4310 temp sensor thread size?
/ 4310 temp sensor thread size? #1
TractorGuy
Elite Member
N. FL
John Deere 4410, John Deere 4120, Kubota LX3310 cab, John Deere F725 Front Mount Mower, Swisher 60" pull behind mower. John Deere 4310 CUT (sold), Ford New Holland 575E Cab Backhoe (sold).
Anybody know the thread size on the 4310 temperature sensor? I am looking into sticking a generic gauge on mine and they all come with a 1/8" NPT sensor. I want to figure out if I can find an adapter bushing.
Edit: May have found a solution. There is a plug under the sensor that is labeled M16 in the parts list that looks a little more accessible than the sensor itself. Should be able to find one of the commercially available oil pressure / temperature adapter kits with that size.
/ 4310 temp sensor thread size? #2
There are also 3 plugs P/N M810638, Key 8 in the drawing. No idea the thread size, if a better spot, pull one and determine thread size?
Thanks Zebrafive. I will look at those.
Trying to come up with something that doesn't look too hodgepodge. I found a nice two gauge pod that should attach on top of the cowl and not look to out of place. I need to add generic fuel and temp gauges since both are being affected by whatever is wrong in the cluster.
The other roadblock is the stock fuel sending unit is a 5-95 ohm unit that reads 95 at empty. All the generic gauges in that range are reversed and use the higher ohm reading at full. I guess having a gauge that reads backwards would be better than no gauge but it would be nice to have them both work as they should.
Those appear to be 1/2" NPT with a female allen. The one on top should work great for my use. Thanks again for pointing those out.
