Four wheel driver lawn mower thoughts
/ Four wheel driver lawn mower thoughts #21
Yeah Ken, I didn't hear a budget either.
I bought my JD2210 with 62" deck and 113hrs for $9,500.
If it won't climb it or plow thru it you shouldn't be mowing it. :)
/ Four wheel driver lawn mower thoughts #23
Thanks Moss.
Not sure this type of tractor would serve Ken. Or if he needs the machine to do multiple tasks. Or what the budget is. :)
/ Four wheel driver lawn mower thoughts #24
As was mentioned the front mount mowers from New Holland, Deere or Kubota with 4wd will do an excellent job.
I have a Kubota B2710 with 6 foot rear finishing mower I have use there a lot but was trying to find a mower that would be more convenient for storage and for cutting the rest of the lawn. I do appreciate each ones thoughts and recommendation.
Am interested in the more aggressive tires some have installed on their ztr's. Have looked at them on line this evening some but would appreciate recommendation on the thread type or tires they used and their opinion.
/ Four wheel driver lawn mower thoughts #26
I have a set of AT101s on my Grasshopper and it’s night and day difference. It went from getting stuck on a mole hill to pushing mud with the deck.
AT 101s make a world of difference on a ZT. Running wet hills is no problem with them and I can run in mud until the deck bogs. No mower is going to survive that without getting stuck either.
The AT 101 are like R 1 tractor tires, correct? Any issue with them on dry grass in turning? Thanks.
/ Four wheel driver lawn mower thoughts #28
They’re similar but smaller lugs. I find the damage to grass is less because they bite and go vs sliding around.
Richard, there is a used JD same model as yours near me for sale. Nice looking tractor design. No idea the hours and the mid mount mower should have had some work done before being placed for sale. $6,900. Mower lower looks like with it.
/ Four wheel driver lawn mower thoughts #32
They are good machines. Just about 70% the size of your 2710. I previously had a 2910. Loved that tractor. Lost it in my shop fire.
Following along to see what you end up with. :)
/ Four wheel driver lawn mower thoughts #34
I had those on my old garden tractor, they worked pretty good.
That sounds like a 3 or 4 star rating just like on Amazon, some say they run small and hard to put on and some say they wont stay on so I dont know if I want them or not. I do know a tire chain can be a pain.
/ Four wheel driver lawn mower thoughts #35
Yeh, I got them on amazon too, and I did give them a 4 star review.
I got them instead of regular chains because I got an asphalt drive, and that tractor was doing plowing duty in winter. Mine stayed on no problem, and I had them on year round. When I first put them on, I deflated the tire somewhat, got them on snug as I could, and then they were real snug when I reinflated the tire. The only downside is that the ride is pretty rough with them on when going on paved areas, but that's to be expected.
To kthompson, I think you could maybe do well with a garden tractor with locking differential, that feature made all the difference in the world to me. My house is on a hill and then the property slopes down into wetland which I do mow (when it's not flooded). And then there's the pond down there with muskrats tunneling into the banks. So yeh, very uneven ground, with lots of moisture in it.
This was my first tractor here:
I'd get stuck with it all the time before I got the terragrip chains. I wouldn't even risk mowing if my wife wasn't home, pretty regular I had to call her to come out and help me dig the sucker out lol. Getting the terragrips helped for sure but I'd still get stuck sometimes.
Now I mow with a new craftsman gt with locking differential, it's like night and day. I still occasionally get stuck (barely ever), but every time it happens now I have myself to blame. I see the ground is wet there, I know it's soggy, and then I still plow into it...and then I'm like no sh^1, sherlock! And then I go call my wife. :D
/ Four wheel driver lawn mower thoughts #36
Wish I knew about diff lock 4 years ago.
Taking it in two phases. Plan to install more aggressive tires on my ztr and today bought a self propelled push mower (seems odd to call a self propelled mower a push mower) to use in the tight areas. I know, not the direction anyone thought would decide upon. Twenty years ago would have just done that cutting with a string trimmer but have reached the point where that is not an option for any length of time.
Thank you for your thoughts and recommendation, each one helped. Oh, guy at the Mower Dealer suggested hiring a person to mow our yards.
/ Four wheel driver lawn mower thoughts #38
Can't beat the Steiner or Ventrac AWD system for tough place cutting. Lots used in the swamp of the run off ponds. With quad tires they just don't get stuck. The AWD system is hard to beat on them IMO. I have an older 420 with a 20hp Onan engine and the torque it provides is amazing.
You could consider just having another mower around for that function when needed. That's what i did. I have a Simplicity ZTR (2 of them) that i use for cutting grass on 4 acres here (wife's and mine) and we can cut it all in a couple hours together. And the Steiner is winter duty and loader duty. I have a 48" mower for it for the hills but I've found the Simplicity ZTR Citation XL with a 61" deck and ultra wide drive tires cuts the 20 degree high hill just fine. Probably due to the weight and wide tire traction. The lesser Simplicity ZT2500 I have can't hold a hill at all. Less weight and less tire traction.
Steve
Need some help on tires for my ZTR. The size is 24 x 12 - 12. Mower weighs about 1700 pounds per Ferris site. I find Carlisle has three models, one being the current turf tire, the second one is the one prefer but it's load capacity is 670 or so and the other is their AT101 which my tire guy strongly recommends against. He told me he has those tires on his side by side and is sure would damage my lawn. The AT 101 tread design is the only design with the load capacity I have found other than the turf tires.
/ Four wheel driver lawn mower thoughts #40
Kevin I added these to my zero turn. I can cut anywhere now. The only issue is you have to have a light touch on the steering, or they will shred your turf.
2015 Freightliner M2 106 AWD Altec DM478BTR Insulated Digger Derrick Truck (A60460)
2015 Freightliner...
2018 Sundowner FD-306 REV A 24ft. T/A Enclosed Gooseneck Trailer (A64194)
2018 Sundowner...
1997 Ford F-450 Dump Truck, VIN # 1FDLF47F6VEB26852 (A61165)
1997 Ford F-450...
2008 Genie AWP-30 Single Manlift (A61572)
2008 Genie AWP-30...
ATS Mini Excavator ATS - ME18 (A66285)
ATS Mini Excavator...
2024 Kubota SVL 75-3 (A64126)
2024 Kubota SVL...
