L5740 front axle o-ring pushed out while greasing
/ L5740 front axle o-ring pushed out while greasing #1
cstamm81
Gold Member
Leesport, PA
Kubota L5740, Mahindra 3016HST, Kubota F2880
I was greasing my new to me 5740 before a long day of earth moving. While greasing the 2 front axle zerks, I noticed half of an o ring protruding between the front axle case and the axle holder. In the drawing below, the part is 070.
I'm assuming the o ring is there simply to hold the grease in the bushing in front of it. I most likely over-greased it, causing my own issue. Has anyone torn into the front axle? In the drawing, it doesn't look like too bad of a job, but I have not inspected the physical machine to see what else has to be disassembled. Also, if I were to keep greasing it regularly, how critical is it to replace the o ring?
/ L5740 front axle o-ring pushed out while greasing #2
You're supposed to remove the plug before greasing to prevent pressureizing the void.
Covered in the Owner's Manual.
SDT
/ L5740 front axle o-ring pushed out while greasing #3
If it were a bucket pin, I'd say let it go. But it supports the front axle and any movement other than oscillation may damage the front drive. The O ring is keeping grease in, but more importantly, dirt and water out. I would replace it on a new or newish machine. Gonna look at mine now...
Literally just read that... a day late and a few dollars short. I have the operators manual, but nothing else. Besides the workshop manual, anything else I should get? I can look at the parts breakdown on Messicks, so parts should be covered.
I agree with you, I'm going to order the o ring and put new bushings in while I'm at it. This is what I get for not following greasing instructions...
/ L5740 front axle o-ring pushed out while greasing #6
It shouldn't need new bushings unless it has significant time on it or has not been properly serviced.
FWIW: The function of the O-ring is to keep dirt out rather than grease in.
SDT
SDT
Thanks for the clarification. I won't do any mud bogging in the meantime, and I'll keep an eye on the area for dirt buildup. Would you recommend I order any other parts in that assembly while I have everything apart? I obviously won't know if there are any other issues until I tear into it. That said, to me, I'd want to replace any wear parts while I'm at it, as they don't cost much.
/ L5740 front axle o-ring pushed out while greasing #8
Wondering why the front carrier bracket needs a breather plug but the one behind the axle does not? The rear one is larger, but otherwise they are similar.
I wondered the same thing when I looked at the assembly closely. Also, none of my other tractors have ever had this breather. It definitely tells you to pull the breather in the book though, and I can tell you what happens if you don't! I'll be greasing the rear zerk very gingerly as well. I hate having to do repairs due to my own stupidity.
/ L5740 front axle o-ring pushed out while greasing #10
I was going to say that to, been wondering why no rear vent plug myself for years, I just give a quick pump in both around 50 hr or so if I use the tractor a lot, especial on uneven ground.
Ratchet Straps (A61569)
Ratchet Straps...
2023 VOLVO VNL760 6X4 T/A  SLEEPER TRUCK TRACTOR (A59908)
2023 VOLVO VNL760...
35in AIM Tooth Excavator Bucket (A60352)
35in AIM Tooth...
2014 LOAD KING BELLY DUMP TRAILER (A58214)
2014 LOAD KING...
2010 Chevrolet Tahoe 4x4 SUV (A61569)
2010 Chevrolet...
2014 Bolens 11A-020W765 20in Push Mower (A60352)
2014 Bolens...
