Generic diesel problem/question?
/ Generic diesel problem/question? #1
84Jeeper
Utah & So California
Yanmar 1500D 186D 1510D and B27
I have a Yanmar B27 excavator with a 3 cyl diesel engine. Well, I let it sit for several years and upon startup something is amiss. The throttle is not responding correctly. It will start (after a lot of cranking) and run smooth. But if I push the throttle all the way down to the stop position the motor does not immediately stop like it used to. It slowly idles down and eventually it usually does stop (initially it would not stop at all). When pulling the throttle to max the engine will initially gain a few rpms and then slowly the rpms will continue to increase to what seems like a normal level but when trying to use the hydraulics there is little power and the engine rpm will drop right down.
It seems like everything is just real sluggish to respond to the throttle with no power available. It also seems like the more it runs (maybe 30 mins total) the better it gets (small improvement so far). I suspect something is stuck and working it's way loose? Should I add some sort of injector cleaner to the fuel? I have no idea about diesel engines...
The mechanical linkage is fine.
I assume this behavior is not related to this particular model but a result of letting a diesel engine sit too long and something getting gummed up?
Please advise...
Thanks!
If it matters this is what the throttle linkage goes to....
/ Generic diesel problem/question? #2
I would say to change the fuel filter and add some #1 fuel oil to it, run it without working it, just varying the throttle untill she responds better.
Have you put fresh fuel in it or is it old fuel also.
/ Generic diesel problem/question? #3
On many diesels there is rack inside the side plate of the fuel pump. It or the linkage leading to it can get sticky or hung. Lube the linkage and check a parts breakdown to see if you have such a rack.
/ Generic diesel problem/question? #4
Yep, like Lou says it sounds like the old fuel got contaminated. Water or bacteria will do that & probably has. You probably have crud throughout that fuel system. But even if that isn't the problem, you still have to get clean new diesel running through that system for awhile before you can go any farther with the diagnosis.
BTW, the reason Lou says to use #1 fuel is that #1 is a slightly lighter diesel fuel with better ability to dissolve crud.
Most automotive diesel from the pump is #1 or even slightly better. So get some new fuel, put some cleaner/additive in with it. And clean EVERYTHING. That probably means draining the tank and the changing the filters too. Sometimes it takes several filter changes.
luck,
rScotty
It is the old fuel :(
Sounds like great advice. I will have to figure out where to get a filter for it but at least it's easy to get to!
...and thanks for the clarification about #1 diesel...my next question was going to be where do I get that? LOL
/ Generic diesel problem/question? #6
Buy several filters and plan to change them out frequently.
The old fuel is now only useful for starting fires in my opinion.
Add a fuel cleaner/lube to your clean fresh diesel. Best if it is one that protects against algae.
If you can remove the fuel tank, it will make cleaning somewhat easier.
For future reference, any time a diesel has set for an extended period (not a couple of months but a year or longer) try not to use the old fuel. Condensation causes water in the fuel and water leads to algae.
/ Generic diesel problem/question? #7
That filter housing in the picture looks like the universal one on our Yanmar tractors. The only alternatives are a long or short filter element and a replacement long filter bowl isn't expensive if you can't find the short filter.
Your local Tractor Supply, Autozone, or most likely NAPA will have the Yanmar filter element and its not expensive. If you are in the boondocks then Hoyetractor.com mailorder is the best source, they have everything.
I agree, you need fresh fuel to do the flushing.
I'm cheap, I would drain the existing fuel downstream from the existing filter, on the chance that it isn't the problem and might be re-used later, and so you can avoid the nuisance of getting rid of it. Then use a fresh filter element for the fresh fuel during the system flush project, then finally a second one when you put the machine back in service, and just check the second one after a while. Replace only if needed.
These new components are the common ones. I bought this filter assembly from a VN 'rebuilt' dealer and nobody had a replacement for this third style of ultra-short element.
61786d1159379481-ordered-yanmar-today-img_3186rfuelfilter2-jpg
/ Generic diesel problem/question? #8
"nobody had a replacement for this third style of ultra-short element."
I ran into same problem on my Mitsubishi.
Longer bowl would hit the flywheel bell housing and short one not to be found.
Problem was my bowl had shrunk and filters would not fit.
I modified by fitting a drain cock and simply dedicated it to be a water separator.
I drain the bowl from time to time via the drain cock thus ridding of water and accumulated crud that may be present.
Next I cut the fuel line past the bowl and inserted a paper type in line fuel filter which I simply replace annually.
6 years or so now and no problems.
The inline paper element takes care of any minor debris that gets by my 'separator' bowl.
/ Generic diesel problem/question? #9
#1 fuel oil is commonly called kerosene.
Update #1
Well I pulled the filter apart and it fell apart. See the pic. The donut looking stuff between the spring and the filter is gunk from the bottom of the bowl. The filter was a nice reuseable metal filter...before the bottom rotted off, as can be seen sitting to the right of the filter. You can of course see all the trash on the outside of the filter and what was on the inside of the bottom of the filter.
Drained the diesel....smelled like paint thinner.
Then noticed it had a second filter. I opened that and drained the fuel from it. I don't think it was doing much as it had a piece of screen that was larger than the first filter?
Primed everything up with new fuel and "magic" additives which are supposed to clean injectors etc...
After much cranking it almost wanted to run but not quite. It had been getting progressively harder to start during the day yesterday (and the engine was warm) even though it seemed to be running better once started.
