Oil & Fuel 4310 ehydro smoking
/ 4310 ehydro smoking #1
chrismorton
johd deere 4310 ehydro
So I got called to check out the tractor because it was not running right. When I got there the oil was Almost completely dry. I added oil immediately but I think I was too late. We just recently got it back from shop and they said they changed filters so I am assuming they changed the oil. I have not seen any oil spots so I don not think it is leaking significantly. Now when I raise the throttle past halfway it smokes from the vent hose and starts squealing. Any ideas?
/ 4310 ehydro smoking #2
First thing to check for squealing is a loose belt. Had to tighten mine the other day.
Low oil and blowback sounds like rings are shot. If it was run low on oil the squealing could be the crank seizing but check the belt first anyway.
I did figure out the last problem with the help of these forums. It was a bad pump seal. Seems like every time I get the tractor going again something else goes wrong.
/ 4310 ehydro smoking #5
How many hours out of curiosity?
I知 sorry how many hours for what
/ 4310 ehydro smoking #7
it sounds like the shop never added oil after changing the filters and draining the oil!. that's a big NO NO!!..
/ 4310 ehydro smoking #8
How many hours on the tractor?
Anybody know if I can get a normal diesel compression test kit or do I need the gauge and adaptor that is called for in the manual
Sorry I have to get back to you on hours
/ 4310 ehydro smoking #11
Had my new grand in dealership for the 50 hour service. Was doing some repair (limb before grill guard) to it when it got back and noticed the coolant level. Was almost empty. Sent picture to owners son and ask if that was their typical service and he sent back asking I fill it to proper lever. Yes I checked the oil levels also.
Got pickup once from having tires changed and lug nut were not tight on right rear. Knew something was not right when got back to office and walked around it. They wanted me to drive it back...
/ 4310 ehydro smoking #12
great!. now you have to check if the mechanics do proper work??.. oh boy!..
UNUSED PARBREAK SST23 BEAR SHAPED SHOOTING TARGET (A65055)
UNUSED PARBREAK...
2012 Caterpillar Warren Power Systems WCW204MH 20KW Towable Light Tower (A64194)
2012 Caterpillar...
13ft. Dump Trailer (A64556)
13ft. Dump Trailer...
SHOPBUILT MESH BOTTOM TRAILER (A64278)
SHOPBUILT MESH...
2016 CATERPILLAR TL1055D TELESCOPIC FORKLIFT (A65053)
2016 CATERPILLAR...
(96) BOARDS OF 1"x8"x8" PONDEROSA PINE (A65055)
(96) BOARDS OF...
