kubota bh77 dipperstick cylinder problem
   / kubota bh77 dipperstick cylinder problem #1
DB Pilot
SW, New York
Case Farmall 65A, L3800 Kubota, BX2200 Kubota
Anyone have this problem with their BH77 backhoe? All has been working well for 5 years. For some reason the Hydraulic cylinder for extending the arm has stopped working. All other cylinders are working bucket curl, raise and lower boom, stabilizers and left right are all working properly except the dipper stick cylinder. I used it yesterday morning and it worked well. That afternoon I could not extend the bucket arm but after awhile all worked again. Today I cannot get the cylinder to extend the bucket arm. I can push the bucket out with my foot and it will come back in with the control but only a foot or so. My dealer is recommending a cylinder rebuild but I am not sure. The controls will bring the bucket in for transport. Anyone ever have this problem? :confused3:
   / kubota bh77 dipperstick cylinder problem #2
Need to take the cover off the linkage and make sure the levers are actuating the valves properly. The linkages can become loose, etc and cause issues.
   / kubota bh77 dipperstick cylinder problem #3
The piston may have disconnected from the rod (inside the cylinder). Yes, I have seen that.
Thanks to both ProjectKing and RickB. Both answers seem very likely. I will check out linkage today first. When I push the control lever to extend the boom the hydraulic hose surges. Which might mean looking inside the cylinder. :mad: I'll let you know what I find and hopefully some pictures. :thumbsup:
   / kubota bh77 dipperstick cylinder problem #5
That's a good observation about the hydraulic hose surging. I sometimes disconnect a hydraulic line and insert a short "T" made up with a $20 5000 psi pressure gauge on it. The whole "T" tool cost about $50 to make with adapters.
I'll be interested in what you find. It sounds kind of similar to threads you may have seen here about Kubota TLBs that mysteriously lose and then regain their BH swing function. But you could move it by hand. That's been going on for ten years or more, and by now a dozen or more owners have reported it happening to them..... and we still haven't figured out why it happens.
There was one recall on a Kubota BH cylinder I heard about a decade ago. But that was the boom cylinder not the dipperstick, and it moved both directions but had a problem in that it would not contract enough to engage the boom lock.
My experience is that cylinders are pretty reliable. For the occasional problem I've had very good luck taking cylinders to a local hydraulic shop for rebuild. Cylinders taken to the dealer usually end up at the hydraulic shop anyway.
rScotty
Looks like we are all on the same page here. :cool: I checked the linkage this morning and all seems correctly connected and moving. I now have the cylinder off the BH. :thumbsup: Right now I believe the nut on the hydraulic piston has come off. :rolleyes: Since the cylinder arm contracts in order for the boom to extend (it can't pull) but can push the piston out to bring the bucket back in (which it does). My local welding shop has rebuilt things for me or will know exactly where to take it. I will definitely let you know what happens.
   / kubota bh77 dipperstick cylinder problem #7
I had the nut come off the same cylinder on my case BH. If you grabbed the bucket you could pull it and the dipper would swing easily. Once you remove the gland nut it's not that hard to remove the piston. If you don't have the tools to remove the gland nut then anybody who rebuilds cylinders can do it.
   / kubota bh77 dipperstick cylinder problem #8
Wow. Thank you for sharing. I agree a cylinder shop should be able to repair. While they have it torn apart they should put in new seals too.
How many hours are on this backhoe?
Hours on tractor read 700+. But the backhoe I would guess about 100- hrs. It is about 6 years old and I would not want to be without it. Cylinder is in the shop right now and hopefully I will know in a day or two if it is the problem.
Well we found out it is not the cylinder. Air pressure works that back and forth just fine. The linkage is tight and seems to be working the valves correctly. My Tractor and backhoe are now in the shop as I am over my head now that we are talking valves or a blockage of some sort. :confused: One word of obvious advice "never take a BH off the tractor if it isn't working properly". :2cents: I did so I could mow with the 3 pt finishing mower. Getting the BH back on without all controls was a one hour operation. :duh: Lesson learned.
BW RVB3405 20,000lbs 5th Wheel Hitch Base (A50322)
BW RVB3405...
2025 Auger Mini Skid Steer Attachment (A53421)
2025 Auger Mini...
Galvanized Livestock Gates (2x Gates) (A55218)
Galvanized...
2012 Freightliner M2 Chipper Truck (A52377)
2012 Freightliner...
2015 Chevrolet Silverado 3500HD 4x4 Crew Cab Service Truck (A53422)
2015 Chevrolet...
2012 Ram 1500 Crew Cab Pickup Truck (A53422)
2012 Ram 1500 Crew...
