Bush hogging is best without front loaders on
   / Bush hogging is best without front loaders on #51
Ticks are bad here, but fire ants are even worse!!!! Wasps, hornets, ground bees and just about everything growing has thorns on it, from the black locust trees to the vines going up the trees, to the stuff all over the ground that is full of thorns.
I'm amazed when I see pictures of people walking in the grass without shoots, and terrified when I see them sit down on the grass like it's not dangerous. The reason to keep the grass short is to give you a chance to avoid the pain that comes from everything living in the grass!!!!!
A guy I know always said, “Everything out here will either sting you, stick you or bite you.”
Not to mention all the poison ivy and other poison plants that can irritate you.
   / Bush hogging is best without front loaders on #52
A guy I know always said, 摘verything out here will either sting you, stick you or bite you.
Ticks are pretty bad here, when I change the knives it is nothing to see hundreds crawling everywhere. How I managed to not get bit over the years, I will never know.
As for poison ivy...I was not so lucky. Last year I blew one of my roller bearings and it fell down pretty hard. I could not rack the boom mower and drive back 5 miles without it breaking the other bearing, so I went looking for barb wire. Trust me, when you mow the sides of the road, you quickly realize fencing wire is everywhere.
I found some, secured my roller so it would not fall down, but in doing so I got my arms covered in poison ivy. It was so bad I had to go to the Emergency Room for steroid shots.
   / Bush hogging is best without front loaders on #53
Made a few trips to the Doc myself because of poison ivy. I try to watch and stay out of it as much as possible but it’s impossible to completely avoid.
My wife is completely immune to it.
   / Bush hogging is best without front loaders on #54
We don't have that kind of stuff up here. But, I once did mow an area with a flail mower and couldn't put pants on the next day (and did not go to work) as something on my legs was itchy and prickly like glass slivers. Never had that since.
Fortunately, never seen poison ivy in my life. None around here.
   / Bush hogging is best without front loaders on #56
As I recall, it took a day or so, without any special attention. Some kind of nettles maybe?
   / Bush hogging is best without front loaders on #57
For Poison Ivy rash, try a hair dryer. I know it sounds crazy. You heat the area until you can’t take it. It does something to the nerve endings that relieves the itch for a few hours. Google it for a better description. It has worked for me several times over the years.
   / Bush hogging is best without front loaders on #58
I use HOT water, as hot as I can stand it and Lava soap, I scrub it raw! The soap washes the oil away that causes it to spread...
Repeat as needed...
SR
   / Bush hogging is best without front loaders on #60
Try Boraxo soap. It will make a good paste.
I use to use it, it came in the round tube looking cardboard cans. BUT, it's hard to get around here now. The last store that carried it, went under years ago...
SR
Bush Hog 3pt 14' Mower (A53317)
Bush Hog 3pt 14'...
2013 FREIGHTLINER  CASCADIA (A55745)
2013 FREIGHTLINER...
Dump Truck Body with Tarp System (A55852)
Dump Truck Body...
Peterbilt 377 Semi-Truck (A55315)
Peterbilt 377...
ST225/75R15 Trailer Tires (A55788)
ST225/75R15...
2002 International 9200i Truck (A55315)
2002 International...
