LS Tractor Oil, Gas, & Air Filter Information
   / LS Tractor Oil, Gas, & Air Filter Information #331
Is there a post with oils and filters used on the newer MT240HE/MT235HE?
I tried multiple searches and nothing came back.
   / LS Tractor Oil, Gas, & Air Filter Information #332
Assuming that many of the LS tractors likely use the same filters, it would be helpful if the original filter's numbers were listed with the aftermarket replacement. ie:
TRACTOR MODEL NUMBER - YEAR
OIL FILTER
[factory part number] - [replacement brand - replacement part number] plus notes as needed like size, fit, etc.
etc.. If that exists here, please point me to it.
   / LS Tractor Oil, Gas, & Air Filter Information #334
Originally Posted by Underdog57
2013 LS R4041H Engine - S4QL Mitsubishi Tier 3
Oil filter / OEM # 40006977 / NAPA # 1334 / WIX # 51334 / Bosch # 3310
Fuel filter / OEM # 40006997 / NAPA # 3128 / WIX # 33128
Hydraulic Filter / OEM # 40007638 / NAPA # 1715 / WIX # 51715
Hydro Transmission Filter / OEM # 40007563 / NAPA # 1551 / WIX # 51551
Inner Air Filter / OEM # 40049447 / NAPA # 2985 / WIX # 42985
Outer Air Filter / OEM # 40007575 / NAPA # 6438 / WIX # 46438
Update: The NAPA Oil filter #1064 & Wix Oil filter #5106453 would not fit my tractor. The correct oil filter for my 4041 is NAPA # 1334 or Wix # 51334 or Bosch # 3310.
These should be the Corrected numbers above ^
Maybe these will help?
   / LS Tractor Oil, Gas, & Air Filter Information #336
2019/2020 MT240HE
These are off the Invoice for the spare filters I requested from my dealer at purchase. Only the OEM is what I can verify, I'll leave the cross referenced numbers posted from above.
Oil filter / OEM # 40409065
Fuel filter / OEM # 40271228
These are what is printed on my air filters,
Inner Air Filter / OEM # Donaldson P822769
Outer Air Filter / OEM # Donaldson P822768
   / LS Tractor Oil, Gas, & Air Filter Information #337
Thanks for adding a few more data points. Interesting that my oil filter is OEM # 40318591.
I just found this: "GENUINE LS ENGINE OIL FILTER P/N 40409065(your number) REPLACES #40318591(my number)"
My OEM #s for both hydraulic filters agree with yours.
I went to the Wix website and looked up the LS MT240HE. They list the E and the HE model, but the site responds, "Sorry, but there are no filters for this vehicle in our records."
   / LS Tractor Oil, Gas, & Air Filter Information #338
A friend of mine just went to look at a new LS. The dealer told him that he had to run LS filters on it or it would void the warranty on it. The friend that he took with him was a guy that works as a sales rep for one of the bigger companies. His statement was "That was a law suit waiting to happen". I think this has already been solved in federal court. The only way to require this is for them to provide the filters. If anyone knows anything else, I would like to see it. The LS dealer is a good guy, but I think he is wrong on this.
   / LS Tractor Oil, Gas, & Air Filter Information #339
I
I believe you are correct.
The OEM oil filter costs $17 and figured it gave me a good excuse to visit my dealer. He is a good guy and has helped me out a lot. After the first oil change at 50 hrs, the manual says every 250 hrs. I change oil/filter every 100-150 hrs. Saving less than $10 dollars every 100 hours is not a priority for me.
   / LS Tractor Oil, Gas, & Air Filter Information #340
I searched but couldn’t find info for a XU 6168, does any one have the filter info for this tractor?
Year: 2017 Make: Ford Model: Explorer Vehicle Type: Multipurpose Vehicle (MPV) Mileage: Plate: Body (A56859)
Year: 2017 Make...
WINCH CABLE DRUM (A58214)
WINCH CABLE DRUM...
LOT: Torch Cart w/Gages, Hose, Torch Head (TANKS NOT INCLUDED) (A59076)
LOT: Torch Cart...
60in Skid Steer Hydraulic Adjustable Forks (New/Unused) (A59225)
60in Skid Steer...
CATERPILLAR HM315C QUICK ATTACH HYD MULCHING HEAD (A54757)
CATERPILLAR HM315C...
Eagle Weathervane (A55853)
Eagle Weathervane...
