Building Lake Corona
/ Building Lake Corona #381
Sure... and some don't have that resource. No argument that there are always better ways to do things. Now let's tune back to the lake build.
The argument wasn’t what equipment anyone has. The argument was a tractor moves dirt better than a CTL. I don’t even have one, I wish I did but a CTL makes a tractor look like a joke doing dirt work.
/ Building Lake Corona #382
Roger that! I would love to have a small CTL from the little exposure I have had seeing them work. Do they come with a rear PTO? If not, are they sort of one trick ponies?
/ Building Lake Corona #383
There’s no rear attachments for them. They’re construction equipment not maintenance equipment or farm equipment but they’re far from a one trick pony. The loaders on these vs a tractor is really no comparison. Their arms are almost indestructible, they’re much more controllable and they have way more hydraulic flow.
/ Building Lake Corona #384
I sure do like reading the OPs posts regarding his pond build!
:D
/ Building Lake Corona #385
Nah no rear PTO, but they have enough hydraulic flow to run numerous hydraulic attachments off the front loader. post-hole diggers, brush mowers like Jk has, etc
You cant really see behind you well at all, so you wouldn't want to run any rear attachments anyway.
The TV450 CTL is 90 hp, 11,000+ lbs with weights. I also have a 62 hp Kubota L6060 tractor. If I'm moving dirt, brush cutting, doing grapple work, or almost anything else that requires a front end loader I'm on the CTL. Mowing & road maintenance I'm on the tractor. Until a few years ago when my business finally took off and I stopped putting all of my profits back into it I couldn't afford a CTL. Everything prior to owning a CTL was done with the tractor. There is no comparison between the tractor and CTL when it comes to moving dirt or digging. It's what they were designed for. The tractor is painfully slow compared to the CTL. There's a reason the only pic of the tractor in this thread was pulling out my stuck CTL. About the only time I could see an advantage to the tractor would be moving dirt over a long distance with a fairly smooth road. With that said if I could only own one machine it would be the tractor for versatility, but I can tell you this pond wouldn't have been dug with it.
/ Building Lake Corona #387
Exactly what I have been getting at. When I rented the CTL, I quit hauling the dirt to where I was spreading it. Just too long to go there and back, time wise. Instead, I dug down into the soft pond bottom with the CTL, where my tractor's front tires would sink in when picking up a bucket load of damp dirt.
Then, I piled it up right close to the pond with the CTL and kept digging with the CTL, as it was rented. Later, I moved that pile of spoils with my tractor. The CTL and a tractor complimented each other here. One machine did better than the other at two different tasks. But either was never the wrong machine. Maybe a less efficient machine. When it comes to efficiently (profits), one machine sometimes just won't cut it. Then you bring in more machines and or help.
True, I could never dig your pond with my tractor loader backhoe because of all those trees.
hugs, Brandi
/ Building Lake Corona #388
I can totally understand not wasting time driving 300 feet one way with a rental machine. I can also understand not doing the same thing with a machine you owned to save track wear. But as far as time savings you’re not. A big CTL with a 2 speed will move dirt 300 feet faster than the tractor. The bigger bucket is the main reason. Another fact you’re not looking at is the CTL is capable of scooping a heaping bucket of packed dirt. The tractor not so much. You’re wasting more digging and piling up dirt to move again. But like I said earlier they’re neither one good for going that far. That’s like comparing a ratchet vs adjustable wrench for hammering.
/ Building Lake Corona #392
Yea me too, and I can tend to be a drifter as well, so I will forgive another drifter......
/ Building Lake Corona #393
Not really especially when there’s a lot of dirt to be moved. A truck and excavator is as good as it gets when it comes to moving dirt. The only thing better is a bigger truck and excavator. And a tractor doesn’t hold a candle to a CTL for moving dirt. Even a good size utility tractor would have a hard go against a baby 6500 pounds CTL. Get one of the big ones that’s 11-12000 pounds and 100 hp and it’s game over for the tractor.
The best machine is a conveyor for moving dirt.
/ Building Lake Corona #395
Back to the pond please. Or the fireworks, the op's bang/pop business is pretty darn cool.
Sitting around waiting for dark this evening. Have a small show tonight for a local festival about 30 miles from home.
Here's one of my favorite pics from one of our shows last year. This was from the roof of Sporting KC after their mls soccer game. The larger display shells were shot further back from the Kansas Speedway. Hopefully next week we'll be back to pond pics and done arguing about how to move dirt.
2020-07-10_09-05-09
/ Building Lake Corona #398
Very cool. I can only imagine the thought that needs to go into this when just starting out. Looks like it's second nature to you at this point.
/ Building Lake Corona #399
2020-07-10_09-05-09
Hey OP... keep it on the pond build. :laughing:
2019 International LT625 Sleeper 48" (A62613)
2019 International...
2009 Kershaw 75-G2 Sky Trim (A61166)
2009 Kershaw 75-G2...
2014 International WorkStar 7300 4x4 Altec AA55E 55ft. Material Handling Bucket Truck (A60460)
2014 International...
New/Unused Wolverine Quick Attach Auger (A61166)
New/Unused...
2016 Chevrolet Colorado Ext. Cab Pickup Truck (A61568)
2016 Chevrolet...
2006 Generac SD0150 187kVA T/A Towable Diesel Generator (A61567)
2006 Generac...