So the battery gave up and I brought it in to charge. I'll wait till it gets warm tomorrow and give it another shot.
I'm hopeful that the fresh fuel and magic additives will hopefully soften up something overnight and it will run....that could be misplaced hope...
ps Autozone had no filter so I just added an inline one as suggested. :)
/ Generic diesel problem/question? #11
Does your excavator have a compression release, and a Thermostart intake manifold heater that works?
The farm tractors that were originally designed for running half submerged in rice paddies have a compression release. I've always thought that was to purge water out of the cylinders in case of a deep water mishap.:)
On those it saves the battery to spin it with compression released, then let the inertia of the spinning flywheel assist the starter after you let go of the release. Hopefully you can do likewise.
Also for your hard to start engine the Thermostart will likely help. Even better, warm the head with a hair dryer for a half hour. Make it think this is a warm restart.
That fuel filter is by far the nastiest one I've ever seen!
/ Generic diesel problem/question? #12
With the replacement/removal of fuel and filters, did you do a fuel bleed all the way to the injectors? If not when your battery is charged. Repeat all of your fuel bleed process including cracking open injectors. Any air in the fuel lines can and will give you dickens on starting.
/ Generic diesel problem/question? #13
Actually with your fuel filters in that condition,
I'd take the line off at the pump and flush it out and hope that none of that crap got into the pump.
Because if it did, it's time for a new pump.
Update #2
Well, sitting overnight didn't do the trick.
Decided to crack the lines at the injectors and make sure there was no air.
#1 Cylinder has fuel pumping to it
#2 No fuel
#3 Fuel
After much cranking it will start and run. It slowly builds up speed as 1 or 2 of the cylinders fire and eventually will start and run on it's own reaching a high rpm if the throttle is left in the high position.
I then decided to loosen the fuel lines while running.
#1 Fuel leaked at a pretty good rate no change in engine rpm
#2 No fuel
#3 Fuel sprayed at high pressure and engine immediately lost rpms
For grins I loosened #2 back at the injector pump (I guess that is what it is) and no fuel there either ... or at least very little like a couple of drops.
This appears to be a 3TN84L-RBS engine if that helps.
So looks like it may be running on just 1 cylinder?
I added more Diesel Kleen to the second filter and cranked the engine a bit to try and get a good concentration into the injector pump and plan to let it sit overnight in hopes it will degum whatever is in there.
All suggestions welcome! :)
This is a closeup pic of the injector pump (or whatever it should be called).20200804_155403.jpg
/ Generic diesel problem/question? #15
I would guess your a couple of your injector plungers are stuck from the long sit. Have you tried tapping around on the injector pump a little while it is running? Not with a sledge hammer! :D
/ Generic diesel problem/question? #17
A stuck plunger in your injector pump would not be a surprise. Make sure the ‘cleaner’ you ate using has a good diesel lucubration included in its additive package. As Winston says tap lightly on the pump. A rubber mallet is a good choice if not accustomed tapping on pumps.
It may be worth wild to pull #1 line from the pump to the injector to see if any debris may be in it.
#2 I suspect is the stuck plunger. The cleaner/lube and light tapping are the route to go. Unless you have the knowledge to work on those pumps, my advice is take it to an injection shop or try to hook up with ‘tgepumpguy’ on these forums and send to him.
#3 appears to be the cylinder that is firing as it should. With #1 being almost there but not quite from your description.
Good Luck!
/ Generic diesel problem/question? #18
not sure if this is helpful to you but i have what looks like a very similar engine in my FX24D tractor. The injector pump looks similar too. Im in the middle of a engine tear down but i was troubleshooting my injectors too and ended up flipping the injector lines 180 and fired up the tractor to see how the injectors were spraying in this post:
https://www.tractorbynet.com/forums/yanmar/427071-fx24d-not-running-post5765810.html#post5765810
After you resolve your fuel pump issue you probably want to clean out your injectors as well?
Update #3
SUCCESS!! Thanks to all!
So y'all were correct about the stuck plunger/s. I watched this video Yanmar 4jHE fuel injection pump cleaning - YouTube and it didn't really look to hard to take the top piece apart to attempt to clean things up...and since it wasn't working anyways I gave it a shot.
Despite the warnings of the last commentor on the video I took it apart and cleaned as best I could. In particular I had to "tap" plunger #2 to get it free (it definitely would not have come free tapping on the side of the IP). I was careful to reassemble and get the correct number of turns etc... (although I don't know if that matters) for the pieces and once I had bled the lines it fired right up! Actually, it fired up while I was bleeding the lines LOL.
Throttle seems to work like normal and it has all the power it ever did as best I can tell.
Again thanks to all for helping me get this running again!
2014 FORD F-350 SUPER DUTY (A65643)
2014 FORD F-350...
New/Unused Landhonor Hand Chain Lever Hoist (A65583)
New/Unused...
2018 FREIGHTLINER M2 FORESTRY UTILITY BUCKET TRUCK (A63276)
2018 FREIGHTLINER...
BOBCAT CT4058 TRACTOR (A62130)
BOBCAT CT4058...
FRESHLY REFURBISHED! 2016 KBH Fertilizer Tender Trailer - Isuzu Diesel (A63688)
FRESHLY...
New/Unused Wolverine 72in Tiller (A65583)
New/Unused...
