henry 01
Judah, Indiana - Mississippi Native
Kubota B2710
Hi Guys,
Hope today was a good day in Kubota land for all of you...
Well, I hope as well that this isn't the dumbest 3pt. question of the day. My 2710 is and has been great addition
to our way of life, should have gotten it years ago. I'm wondering about is this. When engaging my lift it doesn't begin
to actually lift until halfway through the movement of the control lever, doesn't matter which impliment or weight, nor
does it change when adjusting the control valve, is this normal or do I need to adjust or repair something?
It lifts and lowers fine, just figured that it would engage sooner. Something that I've always wanted to ask.
Thanks for your help....
jim
/ B2710 3pt. lift #6
When engaging hydraulic lift, Lower Links do not begin to actually lift until halfway through the movement of the control lever.
Is this normal?
My Kubota L3560 operates the same way.
/ B2710 3pt. lift
Thank you so much!!! I have wondered about it for a long time now, my grandson is going to do some food plots so
if it need some attention I thought I'd do it now before he got started...
Thanks again, take care...
jim
/ B2710 3pt. lift #10
/ B2710 3pt. lift
I sent the question to asktractormike.com, his reply...
mike@asktractormike.com via sendgrid.net
2:13 PM (8 hours ago)
to me
Jim,
Thanks for the nice comments…I’m not a Kubota expert, but on many tractors there is an adjustment for the linkage, usually really hard to get to. If you can follow the linkage under the operator area you might see. Good luck and thanks for watching!
Mike Wiles
“Tractor Mike”
Unused 2024 Land Pride PFL3048 48in. Forks and Frame Skid Steer Attachment (A66734)
Unused 2024 Land...
Kelly-Creswell Model C Walk Behind Paint Striper (A66734)
Kelly-Creswell...
2019 Ford Explorer AWD SUV (A66738)
2019 Ford Explorer...
Unused 2022 Hustler Lift Max LE110 SS Bale Forks and Frame Tractor Loader Attachment (A66734)
Unused 2022...
GENERAC MOBILE PRODUCTS MLT6S LIGHT PLANT (A67714)
GENERAC MOBILE...
2021 JOHN DEERE 410E SERIES II OFF ROAD DUMP TRUCK (A65053)
2021 JOHN DEERE...
