Liquid Filled Tire Pressure Gauge
/ Liquid Filled Tire Pressure Gauge #1
Richard
Super Member
Knoxville, TN
International 1066 Full sized JCB Loader/Backhoe and a John Deere 430 to mow with
My current gauge is dying. I've got some liquid filled gauges (like 0-2000 PSI) for when I measure pressure on my PTO or something.... got me thinking about getting a liquid filled for the air gauge.
In part, it strikes me a bit as over kill however, if I get a cheap one, they just feel soooooooooooooooooooooo flimsy.....
So anyone have any opinions on various brands/styles for a liquid filled tire gauge? For the first time ever, I just now looked them up and found 2-3 brands, none of which I know anything about and I'm sure all of which are made in China.
/ Liquid Filled Tire Pressure Gauge #2
Interesting idea. I would be curious on how you like it if you do decide to get one. I have also found the cheap ones to be flimsy but I guess they work good enough for what their job in life is.
What actually got me thinking about this is the gauge on my air compressor is cheap cheap cheap. Stopped working so had to replace it with a new, cheap cheap cheap on..... now that I have the oil filled gauges for reading PTO pressure or something.... it has me thinking on swapping everything over to that style. Might be mental but they just FEEL nicer.
/ Liquid Filled Tire Pressure Gauge #5
Wow that is expensive! Looks like good quality though.
I'm constantly filling tires on my flexwing mower. Rims probably need replaced. Front tire on riding mower... (again, probably needs replaced, both of them)
Interestingly, I'm pretty retentive about keeping GOOD tires on my car thankfully!!!
Has me debating merits on changing cheapo gauges on my air compressor too....only need to go up to 200 psi as I recall.
/ Liquid Filled Tire Pressure Gauge #8
Definitely a good idea on the compressor. If I bought one for checking tires I could never tell my Dad. He would say "Boy you've got more money than sense" :laughing:
As far as the tires always going down, get some of that John Deere goop and put in there. That is some of the best stuff I have ever seen. My tire on the Kioti were so weathered and cracked the were leaking in about 20 different areas. I put that stuff in and never added air for 3 years. When I finally replaced the tires, it just wiped off the rim with no signs of rust.
Don't know what that call it but it comes in a gallon jug with a hand pump. Just remove the valve stem core and pump a 8 OZ or so in and fill it up with air. I believe that stuff would seal off a 1/4 inch hole no problem.
/ Liquid Filled Tire Pressure Gauge #9
It is a JOHN DDEERE brand item? Or an item a JD dealer sells?
/ Liquid Filled Tire Pressure Gauge #10
I not sure what K5lwq is referring to but I have used a product called "Slime" on 4 wheeler tires with a punctures up to ½ inch. Slime can be bought at Walmart, O'Reilly's or any auto parts store for about $20.00. Put amount in as per instructions and drive tractor around for awhile to distribute to slime. Air in the tire forces the Slime into the cracks and or punctures to seal your tire.
/ Liquid Filled Tire Pressure Gauge #11
/ Liquid Filled Tire Pressure Gauge #12
The thing I wonder about air is HOW do you know when one is accurate? Measure it against one or a number of other gauges? Heck - they probably are all a little off. I really don't think there are any gauges, in a reasonable price range, that's dead on accurate.
What I have learned about air gauges is that you want one that covers the range you're shooting for, and a little more. A gauge that goes up to 2000 psi, even if its off only 1% or 2% is a lot of error if you're needing to set your pressure, say at 12psi, etc..
I have several suspect gauges in my shop. The one I reach for is always a digital gauge that is easy to use with one hand. When it starts reading crazy numbers it either gets a new coin-type battery, or it goes in the junk pile. The ones that I won't even wear out my shirt pocket with however, are those pencil type gauges that you can pick up for a buck. They're a waste, even if they were free.
Forget what it was, but I had (probably an old mower) that I bought from my brother in law.... finally needed tires on front. No big deal, I'll just buy some and do it here.... broke the bead and there was a bunch of Slime in there (the Green Slime). Also looked like it or something had molded a bit... was really kind of gross in appearance and then I had to wipe everything down to clean it up.
Wasn't a huge deal but my take on it is, it's more of a band-aid to hide an issue rather than to fix the issue. I'd rather just get a couple new rims for the flexwing, keep it clean and be done.
For me, it's not so much about the accuracy.... plodding around the farm here to cut a field, accuracy isn't that critical. I DO like keeping the tires in my backhoe/loader somewhat where they need to be because of the potential extra load on them when I put some dirt/rocks/other in the bucket....
It's really just the experience I've had with a handful of cheap gauges getting stiff, needle sticking.... and I now have three liquid filled gauges so I can do various pressure checks on my stuff.... and I got to wondering if that style (liquid filled) is even available for an air gauge..... low & behold, you can spend a freaking fortune on one. (I guess I can understand that in competitive racing....but I ain't racing!!)
A while back I was in the market for a digital tire gauge. I purchased one made by Longacre racing though Amazon and have been very pleased with it. I remembered that they had liquid filled gauges:
Longacre Liquid Filled Tire Pressure Gauges
That's the exact one I'm contemplating. I don't want just a checker.....I want to attach it to the air for when I'm using it.
/ Liquid Filled Tire Pressure Gauge #16
I deleted my post since I realized that you had already posted that gauge earlier. The digital gauge I got from them is made very well. I found out that you can spend as much as you want and more on a tire gauge.
Amazon.com: Longacre 5336 Tire Gauge: Automotive
And I just now ordered it....
So between last night and just now, I've ordered that air gauge that will attach to my compressor.....and last night, ordered two liquid filled gauages to replace those cheapies that are on the compressor.
/ Liquid Filled Tire Pressure Gauge #18
I recently bought a new tire gauge made in the USA Lifetime Warranty from family run business on Amazon called Rhino USA.
It is not liquid filled but it is very accurate for under $20.00
It is not flimsly, it has some weight to it!!
Amazon.com: Rhino USA Heavy Duty Tire Pressure Gauge (?-75 PSI) - Certified ANSI B4?.1 Accurate, Large 2 inch Easy Read Glow Dial, Premium Braided Hose, Solid Brass Hardware, Best for Any Car, Truck, Motorcycle: Automotive
It looks like a good quality gauge, and I might buy one. But don't be misled by their name. "our products are Designed, Engineered and Lab Tested in the USA but manufactured overseas by carefully selected firms that can build to our specific design specifications." Made in China. I wish they were a little more upfront about this in their advertising.
/ Liquid Filled Tire Pressure Gauge #19
I bought this one shown below from Harbor Freight. Best I've ever had. Good for liquid filled because of the hose downstream of the gauge. Can blow out the water between tests.
Ralph
/ Liquid Filled Tire Pressure Gauge #20
