Bush hogging is best without front loaders on
/ Bush hogging is best without front loaders on #41
Does anyone get off their tractors?
I try to avoid this like the Corona Virus...
Back when I was a kid, we had to pick rocks and we used a bucket loader to do so. Up and down, up and down, up and down...it was the CLIMBING that wore you out, more than the picking of the rocks!
Then I started to notice it in logging. All that climbing up and out of the cab wore me out. Now when I log, I try to do as much as I can when I am on the ground, and as much as I can when I am up in the cab of the skidder. Doing that really, really makes a difference on how much wood I get out in a day, and how tired I am in a day for a given amount of wood hauled out of the woods.
Even in mowing the sides of the road, I try and limit how often I get on and off the tractor. Unless there is a broken knife or shackle, I try and change 50% of my knives in the morning and at lunch so I can have sharp knives and mow for long stretches of times. It makes a huge difference. I not only get more road miles mowed in a day from not having to stop, I can mow in 1 higher gear!
/ Bush hogging is best without front loaders on #42
I am a little shocked that anyone would mow an area, not having scouted it first and relying on the loader to find stufff.
Look up Japanese Knotweed.
Try to walk through and scout a couple acres of that.
Here a picture from internet.
Using the Helen Keller front loaded technique is a must unless you 100% sure there’s nothing to hit.
Plus it snaps over most of the stalks so they are lying down when you pass over.
I mow a few acres of this on my neighbor’s property. Even when you know where the obstacles are, you still need the FEL to actually find them. Adjustments.JPG
/ Bush hogging is best without front loaders on #43
Here in Texas, walking through tall stuff is a life or death risk. I have water moccasins and copper heads all over my property. I carry a .357 with snake shot next to me when bush hogging. The last time I was out, I shot two copper heads and I was too slow on a black snake that went into a hole. I only saw it's tail, so I can't say for sure what it was. Last time I was mowing trails on my zero turn, I chased down, but din't get to a water moccasin fast enough. Nobody walks out in the brush where it's not mowed without expecting to run into a snake!!!
/ Bush hogging is best without front loaders on #45
I mow a few acres of this on my neighbor’s property. Even when you know where the obstacles are, you still need the FEL to actually find them. View attachment 657546
That’s rough looking stuff. How often do you mow it? Is it on level ground?
/ Bush hogging is best without front loaders on #46
One reason I do not get out a lot when I am mowing the sides of the road is ticks. Here they can give you Lyme Disease which is another reason to stay on the tractor as much as possible.
Ticks are bad here, but fire ants are even worse!!!! Wasps, hornets, ground bees and just about everything growing has thorns on it, from the black locust trees to the vines going up the trees, to the stuff all over the ground that is full of thorns.
I'm amazed when I see pictures of people walking in the grass without shoots, and terrified when I see them sit down on the grass like it's not dangerous. The reason to keep the grass short is to give you a chance to avoid the pain that comes from everything living in the grass!!!!!
/ Bush hogging is best without front loaders on #47
Ticks are bad this year here also. I mostly get off when mowing trails in the woods, cant always just push stuff out of the way. dont know what i would do without a loader. 4 tractors with loaders and none have ever been off.
/ Bush hogging is best without front loaders on #48
Ticks are nothing to mess with. Sadly, it took the doctors 12 years to finally realize my wife has Lyme Disease. So, she is stuck with it for the rest of her life and the side effects.
Wear your tick repellant and be diligent after you have been outside to check for them.
/ Bush hogging is best without front loaders on #49
If you are brush hogging for hire you might as well stay home if you think you are going to walk all the fields you mow.
/ Bush hogging is best without front loaders on #50
On the other hand, over all the years I have been rotary cutting for hire, I've never needed or wanted a loader on my tractor.
It's just added weight to haul around from job to job, and always in the way to see better or when in fenced fields...
My brush hogging tractor doesn't even have a loader.
SR
/ Bush hogging is best without front loaders on #51
A guy I know always said, “Everything out here will either sting you, stick you or bite you.”
Not to mention all the poison ivy and other poison plants that can irritate you.
/ Bush hogging is best without front loaders on #52
A guy I know always said, 摘verything out here will either sting you, stick you or bite you.
Ticks are pretty bad here, when I change the knives it is nothing to see hundreds crawling everywhere. How I managed to not get bit over the years, I will never know.
As for poison ivy...I was not so lucky. Last year I blew one of my roller bearings and it fell down pretty hard. I could not rack the boom mower and drive back 5 miles without it breaking the other bearing, so I went looking for barb wire. Trust me, when you mow the sides of the road, you quickly realize fencing wire is everywhere.
I found some, secured my roller so it would not fall down, but in doing so I got my arms covered in poison ivy. It was so bad I had to go to the Emergency Room for steroid shots.
/ Bush hogging is best without front loaders on #53
Made a few trips to the Doc myself because of poison ivy. I try to watch and stay out of it as much as possible but it’s impossible to completely avoid.
My wife is completely immune to it.
/ Bush hogging is best without front loaders on #54
We don't have that kind of stuff up here. But, I once did mow an area with a flail mower and couldn't put pants on the next day (and did not go to work) as something on my legs was itchy and prickly like glass slivers. Never had that since.
Fortunately, never seen poison ivy in my life. None around here.
/ Bush hogging is best without front loaders on #56
As I recall, it took a day or so, without any special attention. Some kind of nettles maybe?
/ Bush hogging is best without front loaders on #57
For Poison Ivy rash, try a hair dryer. I know it sounds crazy. You heat the area until you can’t take it. It does something to the nerve endings that relieves the itch for a few hours. Google it for a better description. It has worked for me several times over the years.
/ Bush hogging is best without front loaders on #58
I use HOT water, as hot as I can stand it and Lava soap, I scrub it raw! The soap washes the oil away that causes it to spread...
Repeat as needed...
SR
/ Bush hogging is best without front loaders on #60
Try Boraxo soap. It will make a good paste.
I use to use it, it came in the round tube looking cardboard cans. BUT, it's hard to get around here now. The last store that carried it, went under years ago...
SR
20800 (A56859)
20800 (A56859)
2019 CUSHMAN HAULER PRO ELECTRIC GOLF CART (A58375)
2019 CUSHMAN...
TAYLOR POWER SYSTEMS SKIDDED GENERATOR (A60736)
TAYLOR POWER...
SET OF (10) ACE CATTLE PANELS W/CONNECTION JOINTS (A60736)
SET OF (10) ACE...
2016 Bobcat E85 Midi Excavator (A56857)
2016 Bobcat E85...
2017 Freightliner M2 106 AWD Terex Hi-Ranger 5TC55 55ft. Insulated Material Handling Bucket Truck (A60460)
2017 Freightliner...
