Disc Harrow Need a part
/ Need a part #1
JimR
Elite Member
Central Ma.
Kioti NX4510HST
Does anyone have a lower half support for a 7.5 foot disc harrow. One of mine is missing a piece. These are grease filled style with a rag like filler inside. There is no name on the harrow that I can find. Any help would be appreciated. A worse case scenario is that I could probably build this entire area back up with nickel welding rod. That is a lot of work. I found some letters and numbers on the other side of the support.
/ Need a part
If you can't find it elsewhere you might try Burgh Implement in Harmony, PA.
Thanks, I did find some letters and numbers on the other side. JB 100.I have no clue as to what that means.
Bush Hog 7' 3Pt Mower (A66408)
Bush Hog 7' 3Pt...
2010 Ford F-350 Crew Cab Diesel (A62679)
2010 Ford F-350...
2017 Ford F-250 4x4 Ext. Cab Pickup Truck (A64556)
2017 Ford F-250...
2016 PETERBILT 337 CAB AND CHASSIS (A65643)
2016 PETERBILT 337...
Pair of Rims (A65640)
3pt Hitch Receiver (A62679)
3pt Hitch Receiver...
