What is the best tools for grading a field back to flat land
/ What is the best tools for grading a field back to flat land #1
JimR
Elite Member
Central Ma.
Kioti NX4510HST
i have about 6 acres of field that has been used for farm produce for many years. If you drive over this field East to West or vise versa it is smooth. If your travel North to South or vice versa it is like a washboard. We now want to make this field back into a nice easy to mow smooth field. What would be the easiest tools to use to make this project go along the fastest. The field is all weeds right now. It needs to be broken up.The edges of the planted areas all need to be lowered and graded to blend into the previous planted area. I already have a box blade, grader blade, rock root bucket and a landscape rake. The edges of the planting areas have really good sod that is going to need to be busted up to taper the edges of the field where it is slightly sunken down. Would it be better to rototill the entire area and then smooth it all out with a grader scraper? I could also have my friend till the entire field with his huge land plow setup and then I could smooth it out using ????? I have been reading about the grader scrapers and think that may be the best tool to flatten the ground back out. Would the grader scraper be the best tool to use to smooth out an area like this? Would rototilling the field be better than running a land plow all over it. I could also use my box blade to rip the entire field. Hopefully somebody has already dealt with this issue and can give me some advice.
/ What is the best tools for grading a field back to flat land #2
I would mow the field to get the weeds as low as possible. I would recommend spray with weed killer or burn but don't know your conditions there. Have the neighbor til the entire field. Then a Land Plane Grading Scraper with scarifiers. Scarifiers set at their lowest setting - leveling blades, at least, inch and a half lower than the side skids. I have an 8' LPGS and it is a very easy "pull" behind my Kubota. It would be a piece of cake in a field already tilled.
The scarifiers will help bust up the clods and the following blades will level and smooth it out. Just keep going around until all the clods are broken down and the land is as level/smooth as you want.
Thanks for the advice.That was my thought also and probably the fastest way to get the job done.
/ What is the best tools for grading a field back to flat land #4
Having access to a land plane would be nice. If not I've done several mowing close then just a disc pulling a 12 foot drag. Any areas needing bigger leveling was done with a box blade. And then follow-up with the disc and drag. Did several soccer fields as a free community service and they are still in use with no additional work needed on them over the years.
I've also used a box blade with a drag that is wider pulled behind for leveling. You'll still see contractors with a disc and an I beam drag doing the final leveling.
/ What is the best tools for grading a field back to flat land #5
I have 6 acres of field that has been used for farm produce for many years.
If I drive over this field East to West it is smooth.
If I travel North to South it is like a washboard.
Disc Harrows are traditional field smoothing implements. The goal in harrowing is a smooth, level bed behind the implement.
A week after you spray, mow as short as possible: "scalp."
Few with Disc Harrows adjust them after putting them to use. If you first process the field two or three times (depending on the weight bearing on each of your disc pans) to loosen ridges, then adjust gang angles less aggressively in increments, the disc may meet your smoothing needs solo.
Shorter Top Link = more weight on front gangs.
More weight on front disc gangs throws dirt OUT. Use on ridges.
Longer Top Link = more weight on rear gangs.
More weight on rear/wider disc gangs gathers dirt IN. Straddle the swales.
The faster you disc the more dirt is moved.
As the field is smoothed, adjust hydraulic Position Control so disc is in lighter contact with the soil.
Your last past should be a moderate speed, pans sunk 2" to 3" in soil, front gang adjusted moderately, rear gang adjusted less aggressively than front gang, but not "straight", weight distribution about equal between front and rear.
MORE: https://www.tractorbynet.com/forums...ing-three-point-hitch-mounted.html?highlight=
/ What is the best tools for grading a field back to flat land #6
Get the friend to till it up and break it down and then pull a beam (wood, iron, whatever ) that’s hooked up at an angle across in various directions till you are happy. Finish off with your landscape rake.
/ What is the best tools for grading a field back to flat land #7
Moisture content of the soil will dictate the results as much as implement choice,,
I have a VERY heavy land plane,, but, if you try to pull it when the soil is dry, you might as well scrape concrete with a soup spoon,,
So, around here,, time of year is as important as implement,, spring being the best,, after the soil warms up, but, is still damp.
Summer will work too,, but, you have to "catch" the right time of soil moisture,,
AND, remember, if the soil is too wet, there will be more ruts AFTER leveling,, than before!! :eek:
/ What is the best tools for grading a field back to flat land #8
Central MA has a lot of different soil types (my street has completely different soil from the next street over) but if it was previously used for crops it shouldn't be horrible to work with.
If more sandy, then darn near anything will work. If heavier with more clay, then judging moisture might take some trying and retrying until it has hit a "sweet spot" that works well with your tools.
I think your current game plan is solid, just don't be afraid to let it dry out and/or wait for rain as you work it to see what works better for you. A week or two's wait one way or the other might save you some frustration, but the best way to know is to just get on it and start playing.
