Auger won't drill hard clay
   / Auger won't drill hard clay #11
Not sure what your clay is like but around here blue clay is common. Adding water to soften it up is like putting water in a glass and waiting for it to drain out.
What size auger are you using? my best recommendation is to get a very small auger (6") and drill a pilot hole. Good chance your teeth arnt digging. The point is stopping them from touching. If you have enough hole to hold the auger centered you could try removing the point and see if it will dig.
   / Auger won't drill hard clay #12
Screw point tip? Reason for different teeth and points. Picture of your auger might help with prognosis. Have rocks and red clay here so concur with the workability. Had problems with cheap or worn augers. Have more of a problem drilling too fast and getting auger stuck in the ground.
   / Auger won't drill hard clay #14
Growing up my dad had phd that we would hang on trying to get it to drill. Unshielded pto and auger turning is an accident waiting to happen. Always frustrating. Finally after 40 years brought it over and threw on my metal scrap pile. Bought a new screw point bit auger for $100 and used to build a new section of fence. He couldn’t believe the difference. He took it back to his place afterwards ;-)
   / Auger won't drill hard clay #15
Perc test is soils is based on the diameter and depth of a hole and how long it takes water to be absorbed into the soil. Frequently discussed concerning septic systems. Clays are the worse. They are only slightly better than baked and glazed clay pottery bowls, but just barely.
   / Auger won't drill hard clay #16
Hang a fat gal on the gearbox of the auger for 'Down pressure'....:laughing:
What are you trying to do ? Get him to bend his auger or go through 10 shear bolts per hole ?
:D
   / Auger won't drill hard clay #17
I hate 3 point augers for this very reason. The only solution is lots of down pressure. Get a hydraulic auger that mounts on your loader. We drill holes for dynamite anywhere from 10-30’ deep. Our drill rig is a modified skid steer that weighs 10,000 lbs. Most drilling is done with an auger, 3.5” in diameter. We often have so much down pressure when drilling that we are on the verge of lifting the front of the machine up.
Now I have a beltec auger for post holes but years ago when I had 3 point auger I welded up about 400 lbs of weight on it. It helped immensely but still digged no where near as good as a hydraulic unit with down pressure.
I don’t know how many holes you have to dig but if buying one isn’t an option go rent one. You will be amazed at the difference.
   / Auger won't drill hard clay #18
Time to invest in a hydraulic post driver like a Worksaver. No worries about clay with them.
Thats a great suggestion imo , even though for some it might not be affordable or cost efficient . I just always wondered though about the damage to a t post or wooden post when they hit good solid rock .
Post Hole Driver Shaver Saver Demo - YouTube
I don稚 know how many holes you have to dig but if buying one isn稚 an option go rent one. You will be amazed at the difference.
Totally spot on also ! :thumbsup: I used as good as 3 point PHD 's made except the homemade one's made from rear ends and what I can't stand is the constant turning around body and neck twisting that goes with it setting it up even with the ground marked to drill the holes .
BTW here's a pic of TBN member"s "MouseField"s home made rear end unit .
   / Auger won't drill hard clay #19
Check the angle of the cutting edge of your teeth.
Here's a diagram of a PHD auger I examined in the store. The cutter would be running on the heel of the angle, not the tip. It probably worked in soft ground but wouldn't in the really hard stuff.
Bruce
That is interesting and a good catch on your part. Same issue on subsoiler points if not set at correct angle, the subsoiler.
   / Auger won't drill hard clay #20
This was my problem as well a few months back. Over time the cutting edge had worn away until it was just a rounded edge rubbing on the clay. Made two new ones and bolted one on. I was unable to find the manufacturer to get a new (hopefully hardened one) but none to be found. So at least I have a spare.
2022 Ford F-150 XL Pickup Truck, VIN: 1FTFX1E83NKE63062, Extended Cab, 4 x 4, 3.5 L EcoBoost Gas (A59076)
2022 Ford F-150 XL...
2015 Infiniti QX60 SUV (A56859)
2015 Infiniti QX60...
2008 WABASH 53FT REEFER TRAILER (A58017)
2008 WABASH 53FT...
Year: 2014 Make: Chevrolet Model: Silverado Vehicle Type: Pickup Truck Mileage: Plate: Body Type: 4 (A55852)
Year: 2014 Make...
CASE MXM 190 (A58214)
19008 (A56859)
19008 (A56859)
