kubota bh77 dipperstick cylinder problem
   / kubota bh77 dipperstick cylinder problem #11
Well we found out it is not the cylinder. Air pressure works that back and forth just fine. The linkage is tight and seems to be working the valves correctly. My Tractor and backhoe are now in the shop as I am over my head now that we are talking valves or a blockage of some sort. :confused: One word of obvious advice "never take a BH off the tractor if it isn't working properly". :2cents: I did so I could mow with the 3 pt finishing mower. Getting the BH back on without all controls was a one hour operation. :duh: Lesson learned.
Here's part of message #5 that might be worth thinking about or looking up some old threads.
"I'll be interested in what you find. It sounds kind of similar to threads you may have seen here about Kubota TLBs that mysteriously lose and then regain their BH swing function. But you could move it by hand. That's been going on for ten years or more, and by now a dozen or more owners have reported it happening to them..... and we still haven't figured out why it happens."
The subject comes up at least once a year and nobody has figured it out yet. The difference, is that in all those thread it eventually started working again - except one case that had a bad cylinder. The rest are still a mystery. Mine hasn't done it again in the last 5 years or so. In all of those we could move the cylinder by hand or gravity but only power in one direction.
okay rScotty, The mechanic down at the shop wants to re-look at the cylinder. :confused3: but assured me they would get it working again. :laughing:
   / kubota bh77 dipperstick cylinder problem #13
Will be interesting to hear what they find out.
   / kubota bh77 dipperstick cylinder problem #14
That sounds good. If he is that confident then I'm guessing their shop has a hydraulic flow & pressure meter. That's the hydraulic equivalent to a electrical Volt/ohm/meter, but less common.
None of the shops that dealt with the mysterious TLB hydraulic problem in messge #5 had a flow meter - which is a shame because using one will generally pinpoint the problem real quick. Otherwise there's a lot of guesswork.
We could do a whole thread on what a good dealership tractor shop should have in the way of tools and training.
Although IMHO, there's still a place for the self-taught savant in his cluttered one-man shop....but they are going extinct around here. If you find one of those you have a gem.
rScotty
   / kubota bh77 dipperstick cylinder problem #15
Just in case this helps anything, after seeing this, yet another thread about bh77 glitchy behaviour. My BH77 does sometimes lose force with boom and dipper both extended away from the tractor, with down or lift force weak or gone.
Just checked again the action where the valve levers connect to the BH valve body, with the rubber boots lifted off.
I tried moving the levers through a complete range. The levers hit the metal frame AT 3 POSITIONS!
And there's even more interference when the rubber boots are clipped into place.
Moving the dipper/bucket lever all the way forward even hits the guard rail.
My next task is to remove the top plate that the levers pass through and run bh without that interference.
The design of the BH control tower has the levers way off center of the openings. There's lots of room when moving the levers toward the tractor or center.
I may try shimming under the lever mounting plate to help tilt it a bit away from the obstructions.
It should help SOMETHING to allow the valves full range of motion!
   / kubota bh77 dipperstick cylinder problem #16
The 3 places the lever motion hits the frame. IMG_20200609_184457473.jpgIMG_20200609_184434563.jpgIMG_20200609_184418352.jpg
Got the call today that BH77 was repaired and working great. Thirty minutes later I was at the shop. :thumbsup: They fired up the tractor and guess what, same problem. :shocked: I was told they cleaned up the valve area and I don't remember the rest but now we are into replacing some parts. :confused3:
   / kubota bh77 dipperstick cylinder problem #18
Do your levers hit the frame tube or tower top cover?
   / kubota bh77 dipperstick cylinder problem #19
Something doesn't sound right here. What is "cleaning up the valve area" mean?
Mechanics that do hydraulic repair have a pressure & flow measuring tool. It's generically called a "flow stand" or flowmeter.....that's the basic tool required for the hydraulic diagnosis. Using adapters, the flowmeter gets plugged into the hydraulic circuit in various places so that pressure and flow can be measured as the control valve is worked. A hydraulic flow stand is to hydraulic repair what a VOM is to electrical work. Otherwise a mechanic is just doing guessing and part replacing - some are pretty good at that kind of diagnosis, but it's a gamble on your dime.
Ask him to go over with you what pressure and flow readings he is getting at various points and what he thinks they mean. Take some notes and maybe we can help here, too. There's a lot of experience on TBN.
rScotty
UNUSED RAYTREE RHBC72 - 72" HYD BRUSH CUTTER (A54757)
UNUSED RAYTREE...
Adams 6T Fertilizer Spreader (A55301)
Adams 6T...
UNUSED 10PCS Industrial Polyester Lifting Straps (A53117)
UNUSED 10PCS...
2009 Honda Pilot AWD SUV (A53424)
2009 Honda Pilot...
2019 CATERPILLAR 279D SKID STEER (A52705)
2019 CATERPILLAR...
2005 John Deere 310G 4x4 Loader Backhoe (A53421)
2005 John Deere...
