New Construction Seeding
/ New Construction Seeding #1
MGH PA
Gold Member
Northcentral, PA
2005 Gravely 148Z 48" ZTR
We just seeded our new lawn a little over 3 weeks ago (about 1 acre). We hand spread a mix of Perennial Ryegrass, Creeping Red Fescue, and Kentucky Bluegrass (we're in zone 6a), then spread 150lbs of 10-10-10. We did not spread any mulching layer, but received timely rains, along with supplementing with sprinklers. Needless to say, we have great growth. I have about 96% coverage, and I'm at about 3.5-4" average height.
I see a lot of articles state that you should wait about 8 weeks to mow for the first time, but then it's usually stated that this time frame is to allow the grass to reach 4"+ height. So if my grass has reached the height requirements before the time frame, should I still let it go to establish the root structure? If I wait for 8 weeks at this rate, barring a drought, the grass will be VERY tall.
Thoughts?
/ New Construction Seeding #2
I mow my tall fescue at 3" or 3 1/2", but your mix usually does better when mowed a little lower than that. If this were mine, I would mow now at about 3" or 3 1/2" and continue to mow 'high' to encourage good roots. Mowing now will also avoid too many clippings or clumping which is hard on a new lawn. Then in mid August or so, when the days are getting shorter and the lawn starts coming back after the hot summer, I would lower to the height you plan to mow from now on.
Edit - I would wait a couple days for this first mowing until after our extreme heat comes through mid week.
/ New Construction Seeding #3
mow now to avoid clippings building up and smothering the tinder grass / use sharp blades / water only as needed as letting the ground to dry some will make the grass roots reach further down
/ New Construction Seeding #4
I'd honestly wait the recommended 8 weeks... plants grow in two directions, after all, and letting the young roots mature & spread will be better in the long run.
If the grass height is a bother, then initially cut it twice. One pass high and then the last at the height you ideally want it at.
/ New Construction Seeding #5
Agree. Wait for the roots to get more established. The clippings being long shouldn’t hurt anything since theres no build up of years of thatch. Be patient and youll allow those roots to survive the pounding of the mower tires.
I plant fields for hay, almost always in the fall. By the following spring, they are established and the roots are strong. Last year, I planted a field early spring and attempted to mow it late summer. It caused a lot of crown damage to the plants and I ended up with weeds overtaking the lawn.
/ New Construction Seeding #6
Mowing helps thicken the lawn so you don't want to let it get tall and leggy, allowing bare spots for weeds. Mowing acts the same as top pruning any plant, encouraging more shoots and thickening.
/ New Construction Seeding #7
Follow the seed company's recommendation. They want their product to perform well. Roots do need to be allow to develop strongly. Yes you do mow to help grass spread but that only works with some grasses who will spread. Some have to reseed to produce more hills of grass. Be sure your blades are sharp.
I think I will call the company. I don't care about the length (I don't have neighbors). I just don't want to negate all of my hard work.
/ New Construction Seeding #9
Don't worry too much about a perfect plan. The weather will have more affect on the lawn than when you cut it or at what height. You can see from the comments so far that there are several opinions on what each of us would do. I've put in many acres of lawn over the years so I'm comfortable with my methods and know what to expect for my grass types and the weather in my area. There's no right or wrong, other than keeping it watered if we don't get enough rain.
/ New Construction Seeding #10
I agree. It'll be hard to irrigate an acre of lawn but it may come to that.
I've not had good luck seeding in the Spring. Always looks great until late July.
I seeded last year in late August on dry dusty dirt. Didn't mow it at all last Fall. Have a great lawn now.
/ New Construction Seeding #11
Late Spring is the absolute WRONG TIME to plant grass seed (unless you have in ground irrigation).
Mid September is the PERFECT time to seed new lawns,...with or without irrigation.
In a perfect world, maybe. With two young boys tracking mud through a brand new house all spring, it was prudent to get something in the ground.
/ New Construction Seeding #13
Man do I feel your pain we are in the same boat. New house and all of may was a rainy mess finally got the lawn in over memorial day weekend and weve had maybe 2 days of rain? Weve been watering an acre just about every day it takes about 3 hours and our water bill shows it. It's coming in but is slow to respond and a little patchy from a heavy rain that I think washed some off we didnt do any ground cover either. Dealing with the mud was to much with our boys and I'm planning on over seeding in the fall
/ New Construction Seeding #14
My Nephew owns/operates a Sod Farm. He said you need 350lbs of seed per acre of space. I was shocked. I said, it's $2 per pound. He said, you want a pasture or a lawn? I used $700 of variety seed and $300 of fertilizer. 10 months later I have a lawn. People ask us if we sodded it? :cool:
/ New Construction Seeding #15
Inwas shocked at the price of grass seed I'm prolly a little light I put down about 250 pounds of seed
/ New Construction Seeding #16
Rick's comment was if you can put your thumb on the ground and not cover a seed you didn't put on enough.
/ New Construction Seeding #17
That makes sense it was just all around bad timing for me super wet in may then dried enough to prep and the day I planted we had a strong rain that I believe washed patches of seed away. Overall I think its coming in as good as it could be but overseeing in the fall will definently help it alot. Doesnt help the ground is also hard clay so water runoff is a problem I did spread some pete moss and I wish I would of done the whole yard its growing better in those spots
/ New Construction Seeding #18
Yeah,,,,,I know. Sometimes you have to do things they don’t want to do. We always plant in the fall. The property owner had a situation where it had to be planted in the spring or erosion would have been a problem.
/ New Construction Seeding #19
Do you have any mushroom soil or compost available in your area? Usually if there’s a mushroom grower within 20 miles, they will deliver it to you for a small cost. I get it free. They can’t get rid of the stuff fast enough. It’s great for adding a layer of organic material to clay. It also contains a lot of lime.
All depends on where you live. Check around for a mushroom grower.
/ New Construction Seeding #20
I had to seed this year so I picked early spring knowing frost might be an issue. I agree Sept is the best, but needs dictate timing.
Once grass is established I let it go to seed before mowing my side yards, this gets any bald spots pathed. I run an aerator over the yard first. I aerate in the fall too.
I used some lime this year, but try to stay away from fertilizer as it makes a mess of the local waterways. Always shake my head when someone complains about the growth in their pond/lake/creek while dropping tons of fertilizer on the lawn like they are going to eat it or something.
2019 CATERPILLAR 299D2 XHP SKID STEER (A64279)
2019 CATERPILLAR...
2012 Gehl DL11-55 11,000lb. 4x4 Rough Terrain Telehandler (A61572)
2012 Gehl DL11-55...
2019 HYUNDAI V12530152-AJS 53' X 102" T/A VAN TRAILER (A59912)
2019 HYUNDAI...
2003 Tennant 7400 Compact Industrial Floor Scrubber (A61572)
2003 Tennant 7400...
2003 International 4300 National Crane 326A 7 Ton Straight Boom Crane Truck (A61573)
2003 International...
New Holland TM135 (A64119)
New Holland TM135...
