JD 790 Rear Weights Question
/ JD 790 Rear Weights Question #1
FarmKids
John Deere 790
Do I need to install wheel disk part M138917 prior to putting rear weights on my John Deere 790 or can I just attach them to the rim of the tire?
Thanks!!!
/ JD 790 Rear Weights Question #2
Here is a pic of the M138917..
Do you see a reason to use it if you already have a rim (key #9)?
Do you have the 60# weights that match up to bolt holes in your rim?
I am going to order the weights and the hardware tomorrow. I just wanted to make sure I didn't need to order the discs, too. I am glad I don't because they are expensive.
