can't upload pix
/ can't upload pix #41
Insert Image is the tree in a picture frame icon.
Thats the same as I get, I always click that same insert image but it no longer works and now when I click on the Advance icon, that isn't working now, I dont know what I did last night but I cant upload picture tonight.
/ can't upload pix #42
I am struggling too, always used the insert image icon/from computer, however nothing working for the last couple of days.
Tried shrinking picture size down to less than 100k, but that makes no difference either.
Never mind, they say a picture is worth a thousand words, so we just have to get typing :)
/ can't upload pix #43
This is what I am using:
It is in "General Settings":
Found it. It was in Misc Options, message editor. I was set for basic editor. switched to enhanced and now have more functions.
/ can't upload pix #44
Still cant upload pictures the way I use to by just clicking on the (Insert Image) icon, so I'll try this route to upload pictures, it's lot harder, 1> click (Go Advanced) 2>Click on (Attachments) and this comes up> so I click on (Add Files), 4> click on Choose Files), 5>click on (Upload), good grief I doing more click clucking now than most chickens, then for good measure click on (Preview Post) just to make sure all this clicking clucking worked........... THEN CLICK ON (SUBMIT REPLY) :(
https://www.tractorbynet.com/forums/attachment.php?attachmentid=661064&d=1593140445&thumb=1&stc=1
/ can't upload pix #45
Yep, still don't work...
/ can't upload pix
Testing it for just clicking insert image, didn't work. I had to go through manage attachments. BTW, if you hit "insert line" when adding images through that, it will show up in the message body.
Also, I messed around with the settings, tried Enhanced Attachment Uploading on and off, no luck there. Irrelevant to images, but I selected basic editor, and I like it better than the standard editor.
/ can't upload pix #47
Man, you really have to want to post a pic now, with this new riggamarow. Maybe the TBN managers don't want so many pictures posted??? But I'm an amateur at computers and that's not TBN's fault. Still aggravating though.
Cheers,
Mike
/ can't upload pix #48
Test insert image, Medium Size:
Still working same as always.
/ can't upload pix #50
Yep, strange.
I am on Chrome and these Miscellaneous Options on my Home Page:
/ can't upload pix #51
Lets try again after turning off Enhanced Attachment Uploading.
Nope... still doesn't work.
/ can't upload pix #52
going thru the manage attachment interface..
obviously that works.
/ can't upload pix #53
turned back ON using the enhanced attachment interface. so I can post already used images...
The insert image icon still goes thru all the motions, but does not actually insert the image in the reply box. It worked for years and years, but no longer works.
/ can't upload pix #54
Cheers,
Mike
TBN succeeded on that then, but then there's those that say "if no pictures it didn't happen" therefore your not really aggravated unless you have a picture showing your aggravated...
/ can't upload pix #55
Same thing here.
/ can't upload pix #56
As long as I'm complaining, How come I have to "log in" every time i come to TBN? :confused3: Did not used to have to do that. Is there an explanation for that.
Cheers,
Mike
/ can't upload pix #58
Yep, strange.
I've had my settings this way for the last 50 years, not only that I no longer get email notification for the past month but I'm not loosing sleep over it. Therefore it must be the corona or it's Trump's fault, uh oh now the this thread will be shut down..............
https://www.tractorbynet.com/forums/attachment.php?attachmentid=661198&d=1593226725&thumb=1&stc=1
/ can't upload pix #59
Cheers,
Mike
Did you click the (Remember Me)when logging in?
/ can't upload pix #60
This problem does seem to be dragging on ...
Has anyone seen an explanation from admin as to why we are still having problems with pictures when it was so easy before ?
Perhaps the forum is about to get a major change and it's just not worth trying to fix this in the short term :confused3:
Kubota RTV X1140 (A60462)
Kubota RTV X1140...
2024 CATERPILLAR 68" HYD 4IN1 BUCKET (A62129)
2024 CATERPILLAR...
2020 Bobcat MT85 (A62177)
2020 Bobcat MT85...
2009 JACK COUNTY KILL TRAILER (A58214)
2009 JACK COUNTY...
18ft T/A Utility Tailer (A61569)
18ft T/A Utility...
John Deere 7000 Planter (A63109)
John Deere 7000...
