3-Point Hitch Do you know Brian Faulkner at Kioti - or his manager(s) ?
   / Do you know Brian Faulkner at Kioti - or his manager(s) ? #101
Erik glad to hear your up and running . One thing I would do ASAP before I attacked my work since your tractor has been so long there and away from its home is to check and " RE - TORQ MY LUG NUTS " on the rims front and back of course according to specs !!! ..................;)
Wouldn't that be the icing on the cake... Finally get the tractor home and the wheels fall off.
   / Do you know Brian Faulkner at Kioti - or his manager(s) ? #102
I'd worry more about fluid levels and any hydraulic fittings they touched.
   / Do you know Brian Faulkner at Kioti - or his manager(s) ? #103
Yep that would extra icing on the cake indeed :shocked: Years back co worker drop his Colorado pickup off for oil change and had winter tires put on at Chevy dealer where he brought it,he didn't get very far pickup came to quick stop,service tech never added the engine oil man ole man did the feathers fly. :eek:
   / Do you know Brian Faulkner at Kioti - or his manager(s) ? #104
Yep.... Course it wouldn't hurt to check other things. But I sure would check that hydraulic fluid for sure.
   / Do you know Brian Faulkner at Kioti - or his manager(s) ? #105
I don't know if I find it so horrible. Everyone seems to have had good reasons for what they did. Or if not good reasons, at least reasons that made sense to them at the time. It's certainly didn't go forward in a way that anyone would choose; how to avoid that is what I've learned from this thread. But the outcome seems OK.
There sure are a lot of of good lessons to be learned through Erik's experience.
rScotty
I think nearly TWO MONTHS is a "horror story"!
You, apparently do not?
   / Do you know Brian Faulkner at Kioti - or his manager(s) ? #106
I am going to take a wild guess here, and guess that the dealer in question, was not a 5-paw dealer?
Actually they are a 5-paw dealer. So much for the certification process.
   / Do you know Brian Faulkner at Kioti - or his manager(s) ? #107
No, I don't. I don't like the troubles everyone had, and the way Erik dealt with it is sure a lot different from what I would have done.... but the endng is as much a part of the story as the beginning and middle. The OP is satisfied, the bill seems fair, and we all learned a lot.
rScotty
   / Do you know Brian Faulkner at Kioti - or his manager(s) ? #108
Hope everything goin well for Erik and his family ? He has not posted here since 08/06/20 . Just like maybe some others wondered how the Kioti repair turned out ?
Should we send the TBN chopper lookin for him ? Or how bout a drone ? ...........Just wondered hope all well .
I taught I saw a drone.... all is well! Tractor and more importantly the 3 pt hitch with Woods Brush Bull BB720x is holding and NOT jumping! Yay. All is good in the world again. The dealer called me the day after they dropped it off to ask if it was working. A nice courtesy call but too little too late and I'm pretty sure they know it. Oh well
Yes, it runs, it was the MLS valve, once installed and 'tuned' it worked. I mowed my field for about an hour then did some other chores with Brush Bull still attached to test hydraulic holding. It held. I let the Brush Bull sit up about 12" off ground over night to see if it would hold and it did, no sagging down.
So, all is good for now. Thanks again everyone for following along & chiming in, I hope you learned something as I sure did. All fluids are good too, and tires are on tight.
thank you all very much !
Erik
   / Do you know Brian Faulkner at Kioti - or his manager(s) ? #110
What a tale. Nothing beats perseverance.
My experience with Chappell Tractor was excellent. It involved my Kubota but maybe they handle Kioti. If they don't, I'll bet the some of the guys there know which Kioti dealers are the good ones. Ask around.
2002 AMERITRAIL 32FT GOOSENECK TRAILER (A58214)
2002 AMERITRAIL...
Hercules Rustic Gun Cabinet Holds 40 Guns (A57454)
Hercules Rustic...
Electronic Towable Sign Board (A57454)
Electronic Towable...
SKIDDED FRAC TANK (A58214)
SKIDDED FRAC TANK...
1999 Kawasaki 1100 STX Jet Ski (A57453)
1999 Kawasaki 1100...
Metal American Flag (A57454)
Metal American...
