Poulan Chainsaw not starting
/ Poulan Chainsaw not starting #1
Pixguy
Super Star Member
By the lake in NH & FL
2011 MF 2410 TLB
I have a 4yo 50cc Poulan Pro that I couldn't start last year so I used a smaller one for the few limbs I had to trim. Today I had a downed tree due to high winds and tried to start the Poulan again and had no luck. The saw has maybe 10hrs on it.
The plug appears clean and gapped correctly, air filter was only slightly dirty, carb was clean and I replaced the gas with fresh gas and still not turning over.
I will have to test the plug for spark and maybe replace the gas filter and gas line.
Any other suggestions?
/ Poulan Chainsaw not starting #2
if the plug was clean, and not wet from gasoline, the cylinder is not getting gas, it's possible you have bad fuel hoses, or a clogged carburetor. have you tried putting a small amount of gas in the carb, and tried starting it?..
/ Poulan Chainsaw not starting #3
Get a battery one. They're great. No starting problems. No fuel mix or storage problems.
Unless you do commercial work, I don't see why anyone is still using a motor driven chain saw.
Ralph
/ Poulan Chainsaw not starting #4
If you left non ethanol gas in it the carb is probably shot. You can get a carb for it for not much on EBay or Amazon. The only way I could keep my small chainsaws running is to drain the tanks after use and let them idle until they die. I only use non ethanol gas with stabil.
/ Poulan Chainsaw not starting #6
Same problem with my pullin’ & pullin’ & pullin chainsaw. I drain the tank after every use, pump the bulb numerous times and put the choke on and pull it numerous times to get as much of the gas out of the carb. Some times it works other times it doesnt. My remedy was to drill a small hole in the cover over the air cleaner and with a straw give it a shot of ether. Starts every time.
/ Poulan Chainsaw not starting #7
As others have suggested, give it a shot of starting fluid (a small shot!) right into the carb and give it a pull. If it pops, you know your spark plug is good. Then you can concentrate on a fuel issue. If it doesn't pop on starting fluid, it's most likely a spark issue.
It's a simple test and takes just a minute. Good luck.
Update here, I found no spark at the plug so my neighbor who knows some replaced the coil saying, yup that's what it was. Still won't fire up. Brought it the local repair shop and he says Nope, Poulan is a $100 saw, throw it away and start again.
Really?
/ Poulan Chainsaw not starting #9
Really?
true, but you can try replacing the fuel hoses, they do dry out and crack, 4 years is about right for that, usually, repair shops don't charge more than 50% of the new price for a repair, it's not worth it!.. add the price of say a new carburetor to the shop repair charge, and sometimes it's not worth it!.. fuel hose replacements are not expensive though, maybe $5 a foot for the hose, if you can find someone to do it for free, else add a shop charge to that!..
/ Poulan Chainsaw not starting #10
Really?
After you replaced the coil, did you try using some starting fluid sprayed into the carb with the air cleaner removed to see if it pops?
/ Poulan Chainsaw not starting #11
If you now have spark and compression, the starting fluid should pop. Fuel lines (and filter) are the next probable issue, although 4 years are not much. I had to replace the lines on my Poulan and it's not an expensive or particularly difficult job. However, mine was almost 20 years old when it needed it.
/ Poulan Chainsaw not starting #12
As someone who just went through all of that with my 14 year old Craftsman (Poulan) saw, don't bother. Sure the carb is only $15 and the gasket kit is only $8.95 and on and on till you spend waaaaayy too much trying to fix it when you can get one from DirectTools.com for $99.
Steve got a $63 14" Ryobi 37cc instead. (and wasted other money on useless parts)
/ Poulan Chainsaw not starting #13
Really?
Really.............:laughing:
/ Poulan Chainsaw not starting #15
A few years ago my father in law bought a Poulan at Lowes. They got it running and he took it home and used it once. Next time it wouldn't start. He took it back and the guy at the store got it started. He used it once and the next time he needed it, no start. Asked me what to do and I told him to get his money back and get a Stihl. He took it back to the store, got his money back, and gave $20-30 more for a little Stihl. He makes sure he uses non ethanol gas and it starts every single time on the second or third pull.
My advice is to junk the Poulan, chalk it off as a lesson learned, and buy a Stihl from a shop that works on what they sell. Ten years from now you will be money ahead.
RSKY
/ Poulan Chainsaw not starting #16
Any saw marketed by a company that specializes in vacuum cleaners has to be top shelf.....:laughing:
/ Poulan Chainsaw not starting #17
There are several small equipment repair shops in town...in every one there is more Stihl brand saws, trimmers, blowers etc. in for repairs than about any other brand...
Before replacing the coil on any piece of equipment...it's prudent to check the kill switch leads etc. for shorts that will prevent a spark...
To check a coil remove the plug and hold the wire in a hand and hold it against the head...slowly pull the cord or spin the crank...if the coil is working you will feel it...
/ Poulan Chainsaw not starting #18
and wake up a while later about 10 feet away from where you were standing :)
/ Poulan Chainsaw not starting #19
Nice to know your opinion on Husqvarna products. Sarcasm intended.
/ Poulan Chainsaw not starting #20
**** vacuum won't start again...!
2012 UTILITY VS2RA 53X102 REFRIGERATED TRAILER (A59914)
2012 UTILITY VS2RA...
2021 Big Tex 14ET 18' Tandem Axle Trailer (A62679)
2021 Big Tex 14ET...
2005 Ford F-650 Rollback (A62613)
2005 Ford F-650...
Caterpillar C18 Industrial Diesel Engine - Serial N8F01120 - Power Unit - Pump Takeout (A63689)
Caterpillar C18...
2014 International WorkStar 7300 4x4 Altec AA55E 55ft. Material Handling Bucket Truck (A60460)
2014 International...
Cat 312 Excavator (A62679)
Cat 312 Excavator...
