Hi my name is Hammick and I'm an over-greaser
/ Hi my name is Hammick and I'm an over-greaser #51
Going back to greasing...
I typically grease until I see a bit of grease coming out. I dont worry about it after that. I have too many other things to worry about. The extra grease sits there, getting dirty, falling off, or getting wiped off by brush or trees... not exactly wiped... more like smeared.
That is until I wash the tractor. I use a pressure washer that pumps cold water, which does nothing to the grease other than spread it around. Then, I simply move on.
I do clean the zerk before greasing though. Dont want to push that crap through the zerk into the joint. Use Tub-o-Towels to clean out the recessed zerk.
/ Hi my name is Hammick and I'm an over-greaser #52
I just grease it till I see it coming out and leave the extra grease , Then it falls off in the driveway I step on it and track it everywhere.........:rolleyes:
Me too! I tracked moly grease onto our front walkway. What a nightmare. Wife is super happy with me too...
/ Hi my name is Hammick and I'm an over-greaser #53
My 40 year old Hotsy with only 1,000 psi, does a great job removing grease.......because the water is HOT water at 1,000 psi.
/ Hi my name is Hammick and I'm an over-greaser #54
Agree with wiping off fitting before attaching coupler. Have bunch of grease guns. Mostly use pneumatic with hose TSC moly grease with lock n lube. Pneumatic with hose red TSC premium red. Find these greases don’t leak out the guns during hot weather.
Then pneumatic with metal line for some fittings I can’t reach. Some manual ones setup for specific equipment. Some of of my EA wicked grapple pins are not compatible with the lock and lube coupler. Wheel bearings synthetic grease. Don’t need roadside repairs.
/ Hi my name is Hammick and I'm an over-greaser #55
I clean the zerk before greasing, pump until I see a little bit come out and wipe off the globs if any.
As for the LNL, great idea, just purchased one a couple weeks ago, unfortunately it is too large in diameter to fit in the recessed backhoe pins. I contacted LNL, response felt like "ehh, you're the only one that has complained". Everybody that has ran into this issue should contact them. It shouldn't be too difficult to make a slightly smaller diameter coupler.
As for why the LNL is superior (or the idea of it) IT latches on to the zerk and allows 2 hands to work the grease gun and many times after applying grease the coupler doesn't want to release and you can't always reach the barrel to loosen it.
/ Hi my name is Hammick and I'm an over-greaser #56
LnL actually DOES advertise that they sell a smaller diameter ADAPTER.
/ Hi my name is Hammick and I'm an over-greaser #57
I've got the lnl, it fits everything on my massey gc1710. The only hard part to reach is the zerks on the ssqa handles on the loader, I have to curl the bucket a certain way to get to them.
Actually I had something new happen yesterday, I was hitting all the zerks til I got to the pivot over there between dipper and boom, I couldn't pump anything into it. Tried pushing a nail against the ball in the zerk and it did move, but still was taking no grease. I was about to replace the zerk, but then tried moving the dipper up and down a few times and presto it took grease. Not for sure what was going on there, but I'm thinking the seals were holding so tight that it wouldn't let any grease slip past them (to allow for new grease to enter the cavity) until I moved the dipper and broke the seal.
/ Hi my name is Hammick and I'm an over-greaser #58
The Pin was just pressed up against the port or hole from the zerk and had no where to go, once you moved the dipper, it created a little gap for the grease. Happens often.
/ Hi my name is Hammick and I'm an over-greaser #59
Every 10 hours of tractor/loader run-time or so:
1) carry a rag as you go and wipe each zerk before you grease.
2) pump until you see some movement or old grease starting to push out
3) never clean your tractor, it doesn't mind being greasy. You can just wipe off any high contact areas as needed. If you have huge globs falling onto the ground, you pumped too much lol.
/ Hi my name is Hammick and I'm an over-greaser #60
Bear, maybe you're right, never happened to me before though.
Kubota BX25D (A53317)
JLG 3246ES ELECTRIC SCISSOR LIFT (A59823)
JLG 3246ES...
Sweeper attachment (A61567)
Sweeper attachment...
2022 CATERPILLAR 299D3 SKID STEER (A62129)
2022 CATERPILLAR...
24in pin on tooth excavator bucket (A61307)
24in pin on tooth...
2014 Mercedes-Benz C250 Sedan (A61569)
2014 Mercedes-Benz...
