Sizing a 3rd Function Valve for Flow
/ Sizing a 3rd Function Valve for Flow #1
kb12610
Member
TYM 233
Looking to ad a 3rd function remote. I have two pumps, steering at 2.6 gpm and main at 5.0 gpm. Yes that is what I have. total of 7.6 combined. Equal to about two chipmunks and a crippled squirrel.
Surplus has a valve listed that is 6.6 gpm for 59.00, only downside I see is the ports are #4.
Would it be better to go with something with more flow rate or would this be ok for a 3rd.
/ Sizing a 3rd Function Valve for Flow #2
It'll be on the main circuit not the steering one, which is separate. So it only needs to be large enough for 5 gpm.
Any thoughts on the #4 port size?
/ Sizing a 3rd Function Valve for Flow #4
It can be rated at 6.6GPM but at what pressure drop or loss?
The #4 is too small. Look up a hydraulic nomograph chart on google, very easy to use. Like this one
https://www.google.com/amp/s/www.es...t that valve off the chart at your flow rate.
/ Sizing a 3rd Function Valve for Flow #5
Won't matter for a third function that is used for intermittent use like operating a cylinder.
/ Sizing a 3rd Function Valve for Flow #6
But is it in an open center hydraulic system?
And where is the 3rd function in the circuit?
/ Sizing a 3rd Function Valve for Flow #7
Are the in and out #4 also or just the work ports? If just the work ports it well ok. Put a link to the valve you are looking at.
/ Sizing a 3rd Function Valve for Flow #8
I think the valve the OP is looking at is a "diverter" valve, not a true 3rd function solenoid valve (this is where links to the products your asking about helps). Since your only "diverting" the dump/curl circuit, I think it's fine. I would not put a small valve like that in the the main flow from the pump.
/ Sizing a 3rd Function Valve for Flow #9
But if it's a true "3rd function", then it has all of the pumps flow going through it all the time so it needs to be sized properly.
Sorry should have provided more information. Yes, this is just a selector or diverter valve. After some of the questions I realized I was assuming that my system had larger lines to begin with than what it has. My lines and cylinders are already #4.
This valve was attractive for a couple of reasons
1. The compact size
2. Built in tapped ports
3. $
I'm going to try insert a couple links to the valve and the manufacturers specs.
6.6 GPM 12 Volt DC Double Selector Valve DFE:D | Selector Valves | Hydraulic Valves | Hydraulics | www.surpluscenter.com
may have to copy and paste?
http://www.walvoil.com/allegati/catalogo/DFE080-D1WWEG01-US.pdf
Maybe someone more apt can fix it
https://www.google.com/amp/s/www.es... me is about 1800RPM. Thanks for your input.
Links posted
Open center and after the control valve to split the curl.
Link posted
International MaxxForce 6-Cylinder Turbo Diesel Engine with Transmission (A59228)
International...
2025 Kivel 48in Forks and Frame Skid Steer Attachment (A61567)
2025 Kivel 48in...
Caterpillar 2PD5000 5,000LB Diesel Forklift (A56857)
Caterpillar...
429824 (A61166)
429824 (A61166)
2019 CHEVROLET SILVERADO CREW CAB TRUCK (A63276)
2019 CHEVROLET...
2012 Kia Optima Sedan (A61569)
2012 Kia Optima...
