Ford 1715 Oil issues
   / Ford 1715 Oil issues #1
BrentD
Dad started our Ford 1715 up a couple of days ago, and did something it's never done before. It started blowing oil out the breather tub that connects to the top of the valve cover on top of the engine. Not just a little bit. The oil was streaming out. I checked the oil today and it's almost to the top of the dipstick, way beyond the "full" mark. It also looks very thin and smells strongly of diesel. So I'm guessing fuel is somehow making it into the crankcase while the tractor is sitting. Any ideas what might be wrong?
   / Ford 1715 Oil issues #2
Lower o-rings on the injector pump delivery valve(s) have failed. Time for an injection pump overhaul.
Any idea where to find an overhaul kit for the injector pump? I can't seem to find one online. Looks like it uses a Shibaura J843 engine.
   / Ford 1715 Oil issues #4
We have a local shop which works on the big diesel trucks. I had them rebuild the injectors on my Mitsubishi tractor. The said they could rebuild the pump, too. You may not find a kit specifically for your injector pump but check in with a local diesel shop.
   / Ford 1715 Oil issues #5
You need a kit plus a test stand to measure fuel delivery and the knowhow to get it done. Messing with delivery valves on an in-line pump is generally not considered to be a DIY project.
   / Ford 1715 Oil issues #7
Noticed oil level 1/2” above top mark recently. Could that be same cause? Looking for thinness and smell.
2016 Godwin CD150M 6in Dri-Prime Pump S/A Trailer (A54811)
2016 Godwin CD150M...
2009 Ford F750 Reel Loader Truck (A52377)
2009 Ford F750...
24008 (A53422)
24008 (A53422)
2021 Kubota SVL75-2 Track Loader (A55314)
2021 Kubota...
2008 DOOSAN G25 GENERATOR (A52472)
2008 DOOSAN G25...
2009 Honda Pilot AWD SUV (A53424)
2009 Honda Pilot...
