sloch24
My 3 point just recently started screwing up (more than usual).
Since I've owned the tractor (2016) when I raise it all the way up the motor would labor, so I would have to move the lever down a bit to get it to stop.
The other day, the 3 point started dropping all by itself. It was very annoying dragging my box scraper while trying to move stone with the bucket.
Upon further inspection, I noticed that when I move the rock shaft lever, the 3 point doesn't move at all until it hits a point about 3/4" back. At that time, it acts as a "all the way up" lever. The 3 point then lifts all the way up and the engine labors until I move it down slightly.
At this time, moving the lever down slightly seems to hold the level steady until it doesn't. I can't trust it to stay up, and while I'm running the tractor the 3 point gradually lowers until I'm dragging it.
With the 3 point fully raised, if I move the rock shaft lever down just slightly past the "neutral" position, the implement lowers all the way to the ground.
Basically what I have now is an all raised or all lowered situation.
I pulled the seat and am looking at tearing apart the left side rear fender to take the cover off the valve and check for debris in the valve such as screen material that may have blown past the inline filter (I haven't pulled that line yet, but that will be the first thing I do).
Any thoughts? Am I on the right path? Does it sound like something is caught in the valve, or am I barking up the wrong tree?
Any help is greatly appreciated!
