Looking at a grapple- right size for my tractor?
/ Looking at a grapple- right size for my tractor? #11
View attachment 657343. This is my Kubota M6040 with a Land Pride 1560 grapple. It's 60" wide - 820#. The tractor with FEL/grapple - RimGuard loaded rear tires - Rhino rear blade - - weighs 10,010#. It's a very HD rock/root grapple.
Look carefully at the grapple you are considering. If it's too heavy - can you actually chop a foot off each side. What you are looking for - are the hydraulics in the center of the grapple. If so - chopping will be easy. If they are on the edges - it could be a problem.
I can lift a tad over 3000#. I NEVER lift a heavy load more than 6" off the ground.
I went and inspected the grapple yesterday, it appears very well built and does not seem to be oversized for the tractor, actually looks like exactly what I have been on the lookout for. The width is 4" outside the front tyres of my tractor each side, 4" inside the rears so not unreasonable I think. It's a single full-width lid with a hydraulic cylinder at each end, the mechanism is right at the ends so cutting it down is not an option, or not without a lot of work. The work I want the grapple for is mostly picking up and carrying piles of branches from felled trees, rather than logs, and I think it is ideal for that. The load will not be much weight, just bulky. It has one bid at present, auction ends in 8 hours, I'll be bidding on it and will let you guys know if I end up with it.
/ Looking at a grapple- right size for my tractor? #13
When I went to buy my SSQA grapple, I thought I wanted a 60". Fortunately for me the tractor gods knew more than I did and they were all out of 60" grapples. All they had was 72" and up and some 48"s. I bought the 48". I will never regret it!
There has never been a time when I regretted not having the extra width but there has been a crap-ton of times I'm **** glad had the extra lift capacity that would have been eaten up with something +48"!
Just a thought.
Good luck!
Here's an update. I put in an autobid up to $10 less than my budget; got up from the TV and told my wife I'd be a few minutes while the auction ends went to the study to make sure I got the final bid in- she started watching a movie on her iPad and crashed our internet. I couldn't load the page and the grapple went for right on what I had told myself I was prepared to spend! I'm trying to remain calm. I've been looking our for one of these things for about 2 years! Guess I'll be building one after all! :0
/ Looking at a grapple- right size for my tractor? #15
Pete, sorry about that. But there was a reason for that to happen...maybe a better option pops in next few days...first thank you wife and explain you must expand the hunt. Ever planned a grapple hunt vacation?
Yep, we are on the same page, I fully agree, there was a reason so I am ok with it. If nothing else, it's given me an opportunity to be gracious to my wife! Wish I hadn't spent half a day going to check the thing out though!
/ Looking at a grapple- right size for my tractor? #17
As long as you & the wifey are OK - all is well and the search continues.
Your situation there in Australia is very similar to what I've heard from many TBNers in Europe. The smaller homeowner grapple is not a common item. If you do decide to build your own - send me a personal message. My Owners Manual for my grapple has diagrams, showing of all the dimensions. Could be a fair starting point.
/ Looking at a grapple- right size for my tractor? #18
Pete O said:
including adding a double-link system to increase the roll back / forward angle.
Pete, this is a touch off topic from grapples, but do you think you could post some pics of your linkage upgrade to increase roll-back/dump angles?
/ Looking at a grapple- right size for my tractor? #19
The work I want the grapple for is mostly picking up and carrying piles of branches from felled trees, rather than logs, and I think it is ideal for that. The load will not be much weight, just bulky.------------------------------------------------------.
I am surprised you would choose a clamshell style root grapple for that job. My first grapple was a clamshell style with two lids. did not pick up bulky piles well, a lot would fall out the bottom: https://www.tractorbynet.com/forums...ying-new-grapple-post4622699.html#post4622699
I now have a two lid 72" flat bottom and six tine 44" that move brush, limbs, trees and rocks very well.
That's a very kind offer, thanks heaps, I think I'll PM you soon and take you up on that, it might be a while before i get around to building something (the loader rebuild is taking a long while) but it would be great to have the information handy when I start planning.
Vertical Steel Well Tank (A61570)
Vertical Steel...
2019 CATERPILLAR  XQ35 GENERATOR (A58214)
2019 CATERPILLAR...
2020 Freightliner M2 106 AWD Altec DC47TR Digger Derrick Truck (A60352)
2020 Freightliner...
Volvo EC220EL (A60462)
2020 PETERBILT 567 (A58214)
2020 PETERBILT 567...
(25) Safety Traffic Cones (A60463)
(25) Safety...
