Auger won't drill hard clay
   / Auger won't drill hard clay #21
The answer is of course a hydraulic post driver. Don't matter what is down there, the post goes in and no backfill or Quick Crete needed either. Of course, compared to a PHD the price is a lot more but there is no issue with insertion.
   / Auger won't drill hard clay #22
Thats a great suggestion imo , even though for some it might not be affordable or cost efficient . I just always wondered though about the damage to a t post or wooden post when they hit good solid rock .
Post Hole Driver Shaver Saver Demo - YouTube
Totally spot on also ! :thumbsup: I used as good as 3 point PHD 's made except the homemade one's made from rear ends and what I can't stand is the constant turning around body and neck twisting that goes with it setting it up even with the ground marked to drill the holes .
BTW here's a pic of TBN member"s "MouseField"s home made rear end unit .
I don't think that's so much as home made as a modified Rears "Hole Hog". My brother has two of them, they're not very common especially outside of this area (made in Eugene Oregon), pretty sure they were made in the 60's to early 70's, the casting on the one we used says the rear end was a Chrysler 8.something. There's some giveaways, the U frame with the ball mount to the top link, the original loop for the bottom links, and the diff looks modified the same...
I don't have any input of the original problem, we drilled 14 2' diameter holes 4 feet deep with the ol hole hog and the only hole we had problems with had lumber in it... the clay we were digging was saturated good enough to plug up the auger quick at times.
The first set of holes I dug about a month ago went great - the 9" auger sank fast and it was wonderful. Unfortunately the ground has dried enough that even two feet down there's no moisture and a new 6" auger goes nowhere.
I hung 340# off the back of it and the added downforce didn't help.
Buying a hydraulic unit for the front or a hydraulic pounder I'm sure would work, but fortunately I only need about 20 more holes this summer so a purchase wouldn't be reasonable economically.
Best I'm finding is to start the hole with the 6", use a digging bar to break things up, and go manual from there with the occasional auger attempt. Next batch of holes, I'm going to try starting with the auger and then soak the holes for a few days and see if that helps at all, and see if maybe I can find a long 1/2" auger at a yard sale to help get the water into that layer better.
Thanks for all the suggestions! download_20200622_124431.jpegimage-20200612_150916~2.jpeg
   / Auger won't drill hard clay #25
Pengo carbide frost teeth are useless in clay, ask me how I know... The ones I had were at thick & as sharp as my thumb. Doing stupid thing for a couple hundred lbs of down force did nothing. Finally got a cheap farm store 6" auger & drilled pilot holes fine. Enlarged them with the 9" Pengo. Finally wised up & replaced the teeth with relatively thin dirt teeth & it worked fine. A cheap auger with thin sharp teeth will outdig a better quality auger with not sharp teeth.
I still have the 9" Pengo with a 2" round drive even though I now have a hydraulic SSQA PHD that takes 2" hex now. It's a beefy auger way stronger than the farm store ones. I sold off the cheap 2" round farm store augers with the PTO PHD. May get a round to hex adapter if I can't sell it for what its worth.
My QH mods gave me down pressure from the hydraulic toplink for a little over a foot. Not in the photo is a 200lbs chunk of steel mounted right over the gearbox held on with that handle. Both of those helped out a lot, but I upgraded to a hydraulic SSQA PHD when I upgraded to the new tractor. Not a massive increase but its an improvement in usability if not digging power.IMG_20141109_134834.jpgIMG_20150328_151018-1.jpg
   / Auger won't drill hard clay #26
Way back in message #@, RJ suggested throwing some gravel into the hole. I wonder if anyone ever tried that trick and how it worked? It sounded good to me, because it seems like some hard sharp fractured gravel might help to tear up the clay. We don't have clay here - except for a few cherished little pockets of mostly sticky blue clay. So I don't know much except to use the right tip angle, lots of pressure, and very, very slow rotation.
If the gravel trick doesn't work, I'd agree with others to take a close look at the post hole drill bit for the angle that the tip and the cutting edge makes with the hard clay. Like any drillbit, if sharp but held at the wrong angle all they can do is skate.
When carbide won't cut clay even with lots of pressure and dead slow rotation, then what else could it be except the cutting angle?
rScotty
   / Auger won't drill hard clay #27
rScotty
rScotty
Have you ever tried (even with a very good carbide concrete bit) to drill 40+ year old brick or block or concrete pad with a regular drill? (Not the mortar but the actual brick or concrete preferably a smooth sided brick or smooth for comparison)
Since you have no experience with clay, that is the best reference I can suggest.
Even a cheap hammer drill may not get it done! (Been there done that also). Even putting your body weight against some those well cured concrete pads/walls just doesn’t get it done with that regular drill. The downforce suggestions are like getting a low end hammer drill—if you keep at, change bits and do burn the drill up from frustrations (ask me how I know!) you can eventually get it done.
I wish I knew the answer for using the mechanical PHD for that hole. The solution for the concrete drilling is a true hammer drill usually getting into SDS style bits (a couple of different ones available). Once you use one of these drills (capable of just a hammer function for chisels and other bits) you will never want a regular drill for concrete again!
   / Auger won't drill hard clay #28
^^^ Reminds me of trying to get my gate posts into my many years compacted red rock gravel. Neighbor came over with his 4020 and large PHD. Got no where. Not even a couple of inches. I ended up buying an air chisel and punching in a few inches at a time, then lifting the spoils out. Took half a day to get down 18-20". I wanted to go deeper, but the chisel bit wasn't long enough to work deeper.
   / Auger won't drill hard clay #29
Just rent a skidsteer and post auger for a part day. Get er done.
   / Auger won't drill hard clay #30
I have a hydraulic assist down pressure unit for my speeco 3 point auger. Helps out alot. But i have limited amount of clay on my property.
Dry clay is like concrete.
New Wolverine Sid Steer 3PT Hitch Quick Connect (A59000)
New Wolverine Sid...
1997 international 4900 DT466E (A56435)
1997 international...
GRID SHAPED BUCKET FOR MINI EXCAVATOR (A58214)
GRID SHAPED BUCKET...
2004 EAGER BEAVER 50GSL/3 DETACH TRAILER (A52707)
2004 EAGER BEAVER...
2015 Chevrolet Silverado (A56858)
2015 Chevrolet...
2019 International DuraStar 4300 24FT Box Truck (A56858)
2019 International...
