Comparison Kioti
/ Kioti #1
dbeverly68
Mt Rose,Texas
Kubota
Just joined. Thanks for accepting. I’m looking at the NX series. Probably the the 5010 or the 5510. I would prefer the bigger tires of the 55. I also wished you could get the 12x16.5 on the fronts. Tractor will be used mainly fo loader work but will be used to mow also. Leaning more towards the hst. Has anyone had any issues with the hydro transmission? I’m really having a tough time deciding between the Kioti and Kubota. Looking at the MX5400. I really like all the features and deck of the kioti. Any advise? Thanks in advance!!
/ Kioti #2
Tractor will be used mainly fo loader work but will be used to mow also. Has anyone had any issues with the hydro transmission? /QUOTE]
Loader work is hard on clutches, hydros, shuttle shift, hydro reverser, other trademarked names are best. Run tractor near or at rated engine speed for psi and cooling of hydro oil. Run hydro pedal at or near full power, usually medium range for mowing (high range rough on rear end - YOUR's)
/ Kioti #3
Welcome to TBN.......
Suggestion on your profile......
if you add a location like your home address so we know when to show for BBQ......j/k......Hmm...maybe not.....heh...:D
OK, really location, will help when it comes to questions about vegetation, clearing, etc a multitude of what pops up.....the folks here can provide better info.
As for the HST question; Wiley has about 594 hours and is up for its 400 hour hyd. fluid/filter change out......( I did an OCD change out at 200hrs)
No leaks or performance issues. Prematurely replaced a battery. Replaced with a larger CCA battery and four months later had start issues.
Discovered the ground clamp had no more adjustment left to tighten. Hate the soft lead OEM stuff. Replaced with marine grade battery clamp and bout 40 hours later still works great.
Other then that been excellent, for me......but then all other color machines are also great for the owners just depends on what fits you best and your rapport with your local dealer.
Good luck....and again welcome to TBN.
/ Kioti #4
:welcome: to TBN...enjoy.
Front loader work yep HST time saver :thumbsup: depends on what kind mowing and if ground some what rough and slope I like DT.
/ Kioti #5
G'day Mate and welcome to TBN from Downunder.
Ditto on HST for FEL (front end loader) work... and for tractor (CUT) work in general. Figure what the biggest lifting job you will be doing and buy accordingly. If you can afford the 55, go for it.
Enjoy the site. (we LOVE spending your money :))
/ Kioti #6
Bigger tires is why I opted for the NX5510 too. Would have been fine with 40 or 50HP engine, but I wanted the bigger tires and ground clearance for working in the woods, so I ended up with a little more engine than I really needed, but I consider it future-proofing also. If I ever need to run a larger PTO-driven machine, I'll have a few extra ponies to help with that I suppose . I definitely prefer HST for loader work, and working in tight woods like I do. I wouldn't mind bigger fronts myself. No easy way to switch to 12-16.50 fronts though; being taller, they'll throw off the gear ratio between the rear tires and the fronts. I'm sure it could be done, but it'll be more involved than just switching tires to do it right I'm afraid. Not to mention likely voiding any warranty you may have as well, unless its a mod the dealership would be willing to do. But I doubt it.
/ Kioti #7
FWIW, loader work is normally about the easiest kind of work a tractor loader can do.
OP: You can also look at Bobcat's version of the NX as well.
/ Kioti #8
I have an NX with loaded AG tires set at 82.5 inches wide. It does well with the loader and loaded AG tires. I rarely have to use the 4WD. Over 400 hrs going strong
/ Kioti #9
MinnesotaEric, I think I read on here somewhere that you bought your tractor from the dealership in Ramsey? I didn't think you had a very good experience with them. What didn't you like about them?
/ Kioti #10
I would not purchase another Kioti because of the American Importer.
/ Kioti #12
/ Kioti #13
What does that mean.
Kioti/Daedong builds and imports their own machines don't they ??
KIOTI Tractor Division is a Division of Daedong-USA Inc. KIOTI Tractor Division is responsible for the Distribution & Support of KIOTI Tractors in North America. They do not use an independent importer.
Hope this helps...
/ Kioti #14
Hope this helps...
That's what I thought.
So what is Eric talking about ??
