Good morning!!!!
   / Good morning!!!! #115,072
RS, we just scatter mealworms on our open porch, letting some go under a raised bourbon barrel flower planter because the Carolina wrens love to hunt in tight places...if the lizards and skinks leave them any. I occasionally put some out for the bluebirds, but they seem less interested in them, with so many insects to catch that are fresh.
Billy,
Thanks for the insights - that may be what we're seeing here: just too many other insects available for them to be all that interested in the mealworms.
I did notice yesterday after the thunderstorms came through and it cooled off there was all kinds of feeding activity by a variety of birds. Barn swallows in particular seemed to be having a field day.
Hope Coco continues on the mend ... and that the skunk was just "passing through" ... :D
   / Good morning!!!! #115,073
rs, you're on a roll.
Interesting mealworm feeder.
All credit to Steve Gilbertson, it's his design:
Bluebird nestbox plans
How far away from the home do you put your bird feeders/nest boxes?
Backyard feeders are about 60' from the house, except for the suet feeders which are hanging on the house itself. Mealworm feeder probably 400' to 500' away from house.
Bluebird nest boxes are anywhere from 60' to probably 500' or 600' away from the house. In order of increasing distance they are currently occupied by:
Nest box 1 - wrens
Nest box 2 - wrens
Nest box 3 - house sparrows
Nest box 4 - bluebirds
The newest one I just finished (Gilwood Slot) may be put up near the house ... or it might go even further out ... haven't decided yet.
No decision made on where I'll put up the Northern Flicker nest box ... but it will probably be somewhere fairly close to the house.
Same deal with the barn owl nest boxes ... except that they will not be close to the house (supposedly the chicks can be pretty noisy, while they're screaming to be fed ... :laughing:)
RNG has his lizards doing tricks for mealworms. Next, he'll teach 'em to roll over.
:laughing:
   / Good morning!!!! #115,074
RNG, don't run that pto too long with no water in pump...tank to pump valve must be open first, sounds like you need some labels...I would...lot of levers
and knobs. Was engineer for one year in fire company, really had to think twice about order of what to pull and turn next.
I personally think it's wonderful you have your own fire truck. Hail to the Chief!
Exactly, Drew. Everything is labeled, but now I need to sit down with the operator's manual and put together step-by-step instruction sheets, laminate them, and keep them in the cab of the truck.
Sooner rather than later.
   / Good morning!!!! #115,075
68°F and .23 inches rain.
Followup appointment at ophthalmologist this morning. Errands in town as well.
Prayers for all
Be safe
Have a great day
   / Good morning!!!! #115,077
The key thing is to make sure the suction valve, connecting tank to the pump, is opened before engaging the PTO drive. Then control outlet pressure with engine rpm.
Does your truck have foam capabilities? Foam is useful sometimes .. but you have to flush entire system, with fresh water, after using it.
   / Good morning!!!! #115,078
That reminds me of something at work years ago.
A diesel generator plant with turbos had an air intake system with automatic Louvers that opened. Except when they first tested the system they didn’t open fast enough, and all the air intake ductwork was sucked in and destroyed.
   / Good morning!!!! #115,080
Something got into my back trash can where we dump the cat litter cleanup. Tore hole thru the plastic bag and made a mess. Never had anything get into it before. Now I’m wondering if maybe a squirrel did it.
Went to pull up video to check, and my analog recorder stopped recording 2 weeks ago. It has a 500 GB external hard drive to record to. Dvr says drive is empty. Huumm.
Dogs, foxes and coyotes will go after cat poop, it’s a favorite treat.
Forklift Safety Basket Attachment (A53421)
Forklift Safety...
2017 Ford F-450 Crew Cab Mason Dump Truck (A53422)
2017 Ford F-450...
2006 Toyota Tundra 4X4 Pickup Truck (A53422)
2006 Toyota Tundra...
(APPROX. 20) 4' X...
LIKE NEW 2023 Rhino 84in Reverse Rotation Rotary Tiller (A57024)
LIKE NEW 2023...
