Ford 1715 Oil issues
   / Ford 1715 Oil issues #1
BrentD
Dad started our Ford 1715 up a couple of days ago, and did something it's never done before. It started blowing oil out the breather tub that connects to the top of the valve cover on top of the engine. Not just a little bit. The oil was streaming out. I checked the oil today and it's almost to the top of the dipstick, way beyond the "full" mark. It also looks very thin and smells strongly of diesel. So I'm guessing fuel is somehow making it into the crankcase while the tractor is sitting. Any ideas what might be wrong?
   / Ford 1715 Oil issues #2
Lower o-rings on the injector pump delivery valve(s) have failed. Time for an injection pump overhaul.
Any idea where to find an overhaul kit for the injector pump? I can't seem to find one online. Looks like it uses a Shibaura J843 engine.
   / Ford 1715 Oil issues #4
We have a local shop which works on the big diesel trucks. I had them rebuild the injectors on my Mitsubishi tractor. The said they could rebuild the pump, too. You may not find a kit specifically for your injector pump but check in with a local diesel shop.
   / Ford 1715 Oil issues #5
You need a kit plus a test stand to measure fuel delivery and the knowhow to get it done. Messing with delivery valves on an in-line pump is generally not considered to be a DIY project.
   / Ford 1715 Oil issues #7
Noticed oil level 1/2” above top mark recently. Could that be same cause? Looking for thinness and smell.
2010 Ford Fusion Sedan (A53424)
2010 Ford Fusion...
2015 Honda Accord Sedan (A53424)
2015 Honda Accord...
202481 (A54757)
202481 (A54757)
2025 JOHN DEERE Z325E LOT NUMBER 84 (A53084)
2025 JOHN DEERE...
1996 Timpte 46ft Hopper (A55302)
1996 Timpte 46ft...
2016 Ford Explorer AWD SUV (A55758)
2016 Ford Explorer...