/ Kioti #16
Just joined. Thanks for accepting. I知 looking at the NX series. Probably the the 5010 or the 5510. I would prefer the bigger tires of the 55. I also wished you could get the 12x16.5 on the fronts. Tractor will be used mainly fo loader work but will be used to mow also. Leaning more towards the hst. Has anyone had any issues with the hydro transmission? I知 really having a tough time deciding between the Kioti and Kubota. Looking at the MX5400. I really like all the features and deck of the kioti. Any advise? Thanks in advance!!
Six years since I choose my Kioti over the competition and to date have had zero issues with it.
/ Kioti #18
Just rung up 500hrs on my NX. I'm a bit behind on providing updates in my dedicated thread.
No issues with HST (other than the messy shifting- found out that shifts into "M" work best at around 1,600rpm, and that twisting the steering around at the same time can help).
Engine is also running well. Only issue I've had was water in fuel, something that magically went away when I got a new locking fuel cap from the dealer: interestingly it was a different design; a thing that pisses me off is that I never get reasons for why my dealer does things such as this- was it a redesign of a faulty cap to begin with? I spent a LOT of time verifying my fuel, draining lots of equipment looking for water and found none. One starts to feel that one is crazy (and I know when I'm actually crazy, so don't make me feel like I am when I know I'm not! :laughing:).
Rear diff had sealing issues, requiring two trips to the dealer: they changed the housings the second go-round.
I've had a love/hate relationship with my cab. Early on it leaked. Took two trips to the dealer before resolved. Felt good until I had to attend to mouse infestation and resolve an issue with the cabin blower not working (not related to mice- factory defective connector). Discovered that RTV ought NOT be used to seal something like the cab top if you are ever needing to remove the top! I'd shook my head at my dealer when they'd told me (several years back) that they'd RTV'd the thing. Figure it cost me 8 hours of my life to deal with their crap job (that would be 8 extra hours in cutting the RTV and cleaning it off the top and the cab's top rail). Had left door replaced due to it becoming really resistant to closing (took really slamming it for it to close/latch properly): the dealer said that they couldn't find a problem; they replaced the door; really, they replaced it when there wasn't a problem? BS! (I hate being jerked around; they could, and HAVE done, crap that they won't own up to).
I did a fair amount of loader work when I did my fence project. Had over 100 small dump trailer loads of material I hauled from my neighbor's: figured I was running about 12k lbs per load (15k total towing load?), which should tell you that it's not a toy trailer! Ballasted rears. Didn't have extra ballast on the three-point because I was hauling my trailed back and forth. With the ballasted rears it was just enough to offset a bucket full of material (gravel-ish material). I regularly move around crates of firewood (pallet fork work, figure 1,000 to 1,500 lbs). Lots of grappling (brush as well as tree trunks- I know that I've hit over 2,000 lbs). Happy with the loader performance.
Folks say that the HST draws down power when engaging in dirt work, but I had my 7', 1,200 lb box blade curling sod over on top of itself. I was able to do all that I needed to do. Tractor would grunt and groan but manage. Dropping rippers down created an instant anchor: a comparable non-HST machine wouldn't fare any better in this instance (for me, in my ground).
It's a coin flip as to whether I'd buy Kioti again. Probably good that I'll never probably need to buy another tractor: hoping that what I have will last me the rest of my days. Best choice I made was to get a cab: keeping dust and insects away is a huge plus (reminded every time I do any mowing with my B7800- how did I ever survive all the work I used to do with an open station?); have to be extra cautious when operating as I have lots of trees: when I had my cab roof off I did a repair on damage from a tree branch piecing it. My decision would be made harder due to the fact that I don't really care for my dealer: tolerate them for warranty work because if they don't get it right it's not on my dime to resolve; when out of warranty I don't know what I'll do (with no code reader one is pretty much out of luck dealing with such things oneself- but this isn't just a Kioti issue).
2019 Deere 35G (A64126)
2019 Deere 35G...
1997 Duraco Dura Patcher 81DJ Towable Asphalt Patcher (A64194)
1997 Duraco Dura...
2 new 10'' Pallet fork extensions (A61567)
2 new 10'' Pallet...
New/Unused Landhonor 6ft x 8ft Galvanized Apex Roof Metal Shed (A65583)
New/Unused...
Landhonor 8'x10' Galvanized Apex Metal Shed (A62679)
Landhonor 8'x10'...
New/Unused ATS 13000 Pound Electric Winch (A65583)
New/Unused ATS...
