JD X749 Dying after 30-45 minutes
/ JD X749 Dying after 30-45 minutes
Got it, I'll check them.
This is where I'm at... All lines are 100% clear from filter to injector pump. The fuel supply line leading from the injector pump to the tank is gravity flowing at a very strong rate. I have not gone into the tank, but at the rate it's flowing I just cant imagine there is a obstruction.
So I have taken the transfer pump off and see that all connections and nipples are super clean inside. The manual pump works very well and there does not seem to be a problem. So, do I take it apart risking ruining these diaphragms and gaskets? I'm not sure where inside these check valves are but I got to tell you it seems unlikely this is the problem. What do you think?
Yes... To the injector from the tank. I have not checked the return.
Looking at the pump, I see the diaphragms and can just envision leaks afterwards where there once were none.
Do you mean to the injector pump from the tank, or is this a return line?
I don't think the transfer pump is a fragile item. I wouldn't hesitate to open it up to check the insides. You're running out of options on this to the point that the injection pump will be all that is remaining.
How about I hook up an electric fuel pump (I have one) and run it with that for a while?
/ JD X749 Dying after 30-45 minutes #64
I may have missed a few things (as usual). Is there a fuel filter at the front in the engine area? Is it clear plastic you can see through? If so, have you checked to see if there is fuel in it when the engine stalls?
Yea, you got to go back and read. We are way further than that.
It's worth a try. I might even consider bypassing the filter and go from the tank right into the injection pump.
That would also bypass the return line. I'm worried this electric pump might be too much without it.
/ JD X749 Dying after 30-45 minutes #67
Just an idea, but when I worked for a Deere dealer we used to see the fuel line from the tank get pinched between the fender deck and top of the tank. It wouldn’t be completely pinched shut but it would be enough that it run for a bit and then sputter and shut down. Pretty easy to remove the fender deck from what I remember. Unless they changed something.
Just an idea, but when I worked for a Deere dealer we used to see the fuel line from the tank get pinched between the fender deck and top of the tank. It wouldn稚 be completely pinched shut but it would be enough that it run for a bit and then sputter and shut down. Pretty easy to remove the fender deck from what I remember. Unless they changed something.
As I said earlier, the fuel flows very fast by gravity when I disconnected the supply line, but maybe I'll try the flow test while sitting on the seat.
/ JD X749 Dying after 30-45 minutes #69
Any chance there is a line that gets soft when heated and collapses under vacuum? This could also apply to the air intake system.
I can't say for sure but I don't think so. This is a tractor with low hours and everything inside and out appears as new. All hoses are in very good shape and clean. At this point I'm pretty sure it's a fuel starvation issue and not air intake which is also like new.
I got out this morning and tested that flow while sitting in the seat. Zero effect, and it is POURING out of the hose. I also disconnected the air filter sensor to see if it is heating and shutting it down. I looks like a normally open switch and I am not sure if it gives a warning or shuts the engine off.
Well I disassembled the transfer pump... absolutely pristine inside. It's back together and running without a leak. You were right, no problems with the gaskets.
/ JD X749 Dying after 30-45 minutes #73
I assume that the fuel goes from the pump you've opened up to the injector pump. If so I think I might add a pressure gauge right before the injector pump. There shouldn't be much pressure but it'll tell you if when it dies if the same pressure is there. If so then you might need to look at the injector pump. Since the time it takes to happen doesn't seam random I don't think there's something floating around in your tank that works it's way over to the outlet but at some point I think I would pull the tank and verify it.
I was going to post this yesterday, but didn't get around to it.
Now that you've pulled the transfer pump, you'll have to check the oil level in the injection pump.
Lovely... I didn't know there was an oil level to check. I've run it after putting the pump back on. Not much motor oil came out of the pump. I'll check the drawing you sent.
Also, as stated I ran it afterwards but this time it ran for 90 minutes without failure. It has never gone over an hour without dying so I'm holding my breath until next weeks cutting. The only change was opening the transfer pump and reassembling (I swear it was as clean as new). I also disconnected the wire harness from the air filter box. I don't know if a dirty filter kills the engine or sends an alarm but it seems to be an open switch that allows me to disconnect without killing the engine. I figured that if it is supposed to kill the engine, maybe it is overheating and failing. Time will tell if it's even fixed.
UPDATE: After looking at the diagram it looked very much like my pump. The directions are very clear as to where to ad oil and waiting for it to run out of the disconnected oil pipe below.
Now the reality of what happened: Looking inside the pump from the oil plug I could not see any oil which freaked me out. I started adding oil but nothing was coming out of the lower hole. After about 16 oz. I knew something was wrong and checked the motor oil level. All the oil is going into the engine and had to be drained. What am I doing wrong or does this pump get it's oil from the engine?
Not a bad idea.
/ JD X749 Dying after 30-45 minutes #76
I would ASSUME that the injection pump does get it's oil from the engine and just holds a small reservoir to use and any extra flows back to the engine sump. Being that the transfer pump is mounted lower than where they want the oil level to be, they just want the owner to top it off before running. Just get the engine oil level correct and run the heck out of it. Just let us know if it fixed the problem!
If you look at the diagram that E7LN provided it spells out that there is a separate oil level and how to check it. While that diagram looks just like my injector pump, it (hopefully) provides it's oil different than mine.
I wont be running it again until next week, I cut every blade of grass within a half mile testing it today!
That question, I can't answer, but I've seen the same comments in different tech manuals.
Maybe your overflow tube is plugged, or they simply want some oil added so you don't start dry.
I'll cross my fingers and run it.
I'm at the end of my rope. After cutting for 62 minutes yesterday, it died again. Other than checking the fuel pick up in the tank I have tried everything without success, and even that seems fine considering the amount of fuel that flows freely from gravity.
The odd thing about it is that it runs flawlessly until it suddenly dies. I would think that some sort of fuel blockage would result in a loss of power that I would feel. It looks like something I'll have to live with until it dies permanently.
2016 Caterpillar 349FL Hydraulic Excavator (A56857)
2016 Caterpillar...
2019 KUBOTA KX033-4 EXCAVATOR (A60429)
2019 KUBOTA...
2013 Ram 3500 Utility Flatbed Truck (A60352)
2013 Ram 3500...
2013 Peterbilt 365 IMT 40/275K6 9.5 Ton Knuckleboom Crane Truck (A60352)
2013 Peterbilt 365...
2013 GMC SIERRA (INOPERABLE) (A60736)
2013 GMC SIERRA...
2019 ALLMAND MAXI-POWER 25 GENERATOR (A58214)
2019 ALLMAND...
