LS Tractor Oil, Gas, & Air Filter Information
   / LS Tractor Oil, Gas, & Air Filter Information #81
I have a s3010 and after 50 years of work I retired. Looking to cut cost some. I need to find good but cheaper filters to keep my tractor in good cond. **** good traotor and serves me well Can anyone help?
   / LS Tractor Oil, Gas, & Air Filter Information #82
Have 2013 xr4046 with cab,looking for filter numbers for this unite.its the suburu or how ever you spell it tier 4 engine. Thanks
   / LS Tractor Oil, Gas, & Air Filter Information #83
Ok. So found some numbers but need wix or napa numbers for my oil which is 40283380. And also for my fuel which is 40283326, got these numbers from dealer but need to some how cross them. Thanks
   / LS Tractor Oil, Gas, & Air Filter Information #84
If I am not mistaken which I have been known to be :eek: that is a Douglas filter number or at least the ones I got off of my first replacement filters were, and the Napa store had cross references for Douglas.
   / LS Tractor Oil, Gas, & Air Filter Information #85
   / LS Tractor Oil, Gas, & Air Filter Information #86
I might have missed it but has anyone come up with filter numbers for the R3039? I think the attached picture are the correct NAPA numbers for oil and air.
   / LS Tractor Oil, Gas, & Air Filter Information #87
Originally Posted by Underdog57
2013 LS R4041H Engine - S4QL Mitsubishi Tier 3
Oil filter / OEM # 40006977 / NAPA # 1334 / WIX # 51334 / Bosch # 3310
Fuel filter / OEM # 40006997 / NAPA # 3128 / WIX # 33128
Hydraulic Filter / OEM # 40007638 / NAPA # 1715 / WIX # 51715
Hydro Transmission Filter / OEM # 40007563 / NAPA # 1551 / WIX # 51551
Inner Air Filter / OEM # 40049447 / NAPA # 2985 / WIX # 42985
Outer Air Filter / OEM # 40007575 / NAPA # 6438 / WIX # 46438
Update: The NAPA Oil filter #1064 & Wix Oil filter #5106453 would not fit my tractor. The correct oil filter for my 4041 is NAPA # 1334 or Wix # 51334 or Bosch # 3310.
These should be the Corrected numbers above ^
   / LS Tractor Oil, Gas, & Air Filter Information #88
Rocknrod Showing you rate! (CMC nickel) (CMC also ret in 2004). I have a 2010 LS 3010 and the oil filter is a A0653039 / GT251010 D-07. I still have the box from the replacement the dealer gave me for the first oil change. The numbers on the first filter were covered in paint. I've used the Fram PH3593A. Fram also lists the PH7317.
   / LS Tractor Oil, Gas, & Air Filter Information #89
I've been perusing this thread and failed to notice which Wix oil filter my 4047H takes. Anyone know off the top of their head? It's not listed on the Wix webpage. Thanks in advance.
   / LS Tractor Oil, Gas, & Air Filter Information #90
It takes the same filter as the R4041 which is listed below. Same motor.
1991 MACK CH613 DUMP TRUCK (A58214)
1991 MACK CH613...
New/Unused IRGC40 Mini Golf Cart (A57453)
New/Unused IRGC40...
26ft x 42ft Double Garage All Metal Building (New/Unused) (A59225)
26ft x 42ft Double...
SHOP FAN WELDING CART (3) JACK STANDS (A54757)
SHOP FAN WELDING...
HELI 5K FORKLIFT (A58216)
HELI 5K FORKLIFT...
3 PT SCRAPE BLADE (A58374)
3 PT SCRAPE BLADE...
