L48 alternator/glow plug issue?
/ L48 alternator/glow plug issue? #1
Jason280
Ga
Kubota L4330
I have an '03 Kubota L48 backhoe, with relatively low hours (728). For roughly the last year, I've had this intermittent dead battery/no crank issue. I pulled the alternator a few months ago, and had it tested at a starter/alternator shop. The shop said the alternator was fine, but the issue has continued. You can charge the battery, and everything will be fine. Crazy thing is, its completely unpredictable. Sometimes I can be outside running it for a couple hours, and it will crank fine...then suddenly, no crank (dead battery). Battery has been tested, and its not the issue. Coincidentally, I've noticed the glow plug "light" will some on intermittently as well, and sometimes stay on while the tractor is running.
Tractor runs like a top otherwise, and has never given us any other issues...its just this odd crank/battery issue. I've checked the terminals with the meter a couple times, and only getting 12.2-12.3v. It was doing this when I had it tested at the alternator shop, so I am curious if there is some sort of relay that "tells" the alternator to kick in/increase voltage to normal 13.7-14ish volts while turning. I did a little research on the glow plug light, and it seems like it is either the glow plug relay or controller....but I am not sure how its causing the no crank scenario (unless its simply killing the battery while running). That would sort of make sense, as I don't think there is any other 12v draw on this tractor (other than maybe lights, which are never used). Still doesn't explain, though, why I'm not getting 13+ volts with the tractor running.
The more I think about it, the more I am convinced the glow plugs are continuing to pull current with the tractor cranked, and it subsequently killing the battery...but I still can't figure out why I'm getting 12.2-12.3v with the alternator turning.
Suggestions?
/ L48 alternator/glow plug issue? #2
Check positive battery connector, some have a spade terminal that feeds some fuse holders by the battery for glow and other high current circuits. Sometimes holding the key on start and having someone move the connector helps. May also have a stuck glow relay if the light is on, and the alternator may need battery connection to excite if you have a bad connection.
/ L48 alternator/glow plug issue? #3
Check and clean all your connections really well as David suggested. Your system was not designed for continuous (or even intermittent) glow plug operation. They create more load than your alternator can supply. If they are coming on that problem needs to be addressed.
I'm going to try troubleshooting it a bit in the morning, and will likely start by trying to disconnect the glow plug relay....see if that changes anything.
/ L48 alternator/glow plug issue? #5
Trying to learn here... Just how much current does each glow plug consume and how much does the alternator put out on the L48's?
If the GP's are on all the time, what are the chances they are still good?
I'd do a voltage drop test along the circuits in question. If uncertain how to perform, there are many youtube videos showing how.
/ L48 alternator/glow plug issue? #6
I had a similar problem with m M4700.
Battery seemed to work fine most of the time, it would charge up and fire.... sometimes.
Took the battery to NAPA, they tested it 3 times, third time it failed. New battery, all has been fine for years and many many starts.
/ L48 alternator/glow plug issue? #7
A typical GP has a resistance of 1 ohm. Usual electrical formula of Current equals voltage divided by resistance.
Assume 12 volts + or - and a resistance of 1 ohm means each GP draws 10-12 amps.
If the glow plugs are staying on, you run the risk of the ceramic failing and ending up inside the cylinder where it will do serious damage.
Dave M7040
Its all making more sense now. I believe the glow plugs are staying on, and overwhelming the alternator....which would explain the low voltage. First thing will be to disconnect the plugs, and try and rule out either the glow plug controller or the relay itself.
Should I go ahead and pull the glow plugs and check them, just to make sure there is no damage? I *think* they are likely fine, as the tractor has no trouble with cold starts (as long as the battery is charged).
/ L48 alternator/glow plug issue? #9
Remove the GP relay, charge the battery, measure the battery voltage while the engine is running.
If it is low then the GP's are not involved and you may need a battery and perhaps an alternator.
I am not convinced the GP's are staying on a draining the battery.
Dave M7040
/ L48 alternator/glow plug issue? #10
Dave7040,
Is the glow plug current draw constant or does it change as the GP heats up? I was under the impression it would pull 10-12 amps, but that it would drop off as the element heats up due to the resistance increasing. I've looked for graphs of the current over time, but haven't found any.
I'm with you in thinking GP remaining on is not the problem.
Troubleshooting time.
I checked the battery with everything off, normal 12.7v. After some flashlight and Google searching, found the location of the glow plug controller & relay.
Pulled both, and cranked the tractor....no dash light, and 14v to the battery.
Now, I have to figure out whether it's the relay or controller....except I have no idea how to troubleshoot either.
/ L48 alternator/glow plug issue? #12
Dave7040,
moship
There is not a simple answer to your question regarding glow plug current draw over on time.
Designs are continually being improved to shorten warm up time and thus reduce emissions. Some are now designed to stay on after the engine starts to improve combustion and lower emissions until the engine is warm.
In the early days of diesel VW's, to make the engine start up without a pre heat time for the GP's, i.e. to make it operate like a gas engine, VW designers triggered the GP's on as soon as the drivers door handle was touched on the outside of the car. In this way, by the time the driver sat down, the glow plugs were hot.
The article I have attached in a photo describes a newer design which incorporates both a current regulating coil and a heating coil.
Dave M7040
/ L48 alternator/glow plug issue? #13
Had a similar intermittent glow plug light and occasional run-down battery on my L48. If working right, the controller is supposed to ramp glow plug current down automatically with time and temperature, but mine sometimes did not. Plugging in a new controller cured it.
New/Unused ATS Grass Proof Cloth (A65583)
New/Unused ATS...
2018 Ford F-150 Crew Cab Pickup Truck (A64556)
2018 Ford F-150...
HD Bale Ring w/ Hay Saver (A66408)
HD Bale Ring w/...
Cattle Feeder (A65640)
2015 FORD F-350 SUPER DUTY (A63569)
2015 FORD F-350...
2021 DITCH WITCH HX30 TOWABLE VACUUM TRAILER (A63276)
2021 DITCH WITCH...
