Smart Shop tips!
/ Smart Shop tips! #141
I would most likely fumble and the ball bearing would fall into the intake manifold....
Oh man,, just had a mental vision of that scenario............ :(
/ Smart Shop tips! #142
And then tearing the engine down only to discover you must have dropped it on the floor and it rolled off somewhere....maybe
/ Smart Shop tips! #143
Awww,,, stop it...... I can't take anymore...... :D
Plays right into my OCDness.....
/ Smart Shop tips! #144
IMG_4641.jpgIMG_4640.jpg I came up with this yesterday. I seem to always be looking for a tape measure. Shop is still under construction so tools don’t have permanent homes yet. I put 5 of these picture frame hangers around my shop. Bent them out slightly and used longer nails than what came in the packaging. Now tape measures have a home and are easily accessible. I have 5 tape measures in my shop, but I’ll probably add more hangers as I go. The idea is that the tape gets hung either on a hanger or my belt as soon as soon as it leaves my hand. Not necessarily a specific hanger, just any hanger, that way it’s visible and accessible and I spend less time wondering around my shop looking for the darn thing.
/ Smart Shop tips! #145
Hemmed and hawed over whether French cleats were worth it. Initially did a small 32” test section and decided to take the plunge. As I’m finishing out my shop on my own and I’m more of a quick starter than a planner, I really like the versatility of being able to get stuff off the floor right now, but have the flexibility of relocating and organizing as I go. I went with 45 degree cuts and stained the cleats for a more finished look. I intend to continue the cleats all the way down the wall but have to cut and stain some more wood first. I considered 30/60 miters, but 45 seemed to work just fine and is pretty dead on with the built-in gauge on my table saw. Saves me the time and trouble of messing with the angle finder when I need to cut more.
/ Smart Shop tips! #146
View attachment 661122View attachment 661121 I came up with this yesterday. I seem to always be looking for a tape measure. Shop is still under construction so tools don’t have permanent homes yet. I put 5 of these picture frame hangers around my shop. Bent them out slightly and used longer nails than what came in the packaging. Now tape measures have a home and are easily accessible. I have 5 tape measures in my shop, but I’ll probably add more hangers as I go. The idea is that the tape gets hung either on a hanger or my belt as soon as soon as it leaves my hand. Not necessarily a specific hanger, just any hanger, that way it’s visible and accessible and I spend less time wondering around my shop looking for the darn thing.
Good idea!,
/ Smart Shop tips! #147
661169d1593200233-smart-shop-tips-leica_distod2-jpg
Finally got a laser tape measure. Its 330feet long and accurate to 1/32. Leica Disto D2 $115
And it shows the last measurement on the screen. And will add the two (or subtract) if you want.
And more. Much more. It will multiply 3 dims for cubic feet volume. It does Pythagorean calculations of distances you cannot measure, for example tree height.
Very happy I got on board. Sometimes im a little too curmudgeonly and Luddite, which of course is a tiny minority on TBN. :D But happy I jumped over that line. Cuz I still have a lot of stuff to build before I go to pasture. Yikes better keep busy!
/ Smart Shop tips! #148
I just swept out my shop of debris, (I have no idea how all that dirt gets in there), looking for a screw (from a terminal block) that I dropped into a generator, and don't dare start it now. It was right near the rotor. I didn't find it as I inspected the piles. :confused3:
My work bench bottom has only a few inches of clearance, and I have learned to put a piece of lumber lengthwise just a foots length in, as everything that ever fell down would fall under the bench and to the very back!
/ Smart Shop tips! #149
IT. Where the heck is your sense of adventure ?????
/ Smart Shop tips! #150
I mentioned this before but it's worth repeating.
I have 2 of the HF 250lb retrieving magnets. I keep them each wrapped in a 'thick' plastic bag, like the ones Menards uses (compared to the thin walmart bags). I put both magnets in the bottom of a 5 gallon bucket and drag or bounce it along the ground to clean up nails, screws, steel scrap in burn piles, etc. When the bottom gets covered I hold the bucket over the 'trash' barrel and lift the magnets to release everything collected. It keeps the magnets clean, especially with the bags, and is simple to collect, drop, collect, drop.
Last week after cutting and drilling some steel, I realized a 1 gallon bucket can be used with a single magnet and it even easier to use indoors.
/ Smart Shop tips! #151
That’s clever... I grind inside my shop and I’m constantly dealing with metal dust. I might try to fashion a similar solution near my grinding station to collect dust as it’s generated. I’ve looked into downdraft stations but either too expensive or too much time to DIY.
/ Smart Shop tips! #152
That grinding mess might be more stone grit than metal. I don't think I ever tried in on mine though. But for metal shavings it works amazing, especially compared to a brush or broom.
/ Smart Shop tips! #153
My magnetic roller sweep picks most of it up, so your concept should work. I’m thinking about inverting your concept and putting the bucket upright with the magnet underneath. Even if it only catches half the dust, I’d be way ahead.
/ Smart Shop tips! #154
I saw a youtube channel where the guy was removing stuff by hand from a Princess Auto Magnetic Sweeper. I have the same one and did the same thing for a while not realizing you could pull on a handle and have the stuff drop off! Those pickup things in various styles are so cheap on sale, you just can not have one.
/ Smart Shop tips! #155
Agree on the mag pickups; I have one of the HF 36" sweeps (no longer available) for one area, a 30" for another, and at least 3 of their approximately 3" round ones. The area where I normally use my mag drill is gravel floor, so after the "curly fry explosion" I just blow everything onto the floor and run the sweeper around listening to the clickety-clack. One pull over the scrap barrel and done... Steve
/ Smart Shop tips! #156
Dang. I was hoping mine was the same but it wasn’t.!!
That’s what I get for the ten cereal box tops and $1.99 postage and handling special.
Pretty sad day when when a Princess Auto product would be a major upgrade for a tool I have.
/ Smart Shop tips! #157
That is sad Terry. And surprising. ;)
/ Smart Shop tips! #158
Tools are like animals, Richard. I love them all
/ Smart Shop tips! #159
Me being frugal, i.e. cheap, I use a bunch of magnets from old microwave ovens. Tie a cord to em and drag em over the area but I do cover them with cheap aluminum foil first to make removing the metal bits easy. My wife bought a cheap roll around magnet at one of the box stores that we still must use the foil on to make removal of the metal hassel free.
/ Smart Shop tips! #160
Neat idea but aluminum foil is expensive! I just brush everything off with a shop cloth or a bench brush.
Caterpillar 245D Excavator Service and Parts Manuals (A63117)
Caterpillar 245D...
2023 New Holland C327 High Flow Compact Track Loader Skid Steer (A61572)
2023 New Holland...
Caterpillar Engine Parts and Service Manuals (A63117)
Caterpillar Engine...
2025 GIYI GY-PG72C 72in Dual Cylinder Hydraulic Grapple Bucket Skid Steer Attachment (A61572)
2025 GIYI GY-PG72C...
NEW HOLLAND TRACTOR (A64280)
NEW HOLLAND...
2004 Lincoln Navigator SUV (A61574)
2004 Lincoln...