Don't feel constrained to work "square" with the edges or the current furrows, your best bet might be to work it at angles to everything already there, and especially to your previous pass over an area. Also, working in "half passes" rather than trying to smooth everything in the first pass can help.
/ What is the best tools for grading a field back to flat land #9
With a land plane you still should either till or disc the ground before using. Chances are you will still be using a drag for the final finish if you want great results.
/ What is the best tools for grading a field back to flat land #10
A lot of what you need to do the job and what you end up with will depend upon soil type and moisture content. You CAN do the entire job with a LPGS & scarifiers - if it does not need to be re-contoured. It will be a whole lot easier if the ground is tilled first. A rototiller can be used - but for six acres that will take a lot of time.
However, any LPGS WILL NOT move material from here to there. It's designed to flatten/smooth. Your box blade WILL move material. The entire project will go a lot easier if the ground is tilled first. Till - contour with the box blade - smooth with the LPGS.
Six acres is not going to be a "quickie" project. Take your time and do it right. Once you are finished - it will be "that way" until you have other plans.
This field is pretty loose and easy to work except where the grass is growing. There is lots of info here and on the links posted, THANKS. I like the idea of using a harrow. I may have access to one of those. I think it has two rows of pans on it. I hate to have to buy a grader scraper to use for this one job. I guess if I did I could just sell it afterwards.
Our land is of the better kind compared to someone I know less than a half mile away with ledge all over their property. Previously I did rip up a small section maybe 300 x 100 using my box blade rippers to tear up the ground. Then I used my landscape rake to level it off. I was able to get it fairly smooth but it was a lot of work due to the weeds. I guess the first thing to do is get the weeds taken care of. I did mow them down as low as I could before I started doing this area. I can wait until Fall when the weeds die out too. I agree that working in both directions and angles will help greatly. I see a lot of tractor time coming up.
/ What is the best tools for grading a field back to flat land #13
I also have a home made drag that works well. I pull it with my ATV. I predrilled hole for the big spikes. View attachment 664947
/ What is the best tools for grading a field back to flat land #14
If you lived in flood irrigation territory, the old long landplanes are cheap as the leveling companies have shifted to laser-controlled scrapers.
High bid: $585
West Auctions - Auction: Tractors, Farm Equipment and Implements in Northern California ITEM: 14'x6' Marvin Landplane
Bruce
/ What is the best tools for grading a field back to flat land #16
Before the long steel land planes became common, almost every large farm had a wooden one.
Bruce
I found a 9 - 10 foot double disk harrow with a hydraulic piston and wheels for decent money this morning. I talked with the owner who does farming. He told me that my 45HP Kioti with HST was too small to pull this harrow. We got to talking and he said he has bogged down his 70HP tractor using this harrow. He now has a much bigger one that he pulls with a 135hp tractor. He said a 6 or 7 foot would be the biggest that I probably could pull as long as I wasn't going too deep with the disks. He suggested using a rototiller on the fields or have if plowed. After that to go over it with a disk harrow of grader planer. I can always drag a section of chain link fence over it afterwards if it still needs more leveling. I have plenty of fence and poles. After looking at disc harrows for sale I remembered that my FIL had one back in the 70's that he parked in the woods out behind the barn at the farm. I had forgotten all about this. Sure enough it was still sitting out there in the thicket. I dug it out and it still spins and the levers and adjustments on it still work. One of the rock pans needs replacing. The discs are of the smooth type and it is only a single harrow.
Bruce
But that is not lawn quality grading. That sure does get the job done fast in a huge field. Lots of rocks on that property.
/ What is the best tools for grading a field back to flat land #19
Someone may have mentioned using a box blade with a pair of gauge wheels on the back. These are sometimes referred to as soil movers or speed movers and are, in my opinion, the single best tool for your task at hand. There are 3PH models available as well as pull type.
The principle is that the wheels are following the blade thereby tending to produce a continuously flat surface. Some means of adjustability of the wheels vertically is necessary to provide for cutting action when needed and smoothing action when needed. The box blade is capable of doing both quite well.
Working an area for leveling can be accomplished by traveling in different directions to smooth the highs and lows.
Having ripper teeth on the box blade is a definite plus when working in untilled hard soil conditions.
My box blade has rippers but no wheels.
2018 22ft. Tycorp Vector Belt VB-16H (A60352)
2018 22ft. Tycorp...
2022 Case CX220E Hydraulic Excavator (A61567)
2022 Case CX220E...
2011 INTERNATIONAL DURASTAR 4X2 26FT BOX TRUCK (NON CDL) (A59908)
2011 INTERNATIONAL...
VOLVO EC460CL EXCAVATOR (A58214)
VOLVO EC460CL...
2006 John Deere 250D 25 Ton Articulated Dump Truck (A61567)
2006 John Deere...
2020 CATERPILLAR D6 LGP HIGH TRACK CRAWLER DOZER (A62129)
2020 CATERPILLAR...
